Question about Acer Aspire™ T180 PC Desktop
Ive brought a new gaming rig, as follows CPU: Athlon II X2 240, 2.8Ghz MBD: Biostar TA770E AM3 / DDR2 / SATA RAM: 2GB DDR2 800MHz Case: CoolerMaster Elite 330 PSU: WinPower 450w One 300gb Sata drive One 160gb Sata drive One LG Dvd Writer Graphic card: MSI Geforce 9500gt MD1G-OC/D2 Now when i first got it no problems at all, i could play Crysis, Cryostatis, Riddick, Saw and Mass Effect. All on high and max settings, running fine. Two weeks later it wouldnt let me play any of these games without shutting down, 2-5 mins into a game i would hear a click and it would turn off but the computer would still be running half the time. I thought it was a graphic card problem so i swapped with my geforce 7500GT and it still crashed, i removed one of my sata and dvd drive and still the problem consists? [code] The cpu is at a 22-30°C Graphic cards are at 45-60°C And the case is well ventilated. There is no dust on either card or cpu. And these are all new parts? I also did test using CoreTemp & CpuID Here are the results CPUID:,0x100F62 Processor:,AMD AMD Athlon II X2 240 (Regor) Platform:,(null) Revision:,DA-C2 Session start:,20:34:50 - November 11 - 2009 Time,CPU 0 Temp.,,CPU 0,Low temp.,High temp.,Core load,CPU speed, 20:35:00,23°,,,23°,25°,5%,2800.17 MHz, 20:35:10,25°,,,23°,25°,65%,2800.17 MHz, 20:35:20,27°,,,23°,27°,31%,2800.17 MHz, 20:35:30,27°,,,23°,27°,61%,2800.17 MHz, 20:35:40,28°,,,23°,29°,31%,2800.17 MHz, CPUID HWMonitor Report ------------------------------------------------------------------------- Binaries ------------------------------------------------------------------------- HWMonitor version 1.1.5.0 Monitoring ------------------------------------------------------------------------- Mainboard Model TA770E (0x00000178 - 0x005C18A0) LPCIO ------------------------------------------------------------------------- LPCIO Vendor ITE LPCIO Model IT8718 LPCIO Vendor ID 0x90 LPCIO Chip ID 0x8718 LPCIO Revision ID 0x5 Config Mode I/O address 0x2E Config Mode LDN 0x4 Config Mode registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 87 18 05 10 00 00 EC 07 C0 88 00 00 1F 00 00 00 30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 0E 80 0E 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00 Register space LPC, base address = 0x0E80 Hardware Monitors ------------------------------------------------------------------------- Hardware monitor ITE IT87 Voltage 0 0.98 Volts [0x3D] (CPU VCORE) Voltage 1 1.14 Volts [0x47] (VIN1) Voltage 2 3.33 Volts [0xD0] (+3.3V) Voltage 3 5.03 Volts [0xBB] (+5V) Voltage 4 12.10 Volts [0xBD] (+12V) Voltage 5 -7.74 Volts [0x79] (-12V) Voltage 6 -4.80 Volts [0x4B] (-5V) Voltage 7 4.92 Volts [0xB7] (+5V VCCH) Voltage 8 3.15 Volts [0xC5] (VBAT) Temperature 0 21°C (69°F) [0x15] (TMPIN0) Temperature 1 31°C (87°F) [0x1F] (TMPIN1) Fan 0 1448 RPM [0x1D2] (FANIN0) Fan 1 1245 RPM [0x21E] (FANIN1) Register space LPC, base address = 0x0E80 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 13 10 00 00 FF FF FF FF FF FF 14 C9 07 D2 1E FF 10 FF FF FF 77 D7 7F 7F 80 01 02 FF FF FF FF FF FF 20 3D 47 D0 BC BD 79 4B B7 C5 14 1F 80 80 0B FE FE 30 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 40 7F 7F 7F 7F 7F 7F 5F 74 2D 40 9C 22 FF FF FF FF 50 FF 03 7F 7F 7F 50 FF 08 90 00 06 12 60 00 00 00 60 7F 7F 7F 00 00 02 FF FF 7F 7F 7F 00 00 62 FF FF 70 0A 14 7F 11 2E 02 FF FF FF FF FF FF FF FF FF FF 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 90 FF 00 00 00 FF 00 00 00 FF FF FF FF FF FF FF FF A0 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Hardware monitor ACPI Temperature 0 31°C (87°F) [0xBE2] (THRM) Hardware monitor AMD Athlon II X2 240 Temperature 0 23°C (73°F) [0xB8] (Core #0) Temperature 1 23°C (73°F) [0xB7] (Core #1) Hardware monitor NVIDIA GeForce 7300 GT Temperature 0 50°C (121°F) (GPU Core) Hardware monitor Maxtor 6Y160M0 Temperature 0 25°C (76°F) [0x19] (Assembly) Hardware monitor WDC WD3200JS-00PDB0 Temperature 0 32°C (89°F) [0x20] (Assembly) Processors ------------------------------------------------------------------------- Number of processors 1 Number of threads 2 APICs ------------------------------------------------------------------------- Processor 0 -- Core 0 -- Thread 0 0 -- Core 1 -- Thread 0 1 Processors Information ------------------------------------------------------------------------- Processor 1 ID = 0 Number of cores 2 (max 4) Number of threads 2 (max 2) Name AMD Athlon II X2 240 Codename Regor Specification AMD Athlon(tm) II X2 240 Processor Package Socket AM3 (939) CPUID F.6.2 Extended CPUID 10.6 Brand ID 13 Core Stepping DA-C2 Technology 45 nm Core Speed 800.1 MHz Multiplier x FSB 4.0 x 200.0 MHz HT Link speed 2000.3 MHz Stock frequency 2800 MHz Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 L1 Data cache 2 x 64 KBytes, 2-way set associative, 64-byte line size L1 Instruction cache 2 x 64 KBytes, 2-way set associative, 64-byte line size L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size FID/VID Control yes FID range 5.0x - 14.0x Max VID 1.350 V P-State FID 0x0C - VID 0x10 P-State FID 0x05 - VID 0x18 P-State FID 0x00 - VID 0x20 P-State FID 0x100 - VID 0x2C Package Type 0x1 Model 40 String 1 0x3 String 2 0x6 Page 0x0 Attached device PCI device at bus 0, device 24, function 0 Attached device PCI device at bus 0, device 24, function 1 Attached device PCI device at bus 0, device 24, function 2 Attached device PCI device at bus 0, device 24, function 3 Attached device PCI device at bus 0, device 24, function 4 Graphic APIs ------------------------------------------------------------------------- API NVIDIA NVAPI API NVIDIA I/O Display Adapters ------------------------------------------------------------------------- Display adapter 0 Manuf. API index 0 Display name \.DISPLAY1 Name NVIDIA GeForce 7300 GT Revision A2 Codename G73 Technology 90 nm PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0) Vendor ID 0x10DE (0x1682) Model ID 0x0393 (0x222A)
  • 58 Answers
These new graphics cards pull a lot of power from the power supply. I know you didn't start off having this issue but given the symptoms you are experiencing I'd take a closer look at the power supply and perhaps replace it with a 650 watt or better.
Posted on Nov 16, 2009
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
Thing to know there is no such thing as a power supply thats gives you full power usally prebuilt pc's have the worst powersupply they can get away with for instance your 450 watt psu is probably only putting out 60% of the 450 so i suggest getting a 650 silver or gold version as they put out 70 and 80% of there power i myself use a 650 gold and it runs a gtx650 16 gig ddr3 an i5 cpu and 3 sata hard drives also a soundblaster recon 3d sound card
Posted on Oct 26, 2016
    Master:
  • 363 Answers
If you want to know more things about RSGold can go to this website www.rsgoldfast.com
Our service is the most professional and most secure and convenient
MSI 760Gm-p23 version 3 Fx Desktop athlon II 640 cpu ,deskstar 500 gig 7200 3.5" sata II 16 MB cache hdd, mushkin 8 gig pc3-10600 essential ram, LG L49-8020 oem sata dvd rom post no issue but wont boo
make sure that the cables are right and are good make sure that the power cables are in the dvd and hard drive two cables to each one for board and one to power supply each
Mar 06, 2013 | MSI 760Gm-p23 Fx Desktop Motherboard Amd...
Greetings. I wanna upgrade my processor from amd sempron 3200+ 1.8 ghz to athlon 2 x2 260 processor. But when I put the athlon 2 x2 260 proc, it didnt work.
Did you check to see if it would handle that type of upgrade? Maybe that's your problem, it's not compatible. Research and see if it can handle it, then we can find a solution if it can.
Jun 03, 2012 | AMD Computers & Internet
Hello there! I wanted to upgrade my ACER ASPIRE T180 Mobo: MCP61M-AM-6A61KE11C-00 I want to upgrade the stock CPU : AMD Athlon(tm) 64 Processor 3800+ Into an AMD Anthlon 64X2. Am2+ socket also...
AM2+ mainboard will mean that you will be able to install AM2 and AM3 CPU's. That includes Athlon 64 X2 and Athlon 2 X2 to X4.
My advice would be to look at an Athlon 2 X2 250 3.0GHz CPU at least. It will be able to run on DDR2 or DDR3 RAM, it depends which socket you install it in. AM2+ is DDR2 and AM3 is DDR3.
Try and get an AM3 mainboard if you can it is worth it, ASUS is good. However then you may need new RAM. You may want a new Graphics card as well. Go to a computer store or use the net to look around and learn more about the AMD computer. Computer stores build special gaming computers, very good looking and great performers. It all depends on your budget.
Take care and Happy Gaming!
damnor01
Jun 13, 2011 | Acer Aspire™ T180 PC Desktop
Id like to buy a msi nf725gtm-p31 mobo but am unsure if it supports am2 processors and ddr2 can u pls advice thanks
Here are the specs of the motherboard, both answers to your questions are "Yes". Happy purchase and have fun with it !
CPU
• Support socket AM2 for AMD® Athlon 64/Athlon 64X2 CPU / AM2+ for AMD® Phenom CPU / AM3 for AMD® Phenom II / Athlon II CPU . (95W only)
Please refer to CPU Support for compatible CPU; the above description is for reference only.
bult_ar_org.gifHyper Transport Bus
• HyperTransport 1.0 supporting speed up to 1000MT/s
bult_ar_org.gifChipset
NVIDIA® nForce 630a & GeForce 7025 chipset
bult_ar_org.gifMain Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
bult_ar_org.gifSlots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
bult_ar_org.gifOn-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
bult_ar_org.gifOn-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
bult_ar_org.gifRAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
May 12, 2011 | Computers & Internet
Got a A780L3L mobo,, AMD Athlon II X4 645 AM3, 4GB DDR3 1333MHZ and nothing else. will not boot. error beeps, 1 every 4-5 seconds. can you help please?
this beep mean A video error has occurred and the BIOS cannot intialize the video screen to display any additional information, check your monitor to VGA port??if all ok this mean
you need to place PCI VGA CARD for change your ON BOARD VGA card that was error
i hope this helpful
thank you for using fixya
Feb 03, 2011 | Biostar A780L3L AMD 760G Socket AM3 mATX...
2 GB DDR2 on Gigabyte GA-MA78GM-US2H Motherboard
Hello
That's normal condition. Probably your RAM shares it's capacity with internal video card (which uses the whole 256MB)
More info can be found on Wikipedia:
http://en.wikipedia.org/wiki/Shared_Memory_Architecture
Jan 25, 2010 | Gigabyte Computers & Internet
Computer crashes when playing games
you have ruled out the video card
and since cooling does not seem to be an issue on you cpu, your next step is to switch your power supply
after that one is ruled out,
your next replacement is your motherboard.
good luck man!
Nov 16, 2009 | Computers & Internet
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
303 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
