Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Wall mount button LED is flashing, remotes won't work, door won't close unless the wall mount button is held down until the door is fully closed
    President:
  • 3,197 Answers
Sounds like you have a couple problems. First of all press and hold the button on the wall control that has a lock icon for 3 seconds and release. This should take care of the flashing LED and the remotes will now work. Having to hold the button on the wall control until the door is closed is usually a problem with the door sensors. Make sure they are pointed at one another and the small light on each is lit and not flickering.
Posted on Nov 16, 2009
The door won't close unless only the wall button is held until the door is fully shut
You have an obstruction blocking the laser ray for the door close cycle to complete
OR, there is an electronic malfunction of the sending units just mentioned.
Feb 12, 2016 | Building Materials
My liftmaster formula1 opens everytime but only the wall button will close it. Once in a while a remote will work but rarely. I have one remote, one vehicle oem remote and a wall mounted remote outsid
does it attempt to close. stop go back up and the lights flash....if so check the safety eyes, check for boken spring/ springs using the wall mount button circumvents the safety system. check the down pressure setting.
Nov 15, 2014 | Building Materials
My Chamberlain 41A5389-1B 1/2HP door opener will only close via the wall push button when it is held down until door is fully closed. Will not close with remote, when using the remote it will start to...
Have you checked the tracks on both sides? If the door closes when you hold the wall button there may be an obstruction or a bad guide. This could exert enough resistance to make it stop and reverse. Holding the wall button allows it to keep going past the problem.
Apr 28, 2017 | Sears Craftsman LiftMaster Chamberlain...
My Lift Master remote does not work. The wall mounted unit will open and close the door, but the remote control does not. I've changed the battery with a 1a battery from Radio Shack- but it still won't...
Check the wall console. If it has a lock button and the LED is flashing, the GDO is locked. None of the remotes will work, only the wall button. If it is locked, press the lock button and hold for a couple seconds and release. The LED should stop flashing, and the remotes should start to work.
If the door will open but not close, and the lights flash 5 times, check the door sensors. Make sure the sensors are aligned with each other, and the LEDs are both on.
Jan 11, 2011 | liftmaster 373lm Liftmaster Craftsman...
Garage door won't close unless I hold down the wall button until it is fully closed. Checked the L.E.D light at motor and it flashes 2 times in about 8 seconds. Sensor with amber light is on, other does...
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
Oct 09, 2010 | liftmaster Chamberlain Garage Door Opener...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Must hold wall unit to close garage door...
there is an error in the system. most likely The safety beams (mounted on the track near the floor) are out of alignment and the LED light should be blinking. The garage door opener will not let the door close if the beams are misaligned. Realign them and the LEDs on the beam or on the operator will stay on. you should be able close the door now with one push.
Apr 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
SEARS/CRAFTSMAN 53628SRT Not Closing properly
sounds like the safety door sensors are at fault,also did you reprogram the remotes by pressing the smart button on the logic board,when the safety sensors are bad the door will reverse to open state.you can pully the rip cord to manualy close the door untill you solve the problem.
Sep 04, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
374 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
