Question about Casio FX-115ES Scientific Calculator
What can you get when you touch uninsulted wire
  • Casio Master
  • 7,993 Answers
You can get an electrical discharge. Depending on the intensity of the current it carries ( number of amperes) you may get electrocuted (the heart stops, you may get burns, and you may die), especially if you touch a wire fallen from a power line.
If you want to read a bit more about it here is a short article in Wikipedia.
By the way, what does this quaetion have to do with calculators?
Hope it helps.
Posted on Nov 16, 2009
My Roper washing machine will not complete a cycle. It stops before it gets to rinse. If I turn it off and wait a few hours, it will run and finish if I waited long enough. Could the motor be dying?
ATTACHEMENTS ON HOW TO TEST MOTOR
The following test must be made on one-, two-, and three-speed drive motors:
1.
Touch and hold one ohmmeter probe to the terminal on the white/black wire from the motor.
2.touch the other ohmmeter probe to the terminal on the white wire from the motor.
3.The ohmmeter should showZEROresistance (continuity). If not, the drive motor is bad and needs replacing.
Start Winding
4.
Touch and hold one ohmmeter probe to the terminal on the black wire from the motor.
5.Touch the other ohmmeter probe to the terminal on the yellow wire from the motor.
6.The ohmmeter should show a reading between 4-10 ohms.
7.If you do not get this reading, the drive motor is bad and needs replacing.
High Winding
8.
Touch and hold one ohmmeter probe to the terminal on the white wire from the motor.
9.touch the other ohmmeter probe to the terminal on the blue wire from the motor.
10.The ohmmeter should show a reading between 0-4 ohms.
11.If you do not get this reading, the drive motor is bad and needs replacing.
12.Touch and hold one ohmmeter probe to the terminal on the white/black wire from the motor.
13.Touch the other ohmmeter probe to the terminal on the blue wire from the motor.
14.The ohmmeter should show a reading between 1-5 ohms.
15.If you do not get this reading, the drive motor is bad and needs replacing.
The following test must be made on two-speed drive motors, along with steps 1-15:
Low Winding
16.
touch and hold one ohmmeter probe to the terminal on the violet wire from the motor.
17.Touch the other ohmmeter probe to the terminal on the white wire from the motor.
18.The ohmmeter should show a reading between 1-7 ohms.
19.If you do not get this reading, the drive motor is bad and needs replacing.
20.Touch and hold one ohmmeter probe to the terminal on the violet wire from the motor.
21.Touch the other ohmmeter probe to the terminal on the blue wire from the motor.
22.The ohmmeter should show a reading between 1-7 ohms.
23.If you do not get this reading, the drive motor is bad and needs replacing.
24.Touch and hold one ohmmeter probe to the terminal on the violet wire from the motor.
25.Touch the other ohmmeter probe to the terminal on the white/black wire from the motor.
26.The ohmmeter should show a reading between 1-7 ohms.
27.If you do not get this reading, the drive motor is bad and needs replacing.
The following test must be made on three-speed drive motors, along with steps 1-27:
Ex-Low Winding
28.
29. Touch the other ohmmeter probe to the terminal on the white/orange wire from the motor.
30.The ohmmeter should show a reading between 1-5 ohms.
31.If you do not get this reading, the drive motor is bad and needs replacing.
32.Touch and hold one ohmmeter probe to the terminal on the white wire from the motor.
33.Touch the other ohmmeter probe to the terminal on the white/violet wire from the motor.
34.The ohmmeter should show a reading between 1-5 ohms.
35.If you do not get this reading, the drive motor is bad and needs replacing.
36.Touch and hold one ohmmeter probe to the terminal on the blue wire from the motor.
37.Touch the other ohmmeter probe to the terminal on the white/orange wire from the motor.
38.The ohmmeter should show a reading between 1-5 ohms.
39.If you do not get this reading, the drive motor is bad and needs replacing.
40.Touch and hold one ohmmeter probe to the terminal on the blue wire from the motor.
41.Touch the other ohmmeter probe to the terminal on the white/violet wire from the motor.
42.The ohmmeter should show a reading between 1-5 ohms.
43.If you do not get this reading, the drive motor is bad and needs replacing.
44.Touch and hold one ohmmeter probe to the terminal on the white/black wire from the motor.
45.Touch the other ohmmeter probe to the terminal on the white/orange wire from the motor.
46.The ohmmeter should show a reading between 1-5 ohms.
47.If you do not get this reading, the drive motor is bad and needs replacing.
48.Touch and hold one ohmmeter probe to the terminal on the white/black wire from the motor.
49.Touch the other ohmmeter probe to the terminal on the white/violet wire from the motor.
50.The ohmmeter should show a reading between 1-5 ohms.
51.If you do not get this reading, the drive motor is bad and needs replacing.
52.Touch and hold one ohmmeter probe to the terminal on the white/orange wire from the motor.
53.Touch the other ohmmeter probe to the terminal on the white/violet wire from the motor.
54.The ohmmeter should show a reading between 2-8 ohms.
55.If you do not get this reading, the drive motor is bad and needs replacing.
The following three (3) checks must be made on all one-, two-, and three-speed drive motors to check for an internal failure (short):
56.
Touch and hold one ohmmeter probe to the drive motor housing.
57.
One at a time touch the other ohmmeter probe to each of the wires (terminals)coming from the drive motor.
58.
The ohmmeter should show an open circuit when each of the wires (terminals)are checked. If not, the drive motor is bad and needs replacing.
HOW TO live TEST a G.E - MOTOR
After removing the cabinet follow the wires from the motor halfway up the tub. Then cut and splice the ORANGE, the BLUE, the VIOLET /WHITE, & the RED wires.
Now using a long long extension cord with the end connector cut off and exposing the 2 end wires stripped back about an inch.
To check the spin cycle: Connect and splice the RED & the Blue wires to one end of the extension cord wire. And the ORANGE & WHITE /VIOLET to the other end of extension cord, be sure to use but connectors or electrical tape. Plug in the cord an the wash cycle should start? If not the motor is bad.
To check the wash cycle: Connect the BLUE and the WHITE/VIOLET wires to one end of cord. And the ORANGE & RED connected to the other end of cord, then plug in and the wash cycle should start? If not the motor is bad.
By the way my advice is free cuz God is good!
Mar 20, 2015 | Roper Washing Machines
Westek touchtronic 3 level dimmer
Copy following link for illustration showing how to wire Westek touch dimmer
http://waterheatertimer.org/How-to-wire-Westek-touch-dimmer.html
Add a comment and describe wire colors and what you have done so far.
Does lamp have touch dimmer installed now? Does lamp have metal surface to attach yellow wire so dimmer receives impulse from human touch?
Jun 10, 2013 | Hardware & Accessories
The ignition quit working took the ignition wires touched together to make the bike start; the starter button then quit working so I was jumping the bike off the solnoid, worked for months. parked over a...
Check the starter,wire connection harness and starter solenoid.
That high amp means a power that was being drain by the solenoid or the starter motor.
Disconnect the wire terminal of the starter and connect your ignition, you will see that it will not drain power from your battery and solve your fuse popping.
Then pull down the starter, overhaul it and clean/lubricate the bushing. If you can't do the starter a mechanic can do it for you.
Hope that helps you.
Thanks for using FixYa!
Jul 15, 2011 | kawasaki KLR 250 Motorcycles
I am trying to replace the right front turn signal assembly. The new assembly I bought from j & p has a red wire and a black wire. The product description says it is dual filament. However, the...
Your new assembly may be internal grounded for a common wire. Take it over to your car battery, touch the base/mount to the negative post and touch one wire at a time to the positive post. The light should light, you should have one brighter than the other, as you touch one wire then the other. Then touch both at same time it should be bright. If this new light works like this, then, pull the bike wires out and away from any metal and apart from each other. Use a 12v test light or the new light (be sure the base is touching metal) and test for wire to wire connection. Turn the bike on, turn on the lights, match up which wire is hot to the dimmer light. Then turn on the signal and match that wire to the brighter light. The other wire can be connected to the base of the new assy. or tape it off and leave it covered. Hope this helps Fix Ya up.
Jul 10, 2011 | 2001 Harley Davidson FXD Dyna Super Glide
Just had a honeywell th4000 installed but the heat won't cut off? The temp keeps rising had to cut it off just so I wouldn't burn up? Tried setting the temp down to about 67 but the temp just kept rising
Sounds like they either wired wrong or they got the white wire touching the red wire. Take the cover off the thermostat and see if you can tell if the white wire is touching the red wire. Installers are bad about leaving tag ends on the wires and they end up touching other wires. Good luck
Nov 30, 2009 | Honeywell Heating & Cooling
My 2000 Volo S40 has a window switch stuck and window will not go up. The window will go down but not up. Every once in a while I get lucky and it will go up. It seems to be a problem with the switc, not...
You can pick up a used switch at a junk yard. To get the window up until then, you can disconnect the wires from the switch. Keep them from touching anything metal. Using a volt meter, determine which wire is hot. Touch that wire to one of the other wires to make the window go up. If it does not go up with the first wire, touch the second wire to the hot wire, and the window should go up. Protect the hot wire from touching anything metal in the door until you can install the new switch.
Oct 03, 2009 | 2005 Volvo S40
Broken Sensor Sterling Touch Immobiliser
There are 4 wires going to the touch pad unit which has an LED in it. The unit has 4 pins (or legs) to which the wires must be soldered. As you say, there are two blue wires plus a red and also a black - although as you also correctly observe, only three wires are present (blue, red and black) in the connector at the other end of the loom which plugs into the control module.
The blue simply splits two ways within the loom, and these are earths. The black carries a pulsing voltage to drive the LED, and the red (which should measure a constant 5v on a voltmeter) is an input which senses when a key is touched on the pad.
Use a continuity tester or ohmmeter to establish which of the four pins on the touch unit connects to the CENTRE pin of the touchpad. Solder the RED wire to this pin. (Best to start by putting some heat shrink up the wire as the pins on the touch unit are quite close together and there's not much to stop them touching.)
Again using the continuity tester (or ohmmeter) establish which of the remaining three pins goes to the OUTER ring of the touchpad. To this, solder one of the BLUE wires - it doesn't matter which one. You must however get the wires to the touchpad the correct way around in order for the key to be read.
You're now left with one BLACK and one BLUE wire which drive the LED, and two pins on the unit which have no connections. The LED will only light when you get these the correct way around. You will not do no harm if you connect them the wrong way round - the LED will simply remain unlit.
One you have soldered the BLUE and the BLACK wires in place so the LED is flashing, simply test your work by touching a key on the touchpad. If all is well, the LED will light continuously for a period and it should be possible to start the car.
Sep 24, 2009 | Vehicle Parts & Accessories
Heat Pump Unit
Yes a bad thermostat can cause the problem you describe. So can a hot wire touching a common wire or the chassis of the ac. Check all wires thoroughly. Turn the power off. Use a volt ohm meter set for continuity. Remove all wires from the thermostat.Touch one meter lead to the ground on the airhandler. Touch the other meter lead to each thermostat wire,one at a time. The only time you should get a reading of continuity is when you touch the common wire. All other wires should read open. If you have any wire reading other than common,find out where it is bare and grounded. If only the common wire reads to ground,replace the thermostat.
Sep 21, 2009 | Heating & Cooling
The wire leading to the turn signal in front was somehow torn. Can you just splice it together like a wire in the house and if so, do you have to worry about touching it?
YOU CAN SPLICE IT TOGETHER..TWIST THEM TOGETHER AND THEY SHOULD BE SOLDERED AND HEATSHRINK TUBING INSTALLED BEFORE SPLICING..NO NEED TO WORRY ABOUT TOUCHING THEM..ONLY 12V DC
Jul 07, 2009 | 2007 Jeep Patriot Sport
I touched two speaker wires together and amp will not respond
That is a very nice amp . Try not to touch (short) those wires together. But yes, the amp has protection and is shutting off to protect it.
Nov 26, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Casio FX-115ES Scientific Calculator Logo
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
