Question about HP PSC 1210 All-In-One InkJet Printer
C4400 scanner printer will not scan to pc.
H.p.
c4400 scanner printer will not scan to pc.i can scan to the printer but not to the pc. i reinstalled my software and still no difference.
    President:
  • HP Master
  • 2,017 Answers
Kindly uninstall the printer driver and software restart the system and don’t connect the usb cable 1st install the driver cd and when it prompt you for connect the usb cable then connect it and follow the instruction. It will resolve your problem.also change the usb cable and the usb port.
Posted on Nov 17, 2009
My printer has new carthridges prints from computer but does not make copies
Try scanning from MS Paint or Acrobat & see if it works. If it does, the HP/Vista software is probably at fault. If not, the scanner is probably faulty.
Did it ever work or did you just plug it in? (Did you load the correct drivers?)
Apr 22, 2014 | HP Photosmart C4400 series
When i try to use scan mode it wont scan
Try a different USB port. If you have it plugged into the back of the pc, move it to the front, or vice versa.
Reinstalled drivers from Canon website still no go but you can go to Control Panel, select "Scanners and Cameras" and you should see your Canon scanner there. You can scan from there and use the scanning wizard.
You can try using ACDSee Pro to import image from scanner. It works ! or you can try other softwares too !
Feb 18, 2012 | Canon PIXMA MX310 All-In-One Printer
KODAK ESP 3200 SERIES WILL NOT SCAN
I had the same problems; missing Icon and 100-2105.
This solution on the Kodak web site solved my problem.
http://support.en.kodak.com/app/answers/detail/a_id/1276/kw/ERROR:%20100-2105/selected/true
From your computer desktop, select Start > Run.
Type %windir%, then click OK.
Double-click the twain_32 folder.
Right-click the kodak folder, then select Delete.
Insert the KODAK All-in-One Printer Software CD into the CD drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
Double-click aioscannr.msi, then follow the instructions to remove it.
Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
Start Home Center Software.
Select Scan Documents and Pictures.
Scan a document.
If the error continues using a Wi-Fi connection, make sure you select the correct printer in Home Center Software.
If the error continues using a USB connection, see the following section to reinstall the printer.
Jan 13, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
Keep getting error message 100-2105 when I try to scan
I had the same problem. The icon disappeared. Then the 100-2105 error message came up.
The solution on the kodak web site worked for me.
From
Scan a document.
Sep 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
When I press the scan button, the error USB not connected appears even though it is connected.
You will need to install the software that came with the printer on the computer that it is connected to. The software will then run on the computer and "listen" for a command when you press the scan button. What is the make/model of your printer?
Feb 28, 2011 | Computers & Internet
I keep getting error message for my scanner it worked in Windows XP and now it will not run in Windows 7 I can't afford a new printer It is a Hp Photosmart all in one C4400 series the software is...
There are 9 different HP Photosmart C4400 All-In-One devices. The Windows 7 driver is available on HP website [www.hp.com]. Select "Software & Driver Downloads". If you are running Windows 7 you will need to select either the 32bit or 64bit driver. If you are still having problems, write back. -- SWT
Aug 22, 2010 | Office Equipment & Supplies
Trying to scan pics on HP Officejet 7110. Press 'Start Scan,; display on printer shows 'Scanning to Microsoft Outlook' for over one minute. I can hear the machine scanning and see the scan light working....
Nothing in or jamming document feeder tray.
Change the setup to scan to a file, rather than email.
Reboot all.
Reinstall printer/scanner drivers and software.
Nov 17, 2009 | HP Officejet 6310 All-In-One InkJet...
Hp photosmart 2610xi does not scan.
Remove all hp software and drivers from control panel>add remove programs. Then go to control panel>system and go to hardware and then device manager, then delete your printer/scanner from the list by right clicking and 'uninstall'. Then restart, and make sure you printer/scanner is unplugged and off. Then once your computer restarts go to hp's website and make sure you selected the right country (at the top), then go to support & drivers and download the software/drivers that are for your printer/scanner. Once drivers/software is install, then connect printer (or follow installation instructions, if different)
Also, just to make sure, plug it in a different USB port (after the reinstallation) incase the old drivers are stuck on the computer somewhere. Drivers usually/sometimes are associated with a specific usb port and will reinstall when plugged in a different port.
Mar 07, 2009 | HP Photosmart 2610xi All-In-One InkJet...
My scanner won't work. When I push the Scan/Reprint button and tell it to scan to the computer, it says it is scanning for a little while and then says "Scan error. Try scan from computer or see...
look dor the hp imaging solution on the bottom of your computer screen. Click on it and when the screen come up clip on the button that is closest to what you are trying to do.
Dec 05, 2008 | HP PhotoSmart C4480 All-in-One Printer ...
Scanner not set up
Have to uninstall and reinstall full software solution. First uninstall using the hp program, then use add/remove program uninstall Image zone, extended capabillities and HP update, restart pc and search for scrubber in Hp software it's in utility folder, ccc, doubleclick it to work. then you are ready to reinstall the fully software.
Nov 17, 2008 | HP LaserJet 3050 All-In-One Printer
HP PSC 1210 All-In-One InkJet Printer Logo
656 people viewed this question
Seeker5211
Seeker5211
