Question about Mitsubishi WD-62525 62" Rear Projection HDTV
I just bought a used mitsubishi dlp 62525 and it will some times have wavy lines running diagonally on screen and other times it wont, what is the problema dn how do i fix it
Check all reciver connections make sure dish is stable to mounting
Posted on Nov 16, 2009
Wavy lines all over the screen on a 55 in. Mitsubishi DLP 2005 Tv that has intermitent wavy lines around all the edges of the people and edges of the screen. Jerky picture and almost makes you sic...
You probably have a V26 chassis. The only fix to this problem now that parts are no longer available from MITS is to call their Consumer relations dept. at 800-332-2119. If you have a qualified tech come out and estimate the job, Mits will offer you an attractive discount on a new model. To repair your problem would be around $750
Bill W
integrityhomeworx.com
Mar 22, 2011 | Mitsubishi Televison & Video
Scrolling diagonal lines
The cable box signal on the components video have a too high refresh rate frequency, that is the reason for the lines.
Use RCA cables or an alternative connection.
Other solution is changing the display out settings for cable box (from PAL to NTSC etc.)
Sep 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Basically i have an older rear projection model mitsubishi not sure of the model #, it is currently having lines run from top to bottom like waves on the picture screen! is there anything you can tell me...
Many different mitsubishi's have problems with voltage regulators going out and causing wavy diagonal lines that scroll the picture from top to bottom or vice versa. Without a model number it's difficult to clarify.
Jul 05, 2010 | Mitsubishi VS-55609 55" Rear Projection...
Diagonal lines rolling or showing on picture
I think that means your FMT brd is going out. you can have a mitsubishi authorized service center come out and send an estimate to mitsubishi for help on the repair, or have a service center come out and repair it, usually about 300-500 out of pocket either way
Mar 17, 2010 | Mitsubishi WD-62525 62" Rear Projection...
My picture isnt clear. whats the best color setup?
The best way to clear the picture on these sets is to remove the screen and clean the mirrors. If it is still not clear after that it may be a bad lamp or failing capacitors in the chassis. They cause wavy lines and makes the picture blurry.
Jan 31, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Wd-62525 dlp: I get the following message: TV
how long does the set run before you get the message?
Dec 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have horizontal lines on my Mitsubishi 62525 dlp tv. it does this on cable and component sources (only ones i have hooked up). When you pull up the tv menu these lines do not appear and also the lines...
Bad capacitors. On my set HDMI looks clear, but component inputs have moving horizontal lines. There's a guy named Tbully on AVS forum that did a PowerPoint presentation that will point you to the capacitors to change. Sorry I don't have a link at this time.
Oct 07, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Vertical lines on Mitsubishi 62" DLP
the DM and/or the FMT board are going bad. the chassis needs to be rebuilt. check out www.tv-techs.com
Jan 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
504 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
