Question about Kenwood Food Mixers
Kenwood Chef Mixer A 901P Electronic speed controller replacement.
I am replacing the speed controller on a Kenwood chef A901P.
The old one is a simple bakalite one with on/off contacts and what I assume to be a thyristor with a couple of support componets.
The replacement is a PCB which seems to use a form of inductive loop to interface with the speed goveners on the end of the armeture.
Does anybody have an idea which wires no go to which terminals on the new PCB board??
  • lynik Feb 09, 2009
    I also have an A901P mixer and am having great difficulty locating a wiring diagramn for the new type pcb controller. The controller was purchased from 4ourhouse co.uk but they do not supply a diagramn.Rather like selling a car without the ignition key!
How can I service an A901 kenwood mixer, need to get top plate off.
the speed control on my kenwood chef A901 is not working
how do i fix this.
Oct 16, 2012 | Kenwood Chef Major A701 A901 Cm170 Km201...
Kenwood Chef KM400 motor speed is too slow
A failed SCR or triac will not always show visually any sign of failure. Chances are good that is all that is wrong. If mixer had been plugged in when it got wet, that is all it takes. Also check the transient voltage supressors if the chef has them. They would be identified on the circuit board. as TVS or MOV along with a number. Only number to use is the one on the component.
If you can find ratings for the old devices, just matching the basic ratings should do. Just guessing, but the SCRs should be 20 amp and 400 volt, If the old ones are a lower rating than my guess, there is no problem with using the higher ratings, if my guess is low, go with the original's ratings. Manufacturer of device does not matter as long as ratings are at least comparable.
Jan 19, 2012 | Kenwood KM400 / KM410 Chef Classic Stand...
I have a Rival-Chef Excel KM230 stand mixer. I need a spatter guard for it can you direct me for the part. Rival no longer makes the mixer and has no parts for it. Can you help me. While researching I...
I live in the US and have an old Kenwood KM230 Mixer that I absolutely love. Unfortunately I can not locate a replacement for the spashguard that has now cracked. The old splashguard item # 27215/31227 is the replacement spashguard....any solutions
Aug 05, 2010 | Kenwood KM300 Chef Stand Mixer
Kenwood Chef - slowest speed
if you have max speed you have to replace the .1uf capacitor the 2 spring loaded screws serve far fine adjustment
Feb 02, 2009 | Kenwood KM400 / KM410 Chef Classic Stand...
There was a smell of burning, i.e. very hot wiring insulatiuon (?) on old Kenwood Chef Model 901. Could it be the motor or some other component, and can I repair it? If it is due to overloading due to...
Hi sometimes, its not the motor, maybe its the speed control, in this model same A701 its centrifugal system, if the capacitor or resistor not working fine, give this smell . you must give your Kenwood for repair or check
kenwoodchefrestore.co.uk
Aug 16, 2008 | Kenwood KM300 Chef Stand Mixer
Kenwood Chef A701 Variable speed controller malfunction. Appliance only operates on maximum speed.
the solution its change the capacitor or triac, normaly problems in models A701 or A901 old motors
regards
Aug 07, 2008 | Kenwood KM300 Chef Stand Mixer
Item: kenwood chef km201 Problem: Leaking grease from mixer shaft
How old is the machine?
The leaking comes from the lower gearbox assembly, ther are two kind of gearbox. There are two kind of vertical drive shaft, 14mm and 12,7mm that goes through the gearbox.
You can try to replace the grease, make sure that is vegetable grease.
May 02, 2008 | Kenwood KM300 Chef Stand Mixer
Kenwood chef.mixmaster
Try to replace the grease in the gearbox, make sure to use vegetable grease.
Nov 03, 2007 | Kenwood KM300 Chef Stand Mixer
Food Mixers Logo
575 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
jason
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
