Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
I have a Lacie external HD 500G which we installed approx. one year ago. It was working great . However recently the mother board in our computer failed and was replaced with a new m-board. Essentially we now have a new computer. After bringing our computer home and pluging the Lacie HD in we are unable to access data which we backedup on it over the past year. When we attempt to open that drive(J) we are advised that the drive is not formatted - do you wish to format now. Will we loose our data if we proceed with the formatting as suggested. How should we proceed to get access to this drive. Thanks Kevin
    President:
  • 1,884 Answers
Kevin, Yes you will loose al data if you format it.DO NOT FORMAT as you have your data on it. What I suggest is to get the motherboard of same old model that you replaced. Sometimes the motherboards do not play up with all the hardware. Get the same model motherboard that you replaced. Once that works, copy all data to some other HDD. Or better still send the data in bits by email to yourself. The data would be safe on the email server. And can be retrieved later when all is well. OR attach the drive to some other computer where it works and send emails to yourself. Long and tedious job, but will save your data. And when the drive has started working with your new computer after formatting or otherwise, you can retrieve all the data. and delete the emails from the server.
Posted on Nov 16, 2009
My 500G Lacie external drive is no longer detected by windows. Sometimes it will say the USB port or device is mulfuction. Sometimes it does not detect it at all.
Does this happen in several computers? If it does, then the interface is probably damaged, in which case you could (at your own risk) disassemble the drive and install the hard drive inside a desktop computer to access your data., since theres a standard SATA hard drive inside.
Mar 21, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
External no longer recognized
Right click My Computer, Properties, then click on Device Manager.
Select Disk Drives then on tab menu Action, Add legacy hardware. Go through the setup and use CD's that came with Hard Drive otherwise search company site for drivers.
Oct 05, 2009 | SimpleTech 500GB SIMPLEDRIVE EXT HD-USB...
Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Sep 12, 2009 | LaCie F.A. Porsche (301177) Hard Drive
Lacie HD power light flashing yellow and orange
Hi. Sometimes, there are compatibility issues on external drives. Most recent computers will read them while others may not. Either the external casing or the cable is causing this.
Aug 27, 2009 | LaCie (300728U) 250 GB Hard Drive
Lacie 1tb external hard drive into ps3 is not regconised
I have the same issue, however with my verbatim 500g its ok. i believe it is because the lacie is a desktop external and therefore is compatable with windows xp and 7 alone.
Verbatim is a "portable" external hard drive which makes it compatible with several different systems. I would suggest returning it, I just formatted my old verbatim harddrive and set up mediaasharing. Through my router. You can actually route the lacie harddrive by going to my computer and right click the icon. Next go to share with; advanced settings and allow all. Then when you turn your ps3 on search for media servers... I would suggest to google media server for ps3 to get it all seet up. GOOD LUCK
Jun 07, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
LaCie 200GB HD is now ''read-only''. Recommends reformatting.
>> my computer could not repair the hard drive
It seems that the disk-drive is "dying", and the "table of contents" on the hard-drive has become corrupted, and automated attempts to "repair" the corruption have failed.
>> the hd is being offered with limited functionality, basically read-only.
Yes. Take this as a "hint" that the disk-drive is about to "die".
>> It recommends that I back-up the info elsewhere
Good advice. Take the advice.
>> and reformat.
This may help -- it will identify any "bad" spots on the hard-drive, and will either permanently avoid using those bad spots, or it will allocate a "spare" track on the drive to be used as a substitute for the "bad" area.
However, even after doing this, I would not "trust" the device to be a "reliable" backup for my important files. Like a well-used chalk-board in a classroom, the disk is getting "worn-out".
If it's still under warranty, exercise the warranty.
If the warranty has expired, replace it.
Apr 22, 2009 | LaCie Computers & Internet
Lacie external HD problems
I would suspect your USB drivers. Go into device manager and remove (uninstall) any device under the USB heading. Reboot and see if it works better. Also I would try the drive on another computer to make sure it is working find and try a different USB cable just in case.
Jan 17, 2008 | LaCie (300770) 250 GB Hard Drive
LaCie Design by F. A. Porsche 160 GB not showing on MacBook Pro
The first thing that I would do is try connecting the drive to different USB Ports. If that does not work see if there is any software that came with the drive or that you can download from the internet that you might need to get the drive working. Next I would connect it to a different computer to see if it works that way. If it works when connected to a different computer I would at least get the files on to that computer and transfer them to the computer that you need them on using a network connection, a CD/DVD, or a USB thumb drive.
Nov 07, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
LaCie 500GB external HDD stoped working ?
It sounds like its an internal problem with the pcb board inside,which may not be an actual problem with the hdd it self but the mother board.my advice would be to change the board that links between the hdd and the usb cable.
Jul 19, 2007 | LaCie (300728U) 250 GB Hard Drive
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
451 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
