Question about Jenn-Air JED8430 Electric Cooktop
JED9800CAS - BROKEN COOKTOP GLASS NEAR THE DOWNDRAFT..... CAN I FIX MYSELF AND WHERE SHOULD I GET THE PART IF SO? OR SHOULD I PURCHASE THE NEW TOP AND HAVE A TECHNICIAN COME OUT AND INSTALL IT? WILL THAT SAVE ME BY ME PURCHASING THE TOP MYSELF
  • 77 Answers
Hi,tried to look up your model and i cant find it?
Posted on Nov 16, 2009
  • 68 Answers
You might be able to do the job yourself, but it can be quite challenging. You should definitely consider getting a tech to do it. Whether you'll save any by getting the part yourself depends on the repair outfit. However, if they order the part and it's wrong or something doesn't work out, they are responsible- not you. Some places might charge you for the extra callout if they have to make an xtra trip for wrong part.
Need to clean contacts on control knobs under glass cooktop on ge jgp640 downdraft top. Ignitors wont stop clicking. Is the top glued to the chassis
Sorry to read about your problem, I hope this helps you out.
their is no cleaning of contacts, they are sealed units..have to replace the switch,
you have to remove the entire range from the counter top..will take 2 people
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 16, 2010 | GE Monogram ZEU36 Electric Cooktop
Hi my name is Ursula I have a 5 burner ceramic cooktop whirlpool model 005 and two of the elements do not work at all. How do I get this replaced or must I purchase a new stove top.
YOU DO NOT HAVE PURCHASE A NEW ONE , TAKE NOTE OF TYPE OF ELEMENTS AND ,I E LARGE/ OR SMALL, AND MODEL NUMBER AND CONTACT SUPPLIER FOR REPLACEMENTS, THEN YOU CAN TAKE OUT BROKEN ELEMENTS AND REPLACE WITH NEW ONES.
Oct 13, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
Need To Replace the Cooktop of my Jenn-Air downdraft
Here is a blowup diagram of the cooktop.
CLICK HERE
Looking up the service manual - it is no longer available.
Hope this is helpful.
Thanks for using FixYa!!
Apr 25, 2009 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Broke glass on electric genn-air
Please do not use the stove if the element is viable because of broken glass, this could become a danger to yourself.
Look at the cost of a new stove, you should be able to get one for
around 400.00. One of my customers had a glass top with 4 burners,
they had the same thing happen, the cost to replace the top was
1,200.00. So I would assume that you can get a new stove with 4
burners less then it would cost to replace the part on a stove you don't like. Maybe there is a LOWES around you to look at stoves,
they seem to be everywhere,like death and taxes.
As for putting a 4 burner top on a stove that has 2 with grill, I don't think it can be done without the extra cost of adding the parts to run the other 2 burners, so like I said in the long run,it just might be cheaper to but a new stove. It should not be a big deal to remove the exhaust from the grill part of the stove.
I looked at the model# you put down,and it does not have a grill,
from what I see, there are 4 burners and a downdraft vent in between the 4 burners, there are 6 models with this part # and none have a grill,only the downdraft vent.
If the model# is right, the cost would be around 300.00 for the glass, and then the cost of having it replaced. So I would say over
400.00, In which case for the same amount you could have a new one, but you must weigh the difference for yourself and see what you think is the best way to go.
If you have any more questions,please post back and everyone is more than willing to help you. I hope I have helped a little.
Mar 24, 2009 | Jenn-Air JED8430 Electric Cooktop
Jenn air glasstop
As long as the pan bottom is truly flat, you sure can. Hope this helps!
Feb 11, 2009 | Jenn-Air JED8430 Electric Cooktop
Jenn air cook top
Yes you can. Call Jenn Air ((877) 232-6771) and give them your model number (serial is helpful too). They sent my replacement glass within a week. I have a model JED8430ABD from 2000 and they had the top. Fit perfectly and took about an hour to replace.
To change it out, after unplugging the cooktop, I removed the metal tape connecting the external vent shaft to the blower. Then I just lifted the entire cooktop out up out of the countertop so I could access the screws on the sides of the cooktop (looking at the edges of the new cooktop glass helped me figure out which screws to remove around the edge). Then I removed the 2 screws in the vent area on top (1 black screw on each side). And that released the cooktop glass from the metal box that holds the burners. I then took the rubber rings out of the knob holes so I could put them in the new cooktop (I almost missed that...). Finally, I put the new cooktop glass on, put the screws back in, lowered the cooktop back into the counter, and retaped the blower to the vent shaft. Voila!
I really wouldn't be afraid of doing this yourself if you are handy at all. And it will save you a ton. Good luck.
PS The screws around the perimeter are hexigon shapped, so you can't just use a screwdriver. I found my Black & Decker electric screwdriver had that same shaped hole that it held the bit, so I just pulled out the bit and used the screwdriver that way. Worked like a charm.
Feb 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Cooktop glass broken - need a replacement - where can I find it?
It all depends on our capabilities... The top isn't all that difficult to replace. If it were me, I would call GE Factory Service 1-800-432-2737 or schedule an appointment online at www.geappliances.com as there may still be a warranty on the top which is expensive...
Dec 23, 2008 | GE Profile JP930 Electric Cooktop
JENN AIR GLASS TOP REPLACEMENT
the glass top replacemnt is a pretty straightfoward task, a matter of unscrewing one and repalcing it wiht anew one. after ordering new top its a matter of lookin g at eh new top to see which screws would need to be removed from old. hardest part about job will be youll need to do disconnect the downdraft from the venting ,and pull unit up from the counter inwhich it is installe.< not difficult but cumbersome and awkward to manuver. check abd verify full model and serail number and cal manufacture for correct part umber. may cast anywhere fom 200-400 dollars depending on model
Nov 04, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
209 people viewed this question
Top Jenn-Air Cooktops Experts
Paul Carew
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
