Question about Nokia 6700 Classic Cell Phone
Hi, How do you set up your inbox so that text messages are in order of when you received them instead of randomly all over the place??
When I send a text message, the text is fine but when i receive and Inbox message, the text is huge. How do I fix it?
in the settings find an options for font size........reduce it.... regards!!'mostly see in this order..settings-->display-->font size!!!!
Oct 24, 2009 | Samsung SGH-A877 Impression Cell Phone
My motorola phone will not let me recive text messages but will not let me open to read them.
Hii
have u locked ur inbox wid a password? and yeah u wont receive text if ur inbox is full. Do clear up ur messages in order to receive new texts.
Regards. If still u face the problem, do revert back.
G.Day
Sep 09, 2009 | Motorola Mobility RAZR V3
Blackberry deleting texts/cannot open texts
Blackberrys have something called a low memory manager, which deletes things in order of importance when the device memory is too low. Here is a very helpful link explaining it and how to check the device memory.http://my.simmons.edu/technology/helpdesk/pdf/Blackberry_Low_Memory_Manager.pdf
If you are saving pictures or have a large application you have downloaded you may want to transfer/remove them.
Sep 09, 2009 | AT&T Blackberry Curve 8300 Smartphone
How do I delete text messages from Inbox on Motorola V220?
first press menu, select messages, then press menu button again, scroll down to cleanup messages, select, then scroll down to which box you want to delete and select. done!
Mar 25, 2009 | Motorola Mobility V220
Wont send or receive sms
First you need to get into your phones setting, then touch the pannel for text messages and click get settings.
After you are in your settings there will be a pannel to put in your voice mail and text message number.
You then must go kill your self
Mar 25, 2009 | HTC Touch Diamond Smartphone
Lg chocolate wont hold very many texts
Unfortunately, the texts are stored on the internal memory of the phone in a special place just for text messages, and the limit of the inbox is going to max out at around 40 or 50 texts. Just delete them from the phone, or if you want to save them, you can always email them to yourself from the phone with the forward option, and put in your email address instead of a phone number. You will be charged the standard messaging rate if you dont have a text plan on your phone though.
Jan 20, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Text msgs go to sim card memory instead of phone memory
go to message main menu scroll to 'message inbox' press menu key again , scroll down to 'message setup',press select. scroll to 'text message set up ' press select . in the new menu it will show u 'store to phone , sim' in that option select phone
do update me if u require more assistance
Have a nice day!
Thanks for using Fixya!
Nov 22, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Text Message
Go to messages and to the left it says "inbox" and to the right it should say one of the following....Received, message type, subject or from. click on that... Then choose one of the options..
RECEIVED: Let's you sort the messages by the date you received them either last ones first or new ones first. To change which order you just have to hit received twice. Then scroll up to the top with the bar to the right.
FROM: Let's you sort messages by the sender. For example all "tony's" messages will be together and all "sally's" messages will be together.
SUBJECT: It will sort your messages according to what they say. For example if you have two messages that start with "I'm not home" they will be grouped together. It puts all the messages in alphabetical order no matter the date time or sender,
MESSAGE TYPE; Ok this one is a little tricky. This one sorts your picture messages together, your sim messages together and regular text messages together. They may be in alphabetical order too.
Now if you would like your newest messages first this is what you can do. Hit received and make sure your at the top of your messages (if not scroll up) and if the newest message is the first one there. Your all set. If not repeat the process and then scroll up (assuming you have a lot of texts). Let me know if I helped!
Aug 03, 2008 | T-Mobile Wing™ Smartphone
Sending text message
I am having the same problem! I dont know whats wrong! please help!
Jan 03, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Sending a text message
Go to messaging  - message setting - General Settings - Messages Sent Via  TEXT ( must be )
Oct 03, 2007 | Motorola Mobility Mobile PhoneTools 3.0...
Nokia 6700 Classic Cell Phone Logo
74 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
