Question about Dewalt 18 Volt Compact Drill Kit
Chuck broken drill bit chuck is locked and will not open. is there a way to disassemble the chuck to free up the 3 teeth that hold the bits?
Just happened to me. Oil the chuck and let it sit and soak. Very gently, put the dril into a vice to secure it. With a pair of adjustable pliers (somthing that you can get a good grip with) attempt to work the chuck free. It works but just be gentle so you dont break anything
Posted on Nov 16, 2009
How to change a drill bit?
Put drill in reverse grab ahold of the drill Chuck our use a key. A cordless drill you grab the Chuck order the speed button slowly and it will loosen.
Oct 10, 2015 | Drills
I have a Milwaukee M18 cordless drill with a bit broken off inside and the chuck won't open.
Put your drill into reverse, and hold the chuck. With luck, that will loosen the chuck and the broken bit will fall out.
Jul 17, 2015 | Milwaukee 2610-20 18V Cordless M18 High...
How to remove a drill bit from insert of screw that holds on driver on an elecctric drill?
do you have the "chuck key"? this is the tool you will need to undo the chuck (part which holds the drill bit). it is often stored in holder in handle of drill. If you dont have chuck key you can improvise using 2 slot head screwdrivers: insert one into one of the 3 holes around chuck, then insert the other into the teeth around check and lever against the 1st screwdriver.
Apr 06, 2015 | Drills
Psb 650 re
You have wound the threaded section of the jaws fast the thread in the case so sorry the chuck is broken as the teeth will be damaged. Best replace it with a new chuck
Jun 18, 2013 | Bosch Drills
I have just purchased a Makita 8391DWPETK 18V Cordless Combi Drill - how do i actually put a drill bit in? Do I need to take off the plastic ring?
The large black part of the chuck should turn left and right to extend (close) and retract (open) the three chuck teeth that hold the bit in place. Turn the chuck to open it far enough to get your bit fully in the chuck then turn it closed to hold the bit in. When the teeth make contact turn the chuck a bit further to get it tight enough that the bit won't slip. When you get used to it, sometimes it's easier to hold the chuck lightly and turn it by lightly squeezing the trigger to turn the chuck with the drill motor.
Feb 25, 2012 | Makita Drills
How do you get a drill bit or screw driver bit out of a Cordless Drill? It has been left to me. VPX 1222. I dont know how to use a drill, never had one before.
If it has a key-less chuck, hold the skirt behind the chuck proper and turn the chuck clockwise with the drill point facing away from you. If it has a chick that has a ring of teeth macnined into the outer band, you need a key to release the bit in the chuck. Keys vary greatly and if you do not have one, you will need to take the drill to a hardware shop for them to supply you with the correct size and configuration key. If you do have a key. place it in one of the three holes in the front part of the chuck, engage the gear teeth and turn the key anti-clockwise to loosen off the chuck jaws and remove the bit. If you require any more information, feel free to approach me at any time. Please rate this answer to your question.
Jun 05, 2011 | Drills
I can not change the drill bit. Do I need another tool?
that depends on whether or not you have a keyed or keyless chuck. if you have a keyless chuck then you do not need another tool you must turn the chuck counter clockwise to loosen the chuck and replace the bit. if you have a keyed chuck then you will see three holes around the chuck of the drill ie the part that holds the bit. just below the holes you will see teeth spaced evenly around the drill. a chuck key allows you to put the end of the key in one of the holes and using the teeth you turn the chuck key thereby loosening the chuck and allowing you to change the bit. if you have a keyed chuck just take it to your local hardware store and they can provide you with the correct key and show you how to remove the bit. if your chuck is keyless the hold the chuck put the drill in reverse and pull the trigger use a glove to protect your hand
Feb 24, 2011 | Drills
Keyless drill has locked in a closed position with the drill bit
I just put mine in reverse and grasp the chuck with a pair of channel locks. Pull the trigger and hold the channel locks tightly. The chuck will release the bit.
Jun 04, 2010 | Craftsman 3/8" Corded Drill
There is play in the chuck may be bearings. it means drill bit wanders slightly when drilling. drill bits lock in properly but the chuck has left to right play in it
You seem to have found the problem, now you must disassemble the gear head and remove the chuck. Open the chuck jaws wide and look for a screw inside that locks the chuck to the shaft.
Oct 13, 2009 | Makita BHR200SAE Cordless Rotary Hammer
Never have used a keyless chuck b4- need to change bit, how do I do this? thanks
hi this should be reletively easy hold the end black bit with the sivler bit holde coming out not the black bit next to the yellow case on drill you hold the black part thats at end of drill by where the bit goes into not the black bit near the trigger hope i explain this ok.
Hold this bit tight then put drill in reverse then press trigger a couple of times it might be tight but shouldnt be that tight it wont undo.
1 put in reverse
2 hold black plastic piece near where drill bit goes into
3 press trigger few times
4 this should undo it allowing you to put a bit in
make sure its in reverse else you will just tighten it up more let me know if you need further assistance ok
Mar 05, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18 Volt Compact Drill Kit Logo
214 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
