Question about Sony CDX-L480X CD Player
Sony CDX-L480X Hi, The other day I noticed that it was possible to plug a AUX lead into the back of my unit, upon trying this I plugged everything in and then plugged the jack into the iPod...I managed to get a small amount of sound but when trying to turn it up I get nothing just the same old quite sound does anyone know the reason? Am I doing something wrong? Please help. Thanks Paul.
Posted on Feb 14, 2008
    Problem Solver:
  • 13 Answers
In the main menu there should be an option to turn up the aux sound which will increase the vol on that and nothing else but when you turn up the main vol it should be the same?just remember to turn it down a bit before changing modes?
hope this helps?
Posted on Mar 08, 2008
I have a Sony CDX L480x fitted in my car, this radio has worked fine since i got the car, unfortunatly when i put the face back on it the other day, none of the buttons will work, volume, source...etc. All...
It sounds like the volume button may be jammed or the volume up switch may be bad. If the switch is open just enough to let some voltage through it locks up the microprocessor. Unless you have a multimeter and know how to check resistance on a switch you would be better having a professional repair person check it out.
Sep 29, 2011 | Sony CDX-L480X CD Player
I would like to fit the cdx-L480X into my caravan
ok that will work fine please tell me what the problem is genrally if ir caravan had a tape player the plug should be the same as this unit uses a uni plug if not there will be a converter for under 5 pounds
Jan 19, 2011 | Sony CDX-L480X CD Player
Hello! My Sony CDX-L480X car radio can't read the CD-s. Could somebody help me to solve the problem?
Please try to put in an ordinary audio CD track and see if this is detected. If yes the optical is working, if not there is no laser scanning ,then the possibility of the head being faulty is high.
Now certain cleaner disks are not read and so will not be tracked. Hence it could reject but the best is do a cleaning manually of the laser head eye with a cotton bud very softly and without any pressing of the lens eye.
If there is still no result then watch the CD if it spins or tries to spin. If the head unit moves up or down to focus or in and out of the drive, if so the board seems to work correctly and the possibility of the optical head being the suspected fault is closer.
But if any of the above seems otherwise we must recheck with possibilities of the processor board
Nov 27, 2010 | Sony CDX-L480X CD Player
Sony cdx f5700 wiring diagram needed as aftermarket plug does not match color codes of manufacturer: need to know which of the sixteen pin plug are power, groung and aux wiring.
aux should be 2 point cuming off wive the wires or on the back ov the cd player and red and yellow needs 2 be touching for you live and you earth is the thickest black wire if that dont work then try the fuses
Mar 09, 2010 | Sony CDX-F5700 CD Player
Sony CDX-CA810X / CD-playback drops aux amplifier
Do you have the remote turn on lead hooked up to solid blue wire from the back of the deck? Your amp shoild be hooked up to Bluw w/ white strip as the solid blue wire shuts off when the tuner is off, its used only for the power antenna.
Use Blu w/ Wht strip for amps
Jun 03, 2009 | Sony CDX-CA810X CD Player
No instructions on tuning radio
The Manual is downloadable from Sony at
May 19, 2009 | Sony CDX-L480X CD Player
Aux input for sony car stereo (cdx c 5000r)
For Sony Stereos, you will need to get what is called a Bus Converter. The RCA ports you are trying to use are for a CD changer or alternate device like satellite or HD radio, and those have to have some sort of frequency signal to even be selected. You can find a Bus Converter that will allow you to use this as an Auxiliary input. The device you are looking for is called a Sony XA 300, and it will allow you Two extra Aux Inputs, I believe.
Jan 24, 2009 | Car Audio & Video
Sony CDX-L480X CD Player Logo
266 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
