Question about Sony PSP-3000 Silver Console
My psp green light turns on for a little while and then shuts down. The screen doesn't turn on at all when I try to turn the PSP 3000 on. I fully charged it and nothing happens. Please help
  • 105 Answers
That usually means youe psp is bricked when that happens its usually a factory default return it to the place you got it and call sony about your problem they will repair or replace it hope this was helpful:)
Posted on Nov 16, 2009
Need help my psp is not working when I turn on I can only see the green light no sounds no display just green light and after a few seconds later it turns off the last thing I did I update with something...
First you have to take out the battery and use charger to turned on and when it turn on just put on the battery or take out the battery and wait for minutes then put it on and tur on,if that doesn't work when you turn on just hold R and start or repair it
Feb 06, 2013 | Sony PlayStation Portable (PSP) Slim...
My sons psp has a black screen
Without a functional screen, the PSP doesn't have much of a purpose. If the power light next to your screen is off as well, all your PSP needs is a good long battery charge. But if the power light is on and the screen is still dark, a few quick troubleshooting steps can help you get to the root of the problem. If troubleshooting doesn't work, you will need to contact Sony eService through its support site, particularly if your PSP has recently been dropped or had liquid spilled on it.
Step 1Turn off your PSP. Remove the battery pack. Replace the battery pack, making sure that it is securely inserted. Turn the PSP back on. If the screen is still black, continue to Step 2.
Step 2Press any system button. If the backlight is turned off, pressing a system button should reactivate it. If the screen has turned back on, go to the PSP settings menu. Select "Power Save Settings." Select "Backlight Auto-Off." This option automatically turns off the screen if the PSP has been idle. If you do not wish to have this feature active, select "Off." If this step did not solve the problem, continue to Step 3.
Step 3Press the screen brightness button below the screen. This button is marked with a small donut-like icon. Pressing the button will incrementally increase the brightness of the screen. Holding down the button will turn off the backlight. It is possible that this button was accidentally pressed down after placing the PSP in a pocket or a backpack. If the screen remains black after the brightness has been increased to full, continue to Step 4 if your model of PSP is any but the PSP Go.
Step 4Open the top hatch on the PSP. This will eject the UMD disc. Only touch the UMD at the edges, as fingerprints can interfere with the disc's functionality. Clean the surface of the UMD with a clean, dry cloth. Do not clean the UMD with water or any other chemicals. If the disc looks scratched or damaged, this is likely the cause of the screen issue. Additionally, moisture can condense on the UMD if the PSP has undergone a recent temperature change, such as being brought into a warm house from a cold car. If the UMD looks wet, turn off the PSP and allow the UMD to air dry. Wait several hours before trying to restart your PSP.
Dec 27, 2011 | Sony PSP (Piano Black)
Psp power up green lights on black screen after a few seconds shuts down psp slim
it sounds like you bricked you psp, if it's not a 3000 or psp go you can probably fix it by buying a pandora battery and magic memory stick.  you can buy them from here http://pandorasales.com/?gclid=CNLk1fzUzqgCFcO8KgodAzI2lA , if you are running a psp 3000 and up, you could try to format your memory stick but it probably won't work.
Apr 25, 2011 | Sony PlayStation Portable (PSP) Console
My PSP will not switch on.the green light show and sreneis blank.
Seems like a bad update or a bad flash. If either Pandora's Battery is the only thing that will help if you are out of warrenty.
Mar 25, 2010 | Sony PSP-3000 Silver Console
I charged my PSP with a universal charger and wrong polarity. My PSP immediately shut off. when I tried to turn it on again it would not turn on, and the green light does not light up either. when I charge...
Sounds like the battery is charged fully. If you know someone else who has another psp, try putting the battery into his/hers and see if it starts up. If so, your psp may have been fried. There is not much you can do.
Feb 25, 2010 | Sony PlayStation Portable (PSP) Console
Psp fell ,turn psp on.green light turns on.screen stays off
Hi first i will say sorry for that. I will recommend that you see a certified technician to fix it up, there are a few things i guess are wrong with your psp... the system of psp are fragile and should be handled with care because i think one or more parts are broken and need replacement. Cheers
Dec 23, 2009 | Sony PlayStation Portable (PSP) Console
When i turn on my psp the green light turns on but nothing appears on the screen. can you help me?
ur PSP is semi bricked if u have a PSP model 1000 or 2000 u can unbrick it with a pandora battery and a magicmemory stick
Aug 13, 2009 | Sony PSP-3000 Silver Console
Green light but nothing comes on
It seems that inside your PSP the LCD Screen Connection cable (The broad One) which is connected to the motherboard is being loose contact so if you can open the PSP try it by re-fixing the cable again otherwise you better go for a technician who will do the same job for you.
Sep 10, 2008 | Sony PlayStation Portable (PSP) Console
PSP not turning on
My PSP stopped turning on and when the charger is plugged up it gives me the green light but thats it, should i try a new battery???
Jun 06, 2007 | Sony PlayStation Portable (PSP) Console
Sony PSP-3000 Silver Console Logo
142 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
