Question about LaCie Ethernet Disk (300788) 1000 GB Network Hard Drive
Wireless External HD connection
Ok, problem with Lacie ethernet disk mini external HD 500GB. We just want to be able to plug it in the router and access it through individual computers. Prob is, we just can't seem to find it, even after installing the relevant software and nomination an administrator. Any thoughts? many thanks, j
  • Anonymous Mar 16, 2008
    I have the same problem with the 400Gb model. I can access via a browser using http and its IP address but not see the drive on the Windows network
  • bob814 Jun 21, 2008
    Yep, same problem. Lacie ethernet mini 500Gb disk. iTunes can see it, I can find it using http and explorer, I can use the ftp facility but I can't see through explorer. Useless, about to send it back.
I had the same problem in Vista but it spontaneously resolved itself after some time, but as a temporary solution you can just map to it. Figure out it's IP address and then go to: Start->right click on Network->Map Network Drive...->fill in the Folder field (i.e. \\192.168.1.2 ) and presto you should see the login screen (admin/admin by default). It's not the best but works well enough. Hope that helps.
Posted on Jul 13, 2008
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Blue light come on when plugged into laptop but does not show on laptop
this drive is mainly a Network drive. To use it with the USB, if you have a PC, you will need drivers that can be downloaded from LaCie. If you have a MAC, there are no way to use the drive with USB.
If you have a Router at home, connect the drive to it with an Ethernet cable and then use the LaCie Network Assistant to access it. It is easier.
Regards,
Jan 17, 2011 | LaCie Ethernet Disk mini USB 2.0 External...
Not turning on.... I turned it off to move its location and now i cant turn it on...Power cable and everything is in place and live, but no joy..
Same problem. Bought a new power supply at extortionate price from Lacie but still no joy. I'm hoping to find a way of converting to a dumb external USB HD.
Oct 16, 2010 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Doesn't work
am not so sure if this is a similar issue with iomega2_bing.gif external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link for the solution.
Apr 05, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
When my lacie external hard drive is connected,my
Check your BIOS > StartUp sequence
Maybe the USB boot option has much higher priority that HDD boot. Try exchanging their priority and then reboot, with your external HD connected to pc.
Jan 03, 2010 | LaCie (300951U) 500 GB Hard Drive
XP doesn't recognize 500GB external Lacie after almost 2 years
try it on different usb ports on your system
try replacing the cable which connects the hard drive with the usb port
if this does not works the problem lies in the portable hard drive and i think it would be under warranty period so get it checked
Jul 09, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 500gb external drive
The disks inside the HD are not spining. The creaking noise is the HD trying to start. Next time when it does start transfer all the files ASAP cause your drive is about to die.
rmatheson@wowway.com
Sep 30, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Unable to locate Lacie Ethernet Disk Mini on the network
Lacie's out to lunch..you may be experiencing the old drivers are shot issues..get em from the main site, and reinstall, ok?
Mar 24, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
LaCie Ethernet Disk (300788) 1000 GB Network Hard Drive Logo
297 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
