Question about Microsoft Xbox 360 Console
I have 3 flashing red lights on the console and a yellow light on the power supply
  • 281 Answers
3 red flashing lights is known as the red ring of death. Your power supply showing a yellow light is ok, that just means that your power supply is on standby. The first thing you should do is check with microsoft to see if your unit is still under warranty with this site: http://support.xbox.com/support/en/us/xbox360/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/xbox360/registerdevice.aspx?step=repair
If your unit is not under warranty, go to www.wiredextreme.com. We are a console repair company based in Texas, and we can fix your console. We give a free diagnoses on your unit(excluding shipping), and will call with an estimate before any work is done on the unit. All our work is covered by a 90 day warranty, and you can buy up to 4 years worth of warranty coverage.
Posted on Nov 16, 2009
  • 975 Answers
Well you're either in luck, or in deep trouble. If you have bought your xbox 360 within 3 years, you have a special warranty provided by Microsoft. Call them or go to their support site, and list the problem as having three red light flashing. IMPORTANT it has to have 3 red flashing lights, with only the top right not flashing to have the warranty. They will send instructions and a box, and you just have to wait
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
When i turn on the ps3 it shuts back off imediatly flashes blue then yellow then the red light flashes
Power Supply going bad Or RSX chip separating from motherboard Dreaded YLOD yellow light of death Solutions You tube Fix it yourself or send it off to Sony for them to Fix
Jul 30, 2010 | Sony Playstation 3 (PS3) Console
3 red lights and yellow power supply light
at the very least the main board is acting flaky with the 3 red lights flashing. Here is tutorial courtesy of LLAMA to show how to resolve that problem:
http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm
As far as the yellow light on the power supply is concerned. Unhook it from the Xbox 360 and only plug it into a power outlet. If the light is yellow then the power supply is bad. If the light stays green then plug it into the xbox 360, if it tells yellow then, at that point you know that the main board is causing the yellow light on the power supply and that means the main board is bad.
Aug 03, 2009 | Microsoft Xbox 360 Console
From standby PS3 wont turn on.
that sounds like your main power supply unit
May 28, 2009 | Sony Playstation 3 (PS3) Console
I have a Yellow Led light on power bar, xbox will not turn on
Here ya go! This should help you out, I have also had this happen to me. Don't worry, its nothing like the red circle of death.
http://xbox-360-problems-fix.blogspot.com/2007/11/xbox-indicator-lights.html
Hope this helps you out! Don't forget to rate me :)
Apr 09, 2009 | Microsoft Xbox 360 Console
RED RING WHEN TURNED ON OFF FOR A WEEK
SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Nov 26, 2008 | Microsoft Xbox 360 Console
Three red lights
Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE: The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION: If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 08, 2008 | Video Game Consoles & Games
Three flashing red lights on xbox 360 console
Wow, 4th? That's horrible! Hopefully the following helps you out! SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 05, 2008 | Microsoft Xbox 360 Console
Three red lights on my xbox 360
SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top
CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top
Sep 05, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
186 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
