Why can't i install printer 5150 on windows 7
There's a possibility that Lexmark X5150 does not support the Windows 7 operating system as of the moment. I checked the Web and I could not find any driver for Windows 7.
You need to contact the manufacturer and verify with them if it does support Windows 7 and if yes, then you may ask for a driver for it.
If there's no driver available, that's an indication that it's beyond their support.
Thank you!
Hello there,
Currently, with the X5150 model, there are no drivers specifically for Windows 7. But you can use the vista version which Lexmark advised that would work.
http://www.downloaddelivery.com/downloads/cpd/cjrX5100EN.exe
SOURCE: HI, my laptop is running
First, make sure that you have downloaded the correct drivers and installed them correctly. Drivers are available for two versions of Win 7, 32 Bit and 64 Bit. Click here and make the selection accordingly (32 Bit or 64 Bit).
Secondly, make sure that the printer and cable are functional and when you connect the printer to your laptop, windows detects it. If windows is able to detect the printer, it should work, otherwise the problem could be with the printer or cable.
Let me know if any further clarification is required. Hope this helps! Dont forget to rate the solution!!
CreativeTECH
SOURCE: my windows 7 laptop shows
HP Deskjet 5150 is highly compatible with windows 7, so no issue for the operating system. Now we check the driver for your printer if it has the latest updated software if it does then there is no issue.
