Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Gas heater won't ignite
I have a Carrier gas heater. I replaced the gas valve(White Rodgers 5wire) because the valve would clatter and intermittently work. Initially the furnace worked fine, Now the fan comes on,ignitor works and the pilot will only ignite temporarly and the burners go not light. any thoughts before I have to call a serviceman? Thanks,Mike
    Habit-Forming:
  • 47 Answers
I agree. Either the pilot flame is dirty and is not making good contact to heat up the bi metal strip on the pilot assembly, or the pilot assembly is defective. 90% of the time if you clean the pilot orfice and the pilot burner it will take care of the problem
Posted on Nov 24, 2009
  • 68 Answers
Look at the pilot light it should burn down and up. on the down side it has to heat the plate on the pilot burner (it should have 3 wires coming out of it). If the flame does not touch the lower plate, remove the brass fitting from the pilot burner and clean the orifice inside.
Posted on Nov 18, 2009
Drain wont stop leaking
1) Copy following link for fixing drain valve on 38 gallon gas water heater with plastic drain valve.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
2) According to serial number, your GE (Rheem) water heater was made in 3rd month of 2007. No service manuals are available from Rheem. Warranty period is probably 6 year. Unit appears to have reliable White Rodgers gas control valve.
http://waterheatertimer.org/How-to-maintain-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
3) Add comment and say what you discover.
Feb 18, 2013 | Water Heaters
Pilot lights but no main burner
Is there a way to check for gas pressure even if just a slight loosened connection to hear it then quickly re-tightened. Otherwise the main valve is not working as it should and will need to be serviced or replaced. Thats all i got.
Dec 02, 2011 | Empire Heating & Cooling
I have an A. O. Smith Model FPSH 40-261 hot water heater. It won't heat water. there is a green light on the control flashing. What does it mean?
AO Smith uses the Honeywell ICON gas valve with green indicator light.
Some models use White Rodgers Intellivent with a row of indicator lights.
The gas control blinks the error code:
Open following links to identify gas control thermostat and read possible error codes:
http://waterheatertimer.org/pdf/Honeywell-Gas-Valve-LED-Codes-2000.pdf
http://waterheatertimer.org/BW.html#Temp
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
Jul 18, 2011 | Water Heaters
My white rodgers control panel is set on vacation (green light) is on. I have held down the arrow buttons to get it off of vacation mode but it is not working. Obviously i need to switch it off as we have...
Water heater and gas valve are not clear:
Add a comment with description of water heater and gas valve for possible help.
Open following link for White Rodgers intelli-vent gas valve thermostat:
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#Intellivent
1) Typical instructions for Kenmore and AO Smith water heater with Intelli-vent say:
Set on-off switch to ON position.
Hold down both arrow buttons for 1 second.
Then press hotter button.
2) Also check that 120Volt electrical outlet has power, and check outlet with cheap circuit analyzer from home center.
3) If Intelli-vent gas valve thermostat is malfunctioning, and won't reset, then contact manufacturer of water heater for replacement gas valve.
Label on side of tank will have Model number, manufacturer, type of gas LP NG, serial number for part ordering.
Add a comment for more help.
Jun 10, 2011 | White Rodgers Water Heaters
I have a HEAT MAKER MARK II Boiler and it wouldn't fire up , I replaced the HOT SURFACE IGNITER (I took the amp reading and i got 3.9 amps,wich is normal) and the boiler still wouldn't fire up i check...
Check the flow switch. Small black box lower left hand side as you face the from of the unit. Try to jump the connection and then see if it fires up. If it does, replace your flow switch. The flow switch prevent the boiler from firing because it is not sensing the water moving through the pipes. The boiler won't fire if water is not moving through it.
Craig @ Aggie Plumbing & Service
Dec 16, 2010 | White Rodgers Water Heaters
Burner lites but goes out after 2 or 3 min.
the white rodgers gas control needs to be replaced;
the way it works is: the thermocouple opens the pilot gas circuit and, holds it open
when it heats up by creating a magnetic field in the gas control then: when you turn
the knob on the gas control to "on" a valve inside the gas valve opens the main gas circuit and, electricity supplied by your RV keeps it open.
the main gas coil inside the gas valve is defective and, can not hold the main gas circuit to the burner open anymore.
Jul 24, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
White Rodgers main gas valve operation.
pleas follow the troubleshooting page 9, 10 and 11
Dec 10, 2009 | Heating & Cooling
Troubleshooting techniques for natural gas spark ignition modules
the white-rodgers site has spark ignition modules
Jan 19, 2008 | Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
326 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
