Question about Bose Acoustic Wave (32022) 5-Disc CD Changer
Bose 5 disk changer will not play or eject cds
5 Suggested Answers
SOURCE: i have a Bose acoustic
I called Bose service. Jason said to unplug for 1minute then plug back in. If the changer does not reboot and operate properly....you call Bose service. They will exchange your cd changer for a new one.
$75 plus tax and return your cd's to you. They will give instructions for the exchange when you call.
Posted on Oct 31, 2008
  • 23 Answers
SOURCE: Bose Wave Music Sys & 3 CD Changer
I have had a few of these come to my shop. The gears jump out of timing causing the cd lift to jam or become unalligned. The unit will probably have to be disassembled to get the CD out or have it serviced.
Posted on Mar 18, 2009
vetteman3002
  • 2299 Answers
SOURCE: The 5 cd changer appears
Have you tried to unplug the unit. And leave it unplugged for about 10 minutes. If it is mechanically jammed this will not help. But if it is the firmware that is scrambled, then this will reset it. If it is mechanically jammed, then you might try tipping the unit on the back, then try ejecting it from that position. I would try clearing the firmware by unplugging and leaving for 10 minutes first.
Posted on Dec 23, 2010
  • 23 Answers
SOURCE: I have a bose wave
Hi, The cd disc is not in his place inside the multichanger, you must open the appliance and try to take out the cd without forcing, otherwise you wil brake the mechanical system,
after this the system will work well.
Thanks.
Posted on Jan 30, 2011
I have a bose wave system. I tried loading cds in the multi changer and kept showing error and never would play. The multi changer still has one of my disc and will not eject. I tried unplugging and...
Thanks.
Jan 30, 2011 | Bose Wave music system Multi-CD Changer...
Bose multi cd changer wont work, reads "Disc error"
I think there may be a problem with the system (defective parts) - I, too, am having this issue. I am going to contact the BBB - maybe if enough of us complain we will get a recall. To file a complaint:
http://www.bbb.org/boston/business-reviews/department-stores/the-tjx-companies-inc-in-framingham-ma-97/
Bose
PO Box 9168
The Mountains
Framingham, MA 01701
Dec 01, 2008 | Bose & Wave& Music System
Can't eject cd from cd changer
hi check and see if there is 12 volt to the cd changer or blown fuse.
Oct 26, 2008 | Bose Lifestyle 20 System
I have a Bose acoustic wave muti-disc changer.i have 5 disk in changer,i cannot eject any disk,& it looks like its hung up on # 5.non of the disk will play. Thank You-
Aug 22, 2008 | Bose Acoustic Wave (32022) 5-Disc CD...
Infiniti's FX-35 Bose 5 Disk CD Changer is totally Jammed.
I HAVE A 2003 INFINITY FX 35, CD CHANGER STOP WORKING,WHEN I TURN THE CAR ON SOUNDS LIKE IT WANTS TO EJECT, IT WONT LOAD NEDER.CD STUCK,CD CHANGER WONT WORK, PLEASE WHAT SHOULD I DO,,HELPPPPPPP. HOW CAN I GET THE CD TO EJECT. OR LOAD...
Mar 25, 2008 | Car Audio & Video
Dec 23, 2007 | Bose Wave music system Multi-CD Changer...
Multi cd bose player will not eject 4th cd.
OK, this problem is everywhere with the bose cd changer addon. Many people can still play a cd with the top one fine, but cannot get cds to eject and/or read in 3 disc changer. My friends mom had one and after finally hearing back from bose, they said send it in with $100 to get fixed. If you have to send in and you value your cds, you may want to open it up and get them out. Use this at your own risk, there are no warranty stickers I saw and there will be exposed voltage, shock hazards, etc.; so if any of this worries you, stop here. By proceeding, you are admitting that you are capable of minor repairs and therefore I'm not responsible for any damage or harm caused. OK, here it is:
Unplug everything. On the bottom of the cd changer unit are 4 screws (silver ones recessed about 3/4" or so, use phillips screwdriver) to remove. Turn unit upright again and lift cover slowly straight up. In the front of the unit is a ribbon cable you will want to disconnect that goes to the cd 2-4 lights. Take note which side the dark blue tab is on and gently pull out by dark blue tab, rocking side to side if needed) You can then pull cover all the way off and set aside. Plug power into back of cd changer (careful not to touch anything inside) and see if the cds want to eject now. If not let the initializing process finish and repeat. This time see if you can gently help the cd out. The problem may also be the spindle not lowering, you can look for this movement during the last step of init. process. Work your way fom the top tray down removing the cds gently, remember we open it up because they were valuable to us, don't destroy them now, and don't ever use anything that could possibly scratch either top or bottom of the cd, use edges instead. Start to replace cover making sure to reattach ribbon cable back into socket the same way it came out. do not force too hard or you may crease and break ribbon. Gently replace cover and grab both top and bottom to turn over. Replace 4 phillips screws making sure not to overtighten or cross-thread. Now you may return to bose or just find an independent repair shop in your area, they are usually quicker, more polite, usually cheaper, and best of all, local!
Dec 15, 2007 | Bose Wave music system Multi-CD Changer...
Bose Acoustic Wave  (32022) 5-Disc CD Changer Logo
123 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
