Question about Pioneer PRS-D5000SPL Car Audio Amplifier
Lights dim Hi, my car lights dim alot. My adio system: amp Pioneer Premier PRS-D2000SPL (2000rms on 1 ohm), sub Pioneer Premier TS-W3001D2 (1000rms) and i`m running it on 1 ohm load, extra kinetik HC 800 battery at the back, 5 farad capacitor, everything connected with 0 gauge wires, good connections. On the low notes voltage drops to 10.8V and lights dim alot!which is not good at all:/ any suggestions, do i need a biger capacitor? Thanks
  • kestas666 Jan 11, 2008
    i upgrade my factory alternator for a new one, which gives now 200amp, thats the best what i could get for my model. anyway it doesn`t help that much...
  • player123 Apr 29, 2008
    i have 12" jl 3's with a pioneer 800 watt amp, the amp keeps getting real hot and blowing the 2 30 amp fuses in the amp, or it keeps cutting in and out & my headlights goes real dim when the bass hits
    Problem Solver:
  • 5 Answers
For that much watts it calls for two kintick hc 1400 go to there web site they have a watt cal.
Posted on Mar 22, 2009
3000 watts divided by 12 volts=267 amps...how hot is your alternator...have you considered a separate alternator or a battery isolator?
Posted on Jan 11, 2008
How to wire the Pioneer Premier 12in. dual 2 ohm voice coil. 1000 watt rms 3500 watt peak, and I have a 1000watt JL audio 2 channell amp, they are both stable at 1 ohm. I wired them parrallel, and it blew...
If you have two subs to connect, place the speakers next to each other face down, you will notice that the connection points run in sequence +- and +-. Now connect the - (negative) from the one speaker, to the + (positive) of the other speaker. Now connect the open + from the one speaker and the open - from the other speaker to your amp.
If you have only one speaker it should be bridgeson your amp.
Your amp should have a bridging indication. On the connection points of each channel on the the amp, you should see a mark pointing to the first - and the last +. That will be your bridge
May 09, 2010 | Pioneer TS-W3004SPL Premier 12" SPL...
How can i connect 2 12''s pioneer premier too an jl audio amp n make the bass loud???
Hello m1k377060,
Having your subs in well-designed and constructed enclosures will make as much or more difference in their output than how you connect them to an amp.
The TS-SW1241D's are single voice coil 4 ohm shallow subwoofers that are rated for 350 watts RMS. For maximum loudness, your JL amp needs to be 2 ohm stable and capable of delivering 700 watts RMS into that impedance. Wire the subs in parallel for a 2 ohm load and maximum power from the amp.
Hope this helps.
Oct 09, 2009 | Pioneer Premier® TS-SW1241D Car Subwoofer
Wireing diagrams
Hello stingerman20,
Your Directed D2400 amp is CEA2006 Compliant. It is stable at 1ohm and will produce 1,200 watts into that load. So you want your subs wired as close to 1 ohm as possible.
The only 3500 watt Pioneer Premier series subs I could find were the models number TS-W3002D2 and TS-W3002D4 with dual 2ohm and dual 4ohm voice coils respectively. The wiring options for the D2's result in 0.5ohm (too low), 2 ohms, and 8ohms. Your best option would be the 2ohm configuration which would be voice coils in series and subs in parallel. Options for the D4's result in a 1ohm load and a 4ohm load. Your best option would be the 1ohm configuration which would be voice coils and subs parallel.
To see the wiring options, try Rockford-Fosgate's "wiring wizard".
Select 2 woofers and the appropriate voice coil impedance and quantity and click "search". It'll bring up all of the possible wiring configurations along with the final impedance load.
Hope this helps.
May 11, 2009 | Directed 2400d Car Audio Amplifier
Car audio
(2) 3 ohm voicecoils wired in parallel net a 1.75 ohm impedence.
The amplifier will produce 2000W 1 ohm
1500W @ 2 ohm.
A 1.75 Ohm load will be somewhere inbetween.
Plan on 1750W.
Plenty of power for both in the proper enclosure.
Dec 21, 2008 | Car Audio & Video
Hi, will i be able to feed 2 JL Audio 12W7s with 1 Pioneer PRS-D2000SPL amp? thanks
Yes, that should have enough power. Remember to use 8 or 10 gauge wire to in stall amp, and 14 gauge for the speakers.
2 Subs running together
If they have the same impedence (like 4 ohm) then you should be able to run two different model number speakers as if they were the same model number. There might be a slight difference in the way they sound, but I would not expect it to be enough to be noticeable. Good luck.
Mar 27, 2008 | Pioneer TS-W301R Car Subwoofer
Prsx720
The specs I read on the Pioneer site say the amp is not 1 ohm stable, so keep that in mind.
It partially depends on the impedance of each voice coil on the DVC subs. If they are dual 4 ohm, and you connect the DVCs in parallel ("+"s together, "-"s together), you could run a sub on each channel of the amp(s). This would put about 200W on each sub.
The other option is to still tie the dual 4 ohm voice coils in parallel, tie 2 subs in series (one "+" to the other "-"), and bridge the two channels of the amp (aka put them in parallel). But this, also, would be about 200W on each sub.
Things get different if the subs have dual 2 ohm, 3 ohm, or 8 ohm voice coils.
Mar 15, 2008 | Pioneer PRS-X720 Car Audio Amplifier
Pioneer prsx720 wiring question
If the subs are dual 4 ohm voice coils, you could hook the DVC's of each sub in parallel ("+"'s together, "-"'s together) making each sub essentially 2 ohms. Then connect one sub to each channel of the amps. This will put about 200W on each sub.
Mar 14, 2008 | Pioneer PRS-X720 Car Audio Amplifier
Pioneer PRS-D5000SPL Car Audio Amplifier Logo
152 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
