Question about Mitsubishi PD-5010 50 in. Plasma Television
Misubishi pd-5010 plasma monitor. vertical stripes. 6 yrs old.
Misubishi pd-5010 plasma monitor. 2 vertical black stripes. One from top, one from bottom. Reach to mid-screen.
Both appeared in the last 2 weeks.
Heared crackling / pop and then vertical stripe appeared.
Stripe is 12" tall, inch wide.
Am I dead?
  • 1 more comment
  • bob_myrick Nov 16, 2009
    misubishi pd-5010 plasma monitor. 2 vertical black stripes. One from top, one from bottom. Reach to mid-screen. Both appeared in the last 2 weeks. Heared crackling / pop and then vertical stripe appeared. Stripe is 12" tall, inch wide. Am I dead?
    thanks for a direct, to the point, comon sense answer.
    thanks for a direct, to the point, common sense answer.
    President:
  • Mitsubishi Master
  • 1,114 Answers
Unless the monitor is under warranty, it would be less expensive to replace than repair. Finding a new plasma display panel to replace for the repair would be difficult as well. Sorry for the bad news, however, it is the correct answer.
Posted on Nov 16, 2009
    President:
  • 1,462 Answers
Press the menu on the TV and see whether the menu is effected. If the Menu if effected, then this can be in your video cable or Plasma Connector issue. but most problem is in the flex cable of Plasma. some other cases cannot be fix and replace new Plasma Screen
Please try the following instruction, to solve your issue:
This problem can be caused by several things,
First i suggest you to look for poor connection between Plasma and ribbon wire connector that connects to the board, just press the connectors firmly and this may solve your issue, if you still have problems then i may be due to any one of the following.
-a connector on logic or address boards(in this case the lines would be localized to a half or less part of screen)
-a defective logic board that do not send the right address pulses to address board;
-a defective address board-but again it will impact only half or less of screen,
There is 60% of chance you will need a new screen. The problem you may have is dead driver (part of a screen).
There is some solution for it but not for long time. PDP panel and address driver on it not separated. If one of 26-40 drivers is going out, you need new screen.
Other common problem with lines on screen -- buffer boards , high ammount of failure for these boards due to poor electronic design ( 1-- voltage needs to operate controllers on buffer board just to high for small SMD IC ,2---they are not strong enough to drive address electrode). In future it will be changed for more reliable parts .
Please leave me comment, if you need furthur assistance
Thanks for using FxYa!
RNJ VINODKUMAR
Pioneer PDP-4300 43" Plasma TV, 1/8 of screen has vertical stripes no picture
Look to see PIP or picture in picture is not engaged as it may be doing this.
Dec 10, 2012 | Pioneer PureVision PDP-4300 43 in. Plasma...
Black Vertical Stripe Our Hitachi plasma TV has just started displaying a vertical black stripe about three inches wide right down the middle of the screen. This stripe comes and goes every hour or so,...
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
Feb 03, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
Excus e me my question is i have mitsubishi pd-5010 and have i vertical line black do you think is to expensive for fixer? thank you for you attention
the problem is v/h collapse this is due to power spike a little like a power surge with the older tvs we used to bin them as the repair was too expensive as with the new tvs lcd/plasma the parts are less to replace and cheaper its always worth getting a quote but it is a reasonably expensive repair
merry christmas
please take time to rank this advice
Dec 22, 2010 | Mitsubishi PD-5010 50 in. Plasma...
I have a samsung HP T5054 plasma tv and today, out of nowhere, a vertical black stripe about 2 inches wide, appeared on the screen. Turning off and restarting does nothing and the scrolling feature to...
There is a possibilty its just a defective address board thats causing the issue. Can yoiu reply to my email address tvtek(at)msn.com with the complete model which will be on the side of the TV. It should be something like HPT5054X/XAA and I also need the serial number. Is the black bar on the left, center or right side of the screen? I need all that information to further assist...
Jun 29, 2010 | Televison & Video
Vertical lines/black squares all throughout this 50" TV. Is it worth fixing?
I have 5 vertical black bars coming down halfway on the screen. Also 1 black square that appears on the lower half corner of the screen. What can I do to get them off? Please respond or call me @(510)938-6237 Shon Thanx!!!
Dec 27, 2009 | Mitsubishi PD-5010 50 in. Plasma...
I have a Mitsubishi PD 5010 plasma tv. I turned it on and it now has these black rectangular boxes on its screen one in the upper right hand side that goes down almost about half way and another in the...
Post a screenshot. If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 19, 2017 | Mitsubishi PD-5010 50 in. Plasma...
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
ViewSonic N1700w with Black stripe on right side of display
Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
Dec 27, 2007 | ViewSonic NextVision N1700w (Black,...
Mitsubishi PD-5010 50 in. Plasma Television Logo
210 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
