Question about GE Cafe C2S980SEMSS Stainless Steel Dual Fuel Kitchen Range
GE CAFE dishwasher was installed and I can see the hindge at the bottom of the door. Can it be installed deeper in the cabnit
  • 1,998 Answers
If it was installed correctly you should only be able to see the hinge uif you were looking at it on a downward diagonal
Posted on May 16, 2010
Asko 5152 dishwasher door "clunks" when opening and closing. What is that?
Probably nothing serious, but something is slipinga or catching on the door hindge.
Dec 11, 2014 | Asko Dishwashers
GE Adora dishwasher model ddt575smf0es leaking from condensation
Sounds like a poor install. If the hoses aren't collected correctly heat from water could cause expansion therefore looser doors and hinges. Make sure the water connections are tight and then check the screws at the bottom of the door. you shouldn't need a pro to fix.
Feb 25, 2014 | GE Adora GHDA654LBG Dishwasher
Smart dispenser
You need to take the door apart and check the valve at the reservoir to see if it is sticking open. You should be able to clean it out. IT could be that the circuit controlling that has leakage though and the valve is not closing all the way.
May 19, 2013 | Dishwashers
How do I remove a Whirlpool 7560/1 dishwasher from its cabinet. It seems to be screwed in at the sides.
If you look under the cabnit where the door is there is usually 2 screws that hold a dishwasher in so look under the counter top. Hope that helps
Feb 28, 2013 | Whirlpool Dishwashers
Remove and reinstall left door (ice/water)
two or three bolts at top of door hindge loosen door should lift off tube at bottom has release cupler.
Jan 30, 2011 | GE GSH22JFZWW Side by Side Refrirator
Door will not close
Did you take the door off (moving or new purchase) to bring in the house? if you did then you didnt put the door on correctly. never heard of a door go from fine one day to not closing. take door off and make if the bushing is still on the bottom hindge. re attached door in close position.
Mar 27, 2010 | GE Profile PSW26P Stainless Steel Side by...
Leaking at the bottom of a GE dishwasher
If it's under a year old, it's under warranty, just call 1-800-GECARES and they'll send someone out to replace the door gasket. If it is over a year old, you need to replace the door gasket. There are small black lines that extend beneath the door into the body of the dishwasher that will be replaced when you install the new gasket. This will seal the door so that you no longer have anymore leaks.
Jul 11, 2009 | GE Dishwashers
Ldf8812st lg dishwasher leaking from front door
Thank you for the update. The retrofit kit will probably not only fix your leak but also dry your dishes much better.
I hope the info I provided was useful. Can you take a moment to rate my level of helpfulness?
Mar 31, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
GE Cafe C2S980SEMSS Stainless Steel Dual Fuel Kitchen Range Logo
186 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
