Question about Dishwashers
Hi, I had to clean the lime build-up and all the crud, so I disassembled it down to where you could see the disc cutter. I re-assembled it and now it leaks water above the motor when it calls for water. Also the gasket thats in the discharge housing is loose.
  • Dishwashers Master
  • 5,603 Answers
A lot of gaskets are one-time use. Hopefully you replaced the gaskets with new ones when you reassembled the unit.
Water over the motor is very bad, for one it will wreck the top bearing.
Posted on Nov 16, 2009
How to clean lime
You should call your vendor for service.
*** the following is for information only ***
* Lime build up is caused by heated water standing and cooling off or drying out as it stands.
* Daily wipe down of equipment and removal of standing water puddles help minimize this build up.
* washing pots daily will remove coffee stains and prevent build up.
* Do not allow pots with coffee or water to sit overnite on warmer plate.
* Internal lime requires a qualified tech to disassemble equip to service.
* check bunn.com for free download of manual and cleaning instructions.
Aloha, ukeboy57
Jan 08, 2014 | Bunn Coffee Makers & Espresso Machines
I have a Maytag MDB dishwasher. We recently took apart the spray arm assembly down to the filter to clean out the lime. The problem is that the inside of the spray arm has such a build up of lime and we...
have you tried boiling it in vinegar? it might help. no garenties for that particular problem, but that's what I do with my kettle and chunks of lime come out when I do.
Jul 18, 2009 | Maytag MDB9600A Jetclean II Built-in...
LIMESCALE BUILD UP
To prevent lime build-up, use distilled water instead of tap water. I buy bottles of distilled water for use in my irons and steamers and have never gotten calcium or lime build-ups.
You can buy a product by the name of CLR (stands for Calcium, Lime & Rust) which can be found at stores such as Target, Walgreens, CVS, Walmart, etc.) to wipe the build-up from your iron. You can also run this solution through your iron to clean the build-up from the inside.
May 12, 2009 | Irons
My zebra 4M+ get me a cutter jammed status
Sometimes debris builds up in the bottom of the cutter assembly preventing the cutter from going all the down. There is a switch inside the cutter which trips the "jammed" error if the cutter can't go all the way down. The cutter can be removed and disassembled to remove the problem. Caution should be exercised. There are washers and springs on the cutter face plate guide screws which have to be removed.
Mar 26, 2009 | Zebra Z4M Printer
Clogged water dispenser in Bosch dishwasher
Hi, Logmanup (slight bouts with dyslexia, sorry)
By "spinning water dispensers", I assume you mean the spray arms, right? OK... if they are getting clogged with debris it would be nice to know what kind of debris. Pieces of broken glass? Plastic? Lime scale? Iron? And yes, when they get clogged they won't rotate, won't allow pressurized water through and therefore won't clean the dishes.
For the purpose of this solution, I'll assume that there are little white particles clogging up the jets on the spray arms. This indicates hard water and lime scale build up.
Other than completely disassembling the entire motor/pump assy. (you really don't want to go there), the best way to clear this out of the system is to use an over the counter chemical called Dishwasher Magic or something similar. If the lime scale build up is really bad (and it sounds like it is), use a couple of bottles to start with and follow up with a bottle per month thereafter.
As an aside... If I assumed correctly about the lime scale build up, that means that it's also affecting other appliances as well. Mainly, your hot water heater. If you haven't done it before, please read this to perform maintenance on it. And a product something like this for your washing machine.
I hope this was helpful. Let us know if this works or not. If not, please write back and we'll go a little deeper.
Mar 12, 2009 | Bosch Dishwashers
Upper rack not getting clean
The problem likely is the cutter/chopper filter.
1. Remove bottom basket. Remove top basket (Pop off 'keepers' at the ends of the slidding shelf supports).
2. Remove bottom washing arm. Unscrew (Gently but firmily) centre post. Lift arm assembly out.
3. Remove overhead conduit. One screw at back and one at top (Philips #2 screwdriver bit). Rotate whole assembly 45 deg to the right (Clockwise) and lift off of centre post It can then be taken apart to clean.
4. Remove centre post (Pull straight up) Remove 4 screws (Star T-20 screwdriver bit). Lift whole plastic assembly out. Pop off the screen (Flat blade screwdriver around the edge) and clean.
5. Remove cap over cutter/chopper. There is a single screw at left front (Under the just removed centre assembly). Remove (Star T-15 screwdriver bit) screw and cap (Needs a bit of wiggling to get it free). Remove cutter and filter ( a stainless steel disc with many holes in it). Tt is on a spring loaded pin. Pull the cutter blade foreward and lift the filter straight up. Clean thoroughly. I then ran a 'quick rinse' cycle with everything out, to clean the inside.
6. Reassemble - Good luck! This worked for me.
Jan 02, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
How to take apart the diswasher to clean it
This is a 5 step process.
1 Remove bottom basket. Remove top basket (Pop off 'keepers' at the ends of the slidding shelf supports).
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly out.
3. Remove overhear conduit. There is one screw at the back and one at the top (Philips #2 bit). Rotate the whole assembly 45 deg right (Clockwise) and lift off of the centre post. It can be taken apart to clean.
4.Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift the whole plastic assembly out. Pop off the screen (Flat blade screwdriver around the edge) and clean.
5. Remove cap over cutter/chopper. There is a single screw at the front left (Under center assembly just removed). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter & filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc up. Clean thoroughly. Run a 'quick rinse' cycle with everything out, to clean the inside.
Reassemble.
Jan 01, 2009 | Kenmore 15129 Built-in Dishwasher
Dishes don't get clean!
The problem is probably that the chopper/cutter filter is pluged. It needs to be cleaned
1. Remove bottom basket. Remove top basket (Pop off 'keepers' at the ends of the slidding shelf supports.
3. Remove overhead conduit. One screw at back and one at the top (Philips #2 bit). Rotate the whole assembly 45 deg to right (Clockwise) and lift off of the centre post. It can then be taken apart and cleaned.
4, Remove centre post (pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off the screen (Flat blade screwdriver around the edge) and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (Under assembly remover in 4. Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter & filter. It is on a spring loaded pin. Pull the cutter blade foreward and lift the filter disc straight up. Clean thoroughly. I then ran a 'quick rinse' cycle with everything out.
Reassemble.
Dec 29, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
My kenmore dishwasher isn't cleaning the dishes very good
Your broblem is probably the cutter/chopper filter. This is located under the bottom cleaning arm assembly.
Remove the baskets.
Remove the bottom washing arm. Unscrew the centre post and lift off the arm
Remove the conduit to the top arm(s). Remove screw at top and at back. Rotate the conduit assembly 45 deg right and lift off.
Remove 4 screws (Star T-20 bit) and lift whole assembly out. Pop off screen and clean.
Remove cap over cutter/chopper. There is one screw at left front under assembly just removed. Remove it and the plastic cap (Needs some wiggling to free it up). Remove the cutter and filter. It is on a spring loaded pin. Pull in foreward and also lift the filter disc up and out. Thoroughly clean the filter.
Reassemble
Dec 01, 2008 | Dishwashers
Kenmore 655 ultra wash built in dishwasher
Possible problem is that the chopper/cutter filter is plugged. This prevents water circulation and therefor no water is available for cleaning.
Solution:
Remove the dish baskets.
Remove the bottom cleaning arm - Rotate the centre post and the arm can then be removed.
Remove the conduit that feeds the upper arm(s) - Remove screws, one at the back and one at the top. Rotate the whole assembly 45 deg right and lift off of the centre post.
Remove 4 screws in the plastic assembly and lift it off of the centre.
Remove 1 screw at left front (Under assembly just removed). Lift off the plastic cap which covers the cutter/chopper. Remove the chopper. It is on a spring loaded pin. Pull the cutter foreword while lifting the filter disc straight up. Thoroughly clean the filter disc - a knife will be req'd to scrape in clean.
Reassemble in reverse to the disassembly steps.
May 05, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
