Question about Samsung Propel A767 Cell Phone
I have downloaded and installed drivers and latest upgrades for Propel. but no connection
I hav downloaded intel dg31pr audio driver for windows xp but while installing it appeard as "this driver version is older than the system one". please solve my problem...,,,
Well mahatab9, you have not told us if there is any audio driver installed on your computer or not. But the error message clearly stated that, you have an audio driver already installed for your motherboard model. So, if the driver is not properly working or you just want to upgrade it, you should use Intel Auto Driver Updater for best result. This will show if there is any updated version of your installed drivers are available or not. To do this, click on the following link to automatically identify and update your drivers and softwares.
Automatically Update your Driver
Now click on "Check Your System for Latest Updates" to start analyzing your computer. This will show whether your system requires an upgrade or not.
IMPORTANT: This utility is for Intel Motherboards only.
But still, if this utility doesn't show any upgrade to your audio driver, then you can manually download this driver as your motherboard INTEL DG31PR supports the Realtek HD Audio driver only for best response. If you have already installed any other audio driver than Realtek, please uninstall that and install this one. To download this, click on this following link:
Download latest Realtek HD Audio Driver
This installation will remove any previous version of Realtek and install the newest one automatically.
Hope this helps, Regards,
Mrityunjay
May 06, 2011 | Computers & Internet
I need a driver for a husquvarna 3D reader/writer card, where can I find one
Info on Husqvarna Viking website - http://www.husqvarnaviking.com
When installing the 4D Embroidery System onto Windows 7 computers, the dongle drivers may not initially work correctly, as the 4D Embroidery System installs a set of dongle drivers which were created before Windows 7.
Download and install the latest dongle drivers prior to installing the 4D Embroidery System. Failure to do this, may result in the "Dongle driver not found (E0009)" when you try to open the 4D modules.
Please follow the steps below to install the latest dongle drivers BEFORE installing the 4D Embroidery System
  1. Download and install the latest Dongle Drivers.
  2. Insert your 4D Dongle.
  3. Install your 4D Embroidery System software (and all updates).
  4. Open your 4D Embroidery System software to confirm that your dongle is working correctly.
If you installed the 4D Embroidery System software before installing the latest dongle drivers and if you experience problems such as the error message "Unable to start hasplms service..."; download and install the latest Dongle Drivers.
Link to dongle drivers - http://www.vsmsoftware.net/downloads/HASP/haspusersetup.exe
Dongle issues - http://www.husqvarnaviking.com/global/8588_4197.htm
Good luck.
Dec 10, 2009 | Husqvarna Viking 1
Not booting after upgrade to latest version
The latest version is version 2. First try downloading the update again here:http://www.korg.com/SupportResults.aspx?productid=271 Don't forget to download and install the latest Midi driver and USB driver as well. They are available at the same address. I couldn't get the FAQs section to work there so I couldn't look at it. If you still have trouble try contacting them or try this site:http://www.sweetwater.com/sweetcare/ Let me know if this helps.
Nov 29, 2009 | Korg Pa800 Synthesizer
Error Message on Printer
your printer driver is not vista supported or motherboard driver is not properly instaled
May 29, 2009 | Lexmark X5270 All-In-One InkJet Printer
P4V845 motherboard...
i need audio driver for p4v845sm
Nov 19, 2008 | VIA P4MA Motherboard
CanoScan640P ex
If upgrading an existing PC to Windows XP from an earlier versionof Windows, Canon recommends a "clean install" to ensure reliableoperation of drivers. If a clean install is not possible, it isessential that drivers for your existing Canon Hardware are UNINSTALLEDprior to upgrading to Windows XP. After the installation of Windows XP,the drivers for your Canon Hardware can then be re-installed. Canon has released a software utility to uninstall USB and SCSI Scanner drivers for this purpose. Click here to download this utility.It is recommended to consult our Driver Downloads page and use the latest driver for your product. Canon supports several scanner models with Windows XP. Windows XPsupport is offered for Windows XP Home Edition, and Windows XPProfessional.The following older models are not compatible with Windows XPdue to hardware design: IX-3010, IX-4015, IX-4025, CS 300S, FB310,FB61
Source
Sep 20, 2008 | Canon CanoScan N640P Flatbed Scanner
DOWNLOADING MP3 PLAYER TO WINDOWS VISTA LAPTOP
For Vista compatibility with the SA6045 -
Philips GoGear Firmware Upgrade
You need to get the latest firmware upgrade from the Philips website:
1. Go to www.philips.com/support
2. Enter your country/language
3. Enter your model # SA6045 or whatever
4. Click on the link for your exact model # (the one w/o the "B" in it)
5. Click on "Software & Drivers"
6. Download the updated "Device/Firmware Manager"
7. Once installed, open the Philips Device Manager
8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course)
9. Your Mp3 players firmware will update automatically
If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date."
-Tha Mp3 Doctor
Aug 27, 2008 | Philips GOGEAR SA6045 MP3 Player
Micro
Code 10 means the device is failing to connect properly on some level. Make sure you have downloaded and installed the latest drivers, Creative Zen and Jukebox Driver Upgrade version 1.30.03. Failing that try a disk cleanup from rescue mode. If that doesn't work you need to first determine if the player is faulty. Can you install the drivers on say a friend's PC, connect, and see if it works OK?
http://www.creative.com/products/mp3/MP3PlayerRecoveryTool/welcome.asp
Dec 03, 2007 | Creative Labs Zen Micro MP3 Player
System error
This firmware upgrade only works with Creative MuVo Micro N200 players. Do not install this upgrade to other players.
You will lose all content in your player when you install the firmware. Back up any audio or data files in your player to your computer before upgrading the firmware.
Before installing the firmware, please complete the following procedures:
  1. Download the latest device driver if you have not installed any drivers for your player. The file name is MStorage_PCDRV_LB_1_07_00_250.exe.
  2. Connect your player to your PC.
  3. Close all active applications (for example, Internet Explorer, Windows Explorer, or Windows Media Player etc), as well as background applications such as Norton anti-virus applications.
  4. Double click on the file MStorage_PCDRV_LB_1_07_00_250 to install it. Follow the instructions on the screen.
To install the firmware for your player, follow the procedures below:
  1. Download the firmware update, MuVoN200_PCFW_LF_1_20_04.exe to your hard drive.
  2. Connect your player to your PC if it is not already connected.
  3. Double click the firmware upgrade file.
  4. When prompted to set your player in Recovery mode, disconnect your player from your PC.
  5. Remove the battery from the player, press and hold the Play button while connecting the player to the USB port.
  6. Continue to hold the Play button for about 10 seconds after your player is connected to the USB port.
  7. When the Find New Hardware dialog box appears on your PC screen, release the Play button.
  8. If this is the first time a player is installed as Player Recovery Device, Windows will find a Player Recovery Device (or USB Device), and prompt you for drivers. Click on No , and select Do not search. I will choose the driver to install. Windows will install the necessary drivers automatically.
  9. Double click on the downloaded firmware again (MuVoN200_PCFW_LF_1_20_04.exe) to update the player's firmware.
  10. During the firmware update process, make sure to check the box next to Format Data Area under Download options.
Feb 02, 2007 | Creative Labs MuVo Micro N200 MP3 Player
Samsung Propel A767 Cell Phone Logo
57 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
