Question about Sony Televison & Video
I have a Sony kp53xbr35 rp tv, shutting off
I have a Sony kp53xbr35 rp tv, the problem is that i turn it on the lights begin to turn on. the screen turns blue to blue green then red and the tv shuts off. i can still get sound but no picture. the timer/stand by light light blinks 12 times does any one know the code for the twelve lights. also recently the convergance was all messed up it bowed in the middle and the colors would not line up. i know the convergance ics need replaced but would that make the tv power off? does any one know how to fix thanks.
  • 75 Answers
If you know that the convegance IC are bad then I would replaece them frist and see if that will fix the whole problem, it just might. Here is a sight you can go to that may help you if that does not fix it www.somelifeblog.com has some good info on sony not your model but could be same problem. check it out and see.
Posted on Dec 05, 2009
Distorted curved picture upper and lower screen on my Sony Videoscope XBR model kp53xbr35
CONVERGENCE PROBLEMS ARE COMMON ON THIS MODEL. THIS WILL REQUIRE PARTS REPLACEMENT.
Dec 27, 2009 | Televison & Video
I have a Sony kp53xbr35 rp tv, the problem is that i turn it on the lights begin to turn on. the screen turns blue to blue green then red and the tv shuts off. i can still get sound but no picture. the...
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can get more information and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 16, 2009 | Sony KP-53XBR45 53" Rear Projection...
Sony rp tv kp-53xbr35 wont turn on
YOu may need to replace the bulb in the unit, check the bulb and if blown, you need to replace and after replacing reset the lamp time hours. Good luck.
Nov 14, 2009 | Sony KP-53XBR45 53" Rear Projection...
Sony Wega Kv-36XBR250 screen blinking
I have seen this flashing before, this could be an indication that the picture tube is weak, what happens is that if the white balance is off there is a circuit called akb it monitors the kathode of each gun and if they are not in balance it will attempt to balance it out. if it can't the picture will begin to flash, sometimes in some models the power light will blink 5 times. On some models the power light will only flash if the tv gives up trying to compinsate for white balance and shuts off compeletely. If you see the tv shutting off with 5 blinks then you know for sure it is time for a new set.
Sep 02, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Power on then off
Check the settings on the screen. If they are set too high set will cut off.
Apr 08, 2009 | Sony KP-57HW40 57" Rear Projection...
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KP53XBR35 Rear Projection TV Convergence problems
my sony tv projection got colors out of center of image
Jul 14, 2008 | Televison & Video
Tv/Monitor shuts off and on by itself
I have a complete set working all panels with a duff pdp panel - i will happliy sell you the boards please call me on 07940 025730 for details cheers.
Oct 31, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
52 inch sony projection TV
The laser guns are bad. The TV will shutdown if the lasers are bad. The lasers are pretty expensive.
Apr 22, 2007 | Kenmore 50522 / 50524 Side by Side...
Maintanence question obout my Sony rear projection.
i,m not a tech but i,ve been told by a techinican that those tubes do have fluid and it,s not an easy fix to change the fluid i was told the tube has to be removed and a tech told me it would run around 200.00 by the time the tech removes it puts the fluid back in and reinstalls it and after it,s reinstalled the convergance has to be reset that,s what realigns the colors back to their correct position and i,ve heard this isn,t an easy job so i,d probably get a techinican to fix it but that,s up to you someone might have an easier opinion but the tech i talked to is one of the best thanks and maybe you can help me i have a blue tube on my big screen tv that wont light upcould you give me some insite as to what you know about a projection light that you said that may need changed think that may be my problem your welcomed to call me about this at 270-566-4327 anytime soon as possible thanks
Nov 26, 2006 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
130 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
