Question about Nokia 7360 Cellular Phone
How can i fix my connection settings because my phone only has a signal on only one sim but when i inserted other kind of sim card it has no signal how do i fix it?
Insert sim card is found in low signal
First:
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Second:
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Jan 12, 2013 | Samsung GT C5130 Mobile
Why I don't have network signal on my nokia 6600?
If you are not getting any network from your phone it my be be due to:* sim card issues* network / outage issues* phone issues
SIM Card issues:1. turn off mobile phone2. remove battery3. remove SIM card and memory card4. clean the SIM card from any dirt or dust5. wait for 2 minutes then plug back battery6. insert memory card and SIM card properly7. turn on mobile phone8. check if you will be provided with a signal from the upper right corner of your phone's screen. if not, try a different SIM card.
Outage:1. call your service provider and confirm if there are outages in the area or outages from the BTS where your SIM card is registered.
Phone Issues:1. if the phone is open line, try to enter a different SIM card2. try to insert the SIM card into a different phone, check if it will be provided with a signal3. if the second phone still dont get any signal and your service provider stated that there is no outage that may affect signal issues from your phone, check it from them if your sim card is still active.4. last resort is asking for a SIM replacement with the same phone number
Dec 11, 2011 | Nokia 6600
How to switch from offline to online
Offline mode only appears if the mobile phone is not getting the signal from its service provider.
*make sure that the sim is properly connected*reseat the sim card from the mobile phone*check account status for signal and connection availability*power cycle mobile phone
1. turn off mobile phone2. remove phone battery3. remove memory card4. remove sim card5. wait for 2 minutes before plugging back anything6. after 2 minutes, plug back battery7. insert memory card properly8. insert sim card properly s well, make sure that the sim is not dirty as well9. turn on mobile phone10. check the signal bar, it should be with signal this time and not offline
*after power cycling, phone should be working properly now unless the sim card is really faulty. you check if its faulty by calling your mobile service provider*
Dec 10, 2011 | Nokia E75 Cell Phone
Want to change my sim card in my phone , but when i insert the sim card the phone does not recognise it and says to insert sim card
Hello there,
If your phone is not accepting any other sim card, then it means the phone is sim card secured lock or protected, there are some phones that do not accept any other kind of sim card apart from that which they are made for.
For instance a phone made for vodafone purposes cannot accept etisalat sim cards, it will only accept vodafone sim card. Therefore that is what you are facing with the phone.
Take not, if you insert similar kind of sim you were iniially using, it will accept it.
That is why you cannot use another kind of sim on the phone.
Thank you for using fixya Caseytech
Jul 05, 2011 | Samsung Cell Phones
No internet connection
Problems that can cause this problem are :
- gprs and wap configuration was not right or not activated. Some provider of SIM card require activation via message to send activation setting to your phone. After this activation, phone usually can connect to internet automatically.
Some of SIM card will configure this setting automatically after put in a phone, but other SIM card need manual configuration. Make sure you've configure internet connection in your phone properly.
- another problem is signal strenght or continuity. If you make a connection in closed building or other place with low signal, you may can't connect to the internet.
Hope this help and be kind to rate please, thank you
(^_^)
Jan 07, 2011 | Nokia 5230 Cell Phone
My samsung tocco has full signal but screen shows sos calls
its because of sim card error please insert some other sim card and on it for at least 5 hour once mobile frequency clock will set to new sim card then re insert old sim card it will take effect 100 %
Dec 18, 2010 | Cell Phones
Password to delete all contacts from phone
You might need your phone's security code to do that! But I guess you forgot the code? Nothing to worry though, you can try these steps below:
  1. Turn off the handset and remove the SIM card.
  2. Turn on the handset WITHOUT the SIM card.
  3. At the Insert SIM card screen, enter *2767*2878# (that is, star 2767 star 2878 pound).
    If fails please try code *2767*3855# (that is, star 2767 star 3855 pound).
    • NOTE: The handset now resets to factory settings. This erases all downloaded content as well as pictures, text messages, and phone book entries that are saved to the handset.
  4. The handset automatically turns itself off and then back on, and then it returns to the Insert SIM card screen.
  5. Turn off the handset and insert the SIM card.
  6. Turn on the handset.
    • NOTE: It may take about one minute for the handset to find a signal after this procedure. After it finds a signal, the handset should then function as expected with the security code set back to default (00000000 8 zeros).
  7. Or if the steps above didn't work, try visiting this link
Aug 10, 2010 | Samsung Star GT-S5233 Cell Phone
No network coverage
Phone is not receiving any radio signal / received signal is too weak:
Confirm that network coverage is available where you are by contacting your service provider.
SIM card is not working properly:
Insert your SIM card into another phone
Note: Contact your service provider if you get the same message again.
Phone is not working properly:
Insert your SIM card into another phone. If the second phone works with the inserted SIM card, then
the problem is probably with the first instrument.
Note: In this case, contact your nearest Sony Ericsson service center regarding your phone problem.
May 30, 2010 | Sony Ericsson Walkman® W995 Cell Phone
"Insert SIM card" Prompt message
Hello
To avoid this kind of problem from recurring;
Make sure your Sim card is properly inserted
Make sure you avoid hitting the phone on objects and also avoid dropping the phone because this can make the Sim card shift out of place
Goodluck
Feb 19, 2010 | Sony Ericsson Aino Cell Phone
Ive inserted a vodafone sim card in sciphone, phone sayn insert sim. also why is there 2 sim card slots?
This is called Dual sim phone. Go to settings and make sure that the Dual Sim is enable. Whe a phone state "Insert Sim" after inserting the sim card, it is most probably that you had inserted the sim the wrong way, so that the gold connectors is not connecting with the phone. Invert the sim card and try. If the problem persist, try the other sim slot.
Dec 16, 2009 | Lands Phones
Nokia 7360 Cellular Phone Logo
81 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
