Question about Apple iPod classic MP3 Player
How to fix the ipod i plug it in and it doesn't show up on itunes
  • 57 Answers
SOURCE: Why my iPod doesn?t appear in iTunes?
For Mac users "iPod does not appear in iPod Updater or iTunes in Mac OS X Under some circumstances, iPod appears in the Finder in Mac OS X, but does not appear in the iTunes Source list or does not appear in the iPod Updater. Symptom iPod's disk icon appears in the Finder, but it does not appear in the iTunes Source list or in the iPod Updater. Note: The iPod may appear in iTunes, but not in the iPod Updater. Important: If you are using iPod shuffle, you must have 10.2.8 or 10.3.4 or later to connect it to your Mac over USB. Other iPods require 10.3.4 or later Products affected Mac OS X iPod (5 GB) iPod (10 GB) iPod (touch wheel) iPod (dock connector) iPod mini - USB requires Mac OS X 10.3.4 or later. iPod mini (Second Generation) - USB requires Mac OS X 10.3.4 or later. iPod (Click Wheel) - USB requires Mac OS X 10.3.4 or later. iPod with color display (including iPod photo) iPod nano Solution iPod nano Certain models of single processor Power Macintosh G5 computers may show iPod nano mounted in the Finder but not recognized in iTunes. If this happens to you, try restarting your computer and Setting Energy Saver to highest performance and turn off hard disk sleep. If you have an iPod nano, but don't have a G5, then follow the other steps below. Mac OS X 10.4.x Perform an archive installation of Mac OS X10.4. Mac OS X 10.3.x Navigate to /System/Library/Extensions. Drag the iPodDriver.kext file to the Trash (you will be required to enter an administrator account password). Download and install the Mac OS X Combined Update 10.3.9. Restart the computer when prompted to do so by the installer. Connect the iPod. Mac OS X 10.2.8 and earlier To resolve this issue with earlier versions of Mac OS X, you'll need to delete one file and reinstall iTunes. Follow each of the steps below. Step 1 Delete the file using Terminal Warning: The steps below describe how to remove a file by entering commands in the Terminal application (located in the Utilities folder inside of the Applications folder). Users unfamiliar with Terminal and UNIX-like environments should proceed with caution. The entry of incorrect commands may result in data loss or unusable system software. Open Terminal (/Applications/Utilities). Type: sudo rm -R /System/Library/Extensions/iPodDriver.kext Press Return. Enter the administrator account password when prompted. Quit Terminal. Restart the computer (From the Apple menu, choose Restart). Step 2 Reinstall iTunes Download the latest version of iTunes from the iTunes download page. Install iTunes. Restart the computer after the installation has completed. Connect iPod. Step 3 Delete the iPod.plist file Remove the following file in the your home directory and launch the iPod updater again ~/Library/Preferences/com.apple.ipod.plist "
Posted on Sep 28, 2005
bizelski
  • 118 Answers
SOURCE: Ipod wont show up in my computer or itunes...
Hold the centre button and the menu button
Will reset. hypothetically fixing it
Posted on Oct 10, 2008
mneilsen2084
  • 342 Answers
SOURCE: iPod won't show up in iTunes
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
How to restore iPod (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Posted on Jun 02, 2009
anujtaluka
  • 392 Answers
SOURCE: When i plug my ipod touch into the computer this comes up..HELPP
Try restoring it...here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
Posted on Sep 06, 2009
  • 57 Answers
okey ! i guess there are two reasons for this possibly:
1.the itunes u're using now is not compatible with ur ipod, u may needdownload a suitable edition for ur ipod from apple official website;
2.there may be some vices about connector plugs of ur ipod,replace it and have a try again.
In addition, if you wanna view DVD movies on ur ipod nano , check outDaniusoft DVD to IPod converter which can help you converter DVD(including protected by CSS) to ur ipod nano>>>
http://www.convert-video-dvd.com/dvd-to-ipod-converter.html#135
GL my friend !
Posted on Sep 11, 2009
Ipod will not show up on itunes
1. Reset or restore your iPod for a try, this can fix many general iPod problems. 2. You may try this iTunes alternative, I always use it to upload music and video to my iPod once my iTunes can't recognize my iPod, my friends recommend it to me, it's safe and works pretty well, you can also use it to copy music and video from ipod to computer for backup, it's useful when you lost your iTunes library. http://www.ipod-transfer-copy.com/ipod-iphone-to-computer-transfer-cucusoft.html 3. Upgrade or re-install iTunes for a try, this is the method that I got from Apple technical support. Hope it helps. Contact me if you have any other question.
Mar 05, 2010 | Apple iPod nano
I plug my ipod into the usb plug in and it wont show up in itunes so i cannot update it or add new songs and playlist. it shows the charging symbol but will not show up in itunes
1. Try another USB cord or USB cable. 2. Restrart your computer for a try.
3. Reset or restore your iPod for a try, this way can fix many general iPod problems. If you don't know how to do that, you may refer to this iPod tips
http://www.mac-dvd.com/ipod-tips-and-ipod-faq.html
4. Download and install the latest version fo iTunes for a try.
5. You may try this iPod transfer, it's a nice iTunes alternative that can help you upload music and video to iPod, I always use it to sync my iPod when my iTunes can't recognize my iPod, it's easy to use and works pretty well
If you have any other questions, feel free to email me.
Jan 30, 2010 | Apple iPod nano
My Ipod not coming up on itunes when it's plugged in
1. Reset or restore your iPod for a try, this can fix many general iPod problems. 2. Upgrade or re-install iTunes for a try, this is the method that I got from Apple technical support. 3. You may try this iTunes alternative, I always use it to upload music and video to my iPod once my iTunes can't recognize my iPod, my friends recommend it to me, it's easy to use and works pretty well, you can also use it to copy music and video from ipod to computer, it's useful when you lost your iTunes library. http://www.ipod-transfer-copy.com/ipod-iphone-to-computer-transfer-cucusoft.html
Hope it helps.
Sep 06, 2009 | Apple iPod nano
Unistall ITunes and all Ipod Software.
Remove Ipod for the computer.
Reinstall all software. Make sure ITunes is updated to the current version.
Aug 16, 2008 | Apple iPod nano
PLEASE HELP! CANT UPLOAD MUSIC TO MY IPOD!!!!!!!!
uninstall itunes then reinstall it. if that won't fix it uninstall itunes then install winamp (http://www.winamp.com/download).
if that still doesn't fix it restart your ipod (visit apple support for instructions).
Jul 17, 2008 | Apple iPod nano
Settings/content pane in itunes for adding songs does not show up
The 5 Rs: Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with iPod shuffle. Try
these steps one at a time until the problem is resolved. If one of the following doesn’t
help, read on for solutions to specific problems.
â Reset iPod shuffle by turning it off, waiting five seconds, and then turning it back on
again.
â Retry with a different USB port if you cannot see iPod shuffle in iTunes.
â Restart your computer, and make sure you have the latest software updates
installed.
â Reinstall iTunes software from the latest version on the web.
â Restore iPod shuffle. See “Updating and Restoring iPod shuffle Software” on
page 26.
Jul 16, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Ipod wont show up on itunes
Try the five r's:
These are for Nano, but they apply to all iPods:
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
Jun 14, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod 1st generation doesnt show up on itunes & wont restore
Do the 5 R's:
installed.
May 12, 2008 | Apple iPod nano
you might have already tried this, but just to eliminate the obvious
1. download and install the latest version of itunes
2. unplug everything
3. restart computer and restart ipod
4. plug back in and see what happens
Feb 08, 2008 | Apple iPod nano
Okay, I had a similar problem with a 5th Gen 30GB, and I stumbled upon a solution that I have not seen anywhere else.
Basically, my iPod was mounting as a disk drive, but would not show up in iTunes. I reset it many times and ran the diagnostics (left and center upon Apple logo at startup). Nothing worked, and of course I couldn't restore it, because it wouldn't show up in iTunes. It did the same thing regardless of what PC or Mac it was plugged into -- it always mounted, but never showed up in iTunes.
Another odd observation was that it was mounting on my Mac desktop with the "external hard drive" icon, not with an iPod icon.
Here is what I did that fixed it:
1. Plugged it in to a Mac. 2. Opened a Terminal session 3. Browsed to the /Volumes/iPod/iPod_Control/ folder 4. Renamed the iTunes sub-folder to iTunes.backup 5. Ejected the iPod, then re-connected it
At this point, iTunes detected my iPod just fine! I went through the restore procedure as a precaution; because I have no idea what this directory really contains.
I realize that the circumstances surrounding my successful restore are somewhat unique, and probably don't apply to very many other situations, which is why I described some of the quirky things (like the icon showing up as an external hard drive) in detail at the beginning of this. Don't attempt it if you're not comfortable with what I described, or if your iPod has different symptoms!
Dec 24, 2006 | Apple iPod nano
Apple iPod classic MP3 Player Logo
60 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
