Question about Avermedia QUICKPLAY (pquickplay)
AveMedia The AverKey turns the monitor screen when it is connected. How do I correct this problem?
Averkey lite I work with xp ok.but I opperating vista now I cant on my tv screen.
Posted on Apr 20, 2008
Cpu on but no video no beeps
There is likely a hardware-error.
1) Did you connect all powerconnectors correctly to the motherboard ?
2) Same question for attached internal hardware ?
3) Memory modules inserted correctly ?
If all OK, it's seems you PC is correctly booting and running succesfully an operting system like Windows.
Now, the error might occur something between monitor and PC.
4) Did you recently change the screensettings under Windows ?
If your monitor can run max. 1024x768-mode, but you accidentally fiddled with Windows-settings, to set it into 1200x900-mode, your monitor will turn black, not showing anything of Windows. In panic you might have turned of your computer. To solve this, it's best to push the F5-key when booting in Windows safe-mode. Here you can restore the older screen-setting.
5) No damage at pins of connectors between monitor and PC ?
6) Cable between monitor and PC connected correctly ?
If all OK :
7) Does monitor power on ?
Yes. Shortly but turns off within seconds (for TFT-monitors)
- Something at inverter-level is damaged. This is inside the monitor.
No. monitorLED is not even turning on
- Monitor has an internal defect
Oct 14, 2013 | Computers & Internet
My computer is on.. but my screen wont turn on . The red light on the botton of screen is blinking and it says DIGITAL POWER SAVING MODE on the screen. how do i make my monitor work ! (:
When the monitor detects no input "signal", it goes to "sleep", to consume less power.
Check that the "data" cable is securely connected to both the monitor and the VGA-output on the back of your computer.
Or, try connecting the monitor to a different computer, to see if the monitor works at all.
Or, try connecting a different monitor to your computer, to see if your computer's video-card is working correctly.
Oct 24, 2010 | LG Computers & Internet
Black screen
Make sure power connection is connected and has power.
Make sure video cable is connected to the correct input.
Make sure you select the correct input source on the monitor menu.
Make sure you computer is on, has the correct video drivers and screen resolution.
If all this is good then have the monitor serviced or replace it.
Good luck
Oct 12, 2010 | ViewSonic VA1930WM LCD Monitor
I see a black screen when I turn thw computer on
The first thing to do is to check the lead from the monitor to the computer is correctly plugged in at both ends.
If this is OK then perhaps you try another monitor, if an other monitor works OK then yours may be broken.
If another monitor does not work then you will need to check your computer hardware and software.
Oct 30, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
I whant driver averkey plus v5.20 work whit
send request to need_software@ymail.com
Aug 25, 2009 | Televison & Video
Averkey
Unit powers up but will not show a picture on the TV. Was working previous day. I have check all cords and even replaced them with ones from another averkey but still no picture.
Apr 02, 2008 | Avermedia AVerKey Plus (AVERKEY-PC)
BLACK AND WHITE PICTURE
Verify that your region setting is correct, ie USA is NTSC.
Please let me know if this works for you.
thanks
Jan 18, 2008 | Avermedia AVerKey iMicro (58686)
AverKey3 Plus
Hi, sorry to tell you this, but static electricity has killed every conceivevable type of electronic device ever built by man or woman. The insides of your TV has very high voltage and the only safe solution is to take it to a repair man. Ask for a qoute before any work is done, try to get at least 2 quotes.
It may be cheaper to replace than repair the unit and with 2 quotes you will know that you are not being conned.
Regards mistyman
Oct 09, 2007 | Avermedia AVerKey Plus (AVERKEY-PC)
Avermedia Averkey lite - Monitor Colour Display Issue
I had the same problem. I was going from PC -> Dvd recorder -> TV.
I had the S-Video output from the averkey going via an adaptor into the DVD scart input. I discovered a setting within the DVD menu which could select between 's-video' and 'composite video' on the scart socket. (it appears that scart can carry either/or, I guess).
I changed from composite to s-video, and I got colour.
I think seeing a greyscale image indicates that the signal being sent is S-Video, but the equipment that is recieving it is expecting composite video.
Sep 23, 2007 | Avermedia QUICKPLAY (pquickplay)
Avermedia QUICKPLAY (pquickplay) Logo
160 people viewed this question
Top Avermedia Televison & Video Experts
Alun Cox
Are you an Avermedia Televison and Video Expert? Answer questions, earn points and help others
