Question about LG Vu CU920 Cellular Phone
MY TOUCHSCREEN STOPPED WORKING OUT THE BLUE . IT WONT RESPOND TO WAT I PRESS . I CANT TEXT AT ALL
My touch screen is all wonky its not responding to anything I'm trying to do with it and its doing things that I'm not doing it's basically made my phone useless at this point
Tf810c Touch screen wont work ' TabletPCReview.com - Tablet PC ...
forum.tabletpcreview.com > Forums > Windows Tablet PCs > Asus
Feb 24, 2013 - 10 posts - ‎4 authors
If it's greyed out, there is no data to reset, and it's not that causing the issue. ... wentall wonky, swipe for charms wont work, can select anything ... I tried the hard reset and low and behold my touchscreen started working again.
Nexus 7 (2013) erratic touchscreen & keyboard - Google Product Forums
productforums.google.com/d/topic/nexus/W0Hfkq8hf-c
GoogleJul 30, 2013 - I've used some touchscreen test apps and "ghost" touches would ... Myoriginal Nexus 7 (2012) didn't do this, nor did my Gnex or any of ... If it's software, I don't mind hanging onto it until a fix is released. ...... I can't believe no one has saidanything about the touchscreen not responding at all to touches I've ...
XPS 9530 touch screen stops responding (how to fix) - General ...
en.community.dell.com/support-forums/laptop/f/3518/t/19534511
Dell
Dec 1, 2013 - 15 posts - ‎7 authors
Dec 16, 2015 | Cell Phones
My v touch pro touch screen wont work
b> The Touch Pro2, manufactured by HTC, is a smartphone designed to be used with the Verizon wireless phone network. This smartphone combines a cell phone, PDA, MP3 player and wireless Internet access into a small, portable device. If the device begins malfunctioning or freezing, you can perform a soft reset. A soft reset does not delete any of your saved information. It shuts the phone down and reboots the phone to the Verizon Today Welcome Screen.
Pull the stylus upward to remove it from the side of the phone. Push the back cover upward using your thumbs until it pops from the back of the Touch Pro2 phone. The back cover can then be lifted away and removed from the phone. Press the "Reset" button, on the upper, left side of the back panel using the stylus tip. The device will now restart and display the Verizon Today screen. Snap the back cover back onto the back of the phone. Touch Screen is Not Working
As most tablet PCs ,Phones and Mp3 players are full touchscreen devices, you use your touchscreen for everything you need to do on your Tablet PC. If the touchscreen stops working, you can't get much use out of your Tablet. Touchscreen issues are caused by hardware or software problems, but check with your manufacturer before attempting a DIY repair.
Hardware Issues Damages to the surface of your Tablet PC can cause the touchscreen to malfunction or stop working entirely. For example, putting pressure on the screen, such as placing the Tablet PC in a bag with other heavy items, can cause cracking along the screen. Exposing the screen to water, even in small amounts, can cause the electrical system within the touchscreen to malfunction. If the electrical system malfunctions, the touchscreen stops working properly. b> Screen Sensitivity b> Pressing the touchscreen on your Tablet PC sends a signal to the internal motherboard. The motherboard then transmits to other components, such as the hard drive. The accuracy of the touchscreen depends on the screen's sensitivity. Many Tablet PCs include a program for calibrating the touchscreen. This program may fix minor responsive issues. Even a small amount of dirt or debris can effect how the touchscreen responds. Cleaning your touchscreen with an electronics cleaner or a microfiber cloth may help improve sensitivity. b> Software Issues b> A driver is a software program that interacts between hardware devices and an operating system, Your Tablet PC needs the right drivers for your OS to work correctly. Outdated or missing drivers can cause the touchscreen to work improperly, or not respond at all. Visit the manufacturer's website to find the right drivers for your Tablet PC. b> Repair b> While you can perform some minor repairs yourself, such as re-calibrating the touchscreen sensitivity or installing drivers, only perform a hardware repair if you have a good working knowledge of electronics, specifically Tablet PCs. Before attempting to repair your device, contact your manufacturer. If your Tablet PC has a warranty, completing an unauthorized repair may make you ineligible for claiming that warranty. Hope this helps
b>
Jan 20, 2013 | Visual Land V-Touch Pro (8 GB) MP3 Player
IBM thinkpad wont work
Try to get hold of a bootable xp pro disk and boot from it, when finished loading the initial drivers and files onto the system gointo the 'R' option recovery console, this is a command line recovery, once there type chkdsk c:/f and press enter let it run its coarse and then restart pc.
Jan 21, 2010 | IBM ThinkPad R31 2656 Notebook
LG Incite touchscreen not responding
try to reset the phone by picking the reset hole on the side of the phone (i use a staple) the touchscreen should be a bit better to press the unlock button. hope this helps!
Nov 16, 2009 | LG Incite Cell Phone
Xenon Touchscreen stopped working
There is no way. My touchscreen has stopped working several times and everytime fixes itself after a few hours. DO NOT let this phone ANYWHERE near moisture or water, the touch screen is very sensitive.
Jul 17, 2009 | LG Xenon GR500 Cell Phone
LG viewty Touchscreen problems
I have the same problem. But i had solved it. I use a lighter to burn on my viewty's touch screen, and it is working properly again within 30 secs. And ofcourse, do not burn the touch screen without a screen protector. Hope this solution would help.
Aug 12, 2008 | LG KU990 Viewty
LG Vu CU920 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
