Ectaco translation software for Palm Tungsten e
We have the several dictionary programs for our Palm. The power went down, and now we cant get the dictionary(s) to work. Phil Evans [email protected] 202-255-5839 cell
  • 4 more comments
  • philevans Jan 09, 2008
    I do not feel comfortable removing the back, even if I did have the proper tools, which I don't. What else can you suggest. I tried a soft reset already.
    Phil
    I think I tried reinstalling it. But maybe did not do it properly. Do I have to first Uninstall, then reinstall?
    Yes, Palm Tungsten E. No, just pushing the reset button on the back with the pointer. How do I uninstall the program from the Palm. Should I try holding down the power button/reset first?
    A hard reset didn't work. Let's try a uninstall/reinstall. How?
    No, they reloaded when I did a hotsync. Should I not have done that?
  • philevans Jan 12, 2008
    Nothing is working. I even tried to install a new dictionary program, and that is giving error messages. Maybe if I try a hard reset, and then just load one program at a time. Help !!!
    Sergeant:
  • 264 Answers
You may try small step known as fleepower. To do so you need to turn off the Palm. Remove the power sources like Battery and the power adaptor. Than press and hold the power button for 20 seconds. Put battery and the Adaptor back and turn on the palm and try using the dictionary again.
Hope this solves your issue, or else i will give you more steps than.
Sammy
Posted on Jan 09, 2008
    President:
  • 1,950 Answers
What happens when you try to run them? Did you try reinstalling the programs?
  • 7 more comments
  • Damen Wong
    Damen Wong Jan 09, 2008
    Yes, you should uninstall and then reinstall.
  • Damen Wong
    The model you have is Palm Tungsten E? Correct?
  • Damen Wong
    When you say soft reset, do you mean holding down the power button while you press the reset button on your unit?
  • Damen Wong
  • Damen Wong
    I think the hard reset will most likely solve your problem as it wipes out everything on the device. That would allow a new clean installation of your programs. Make sure you back up everything important first.
  • Damen Wong
    Did the hard reset get rid of the program? The program is not supposed to be there after the reset.
  • Damen Wong
    Are your dictonary programs built in?
  • Damen Wong
    I see...
    I suggest you uninstall and then reinstall the hotsync program.
    Before you do that, do you have the setup files of your dictionary programs? In what format are they?
  • Damen Wong
    Damen Wong Jan 13, 2008
    Do a hard reset again. Uninstall the hotsync program and wipe out all data. Then reinstall the sync program and then reinstall the dictionaries. Also, install each program one at a time.
6ya staff
SOURCE:
Doesn't turn on
Did you drop it, and when you shake it, it makes some kind of rattling noise? then you probably broke it.
Jan 27, 2014 | Ectaco Partner ER-X8c Dictionary /...
Cannot torn on
Call Ectaco for service location.
Sep 09, 2013 | Ectaco Partner ER-X8c Dictionary /...
Ectaco-partner lux er-user manual
Where I could take manual for my Ectaco Partner LUX
Jun 26, 2012 | Ectaco Office Equipment & Supplies
Where can i buy the rechargeable battery for Ectaco Partner X5?
You may have to contact Ectaco customer support they may be able to provide
you with a replacement battery. It seems like you should fill out this form -
http://www.ectaco.com/support/
Feb 16, 2011 | Ectaco Partner ER850
Can I use my ectaco partner dictionary on my laptop? How do I install it?
My Partner P900 series is completely separate from he computer. You can only connect the two to add movies or music onto the partner. I think that was the idea Ectaco was going with, it is a self sufficient language device.
Feb 16, 2011 | Ectaco Office Equipment & Supplies
Restriction code nokia 5130 c-2 imel 359329029445376
you should remember your mobile code.if forgot then go to to the moblie software shope and tell the man there put new software in it.
Mar 06, 2010 | Ectaco Romanian English Talking Dictionary...
Partner x8c problem
I have a problem with my Partner X8c translator, which scren after three years of using stopped to work properly. The batteries are new. Do you know any repair service opportunities? I want avoid buying just a new translator as they are really expensive and should be able to work longer then three years.
Aug 11, 2009 | Ectaco Partner ER-X8c Dictionary /...
The translator does not switch on any more, (out of the blue)
Outlook not good.
Ectaco is adamant that all repairs must be sent directly to them. They do not authorize anyone else to perform repairs.
As a result, no one else can obtain parts or service manuals to repair these devices. So there are no other options for repair worldwide- only shipping the unit to Ectaco's Service Center in the United States (and only if it is under warranty).
You could try posting your problem on the Ectaco User Forum to see if any other users of this translator have a solution.
You will see many other users on the forum that are in your same situation, and most of them are equally frustrated.
Though I have not been able to personally fix your problem, I hope the information provided will be helpful in some way.
Mar 05, 2008 | Ectaco Partner ER-X8c Dictionary /...
Need battery for a gd-986 translator
You might buy 4AAA batteries.I did, it worked.
Aug 10, 2007 | Ectaco GD986 Dictionary/Translator
Computers & Internet Logo
99 people viewed this question
Ekse
Marvin
Marvin
