Question about Canon PIXMA MP530 All-In-One InkJet Printer
Service mode #1 BIT SWITCH
Hello, i receive this possible error (or i don't know what to say):
service mode #1 BIT SWITCH
What should i do ?
  • 2 more comments
  • bebef Jan 09, 2008
    after i unplug, 2 min, that error disapear but, i receive the second error, Lik Low Mergenta. If i will try to push 5 seconds the Stop/Reset button, i believe the" service mode #1 BIT SWITCH "
    error will apear again.
    i refill the cartrige. If this will apear everytime i refill a cartrige, that means it will be easier to buy one new.
    I don't think this is the best idea.
    i refill the original cartrige.
    thanks for trying
    President:
  • 4,402 Answers
Unplug and wait 1hour and try again
Posted on Jan 09, 2008
  • 1 more comment
  • Cary Farah
    Cary Farah Jan 09, 2008
    replace the megena ink before proceeding.
  • Cary Farah
    are you refilling or replacing cart? i recommend replacing with original cart manufactures only. not refill ot other manufacturers cart.
  • Cary Farah
    try a new one.
How do i solve an error e000-0000 canon ir 2002n please
Description
The main thermistor reading does not reach 40C 14 sec after the fixing heater goes ON (fixing low temperature error)
Remedy
1) Wiring Is the connection of the connector (CN8) on the power supply PCB and the connector (J103) on the DC controller PCB and the wiring to the fixing assembly normal? NO : Correct the connection and wiring. 2) Fixing assembly Try replacing the fixing assembly. Is the fault corrected? YES : End. 3) Power supply PCB, DC controller PCB Try repacking the power supply PCB. Is the fault corrected? YES : End. NO : Replace the DC controller PCB. 4) Error With the power switch ON, clear E000 through E004; then, turn off and then on the power switch.
Aug 05, 2015 | Canon Office Equipment & Supplies
How can i reset a system error E007
Good answer here:
http://www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
<quote>
How to reset E000, E001, E003 and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" than Press "Stop" or "Additional Function key" to end service mode or restart the machine.
</quote>
Jan 20, 2015 | Canon IR2020 Copier
Sc fusing error dsm615
you can try to reset the code by entering into service mode, just enter into service mode and then shut down the machine by the main switch and then turn it on after 30 seconds.
For to enter into service mode press the following keys in the next order:
press the yellow key ; then press 1-0-7 and then press the red key and hold it pressed until on the screen do not show service mode.
If after this again the machine gives fusing error, it means that you have problem some part in the fusing unit. possible is the termistors or the teromstats
Nov 23, 2013 | Ricoh Aficio 2015 Copier
System error E000 of canon mf4100
I think you need to reset....
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key. Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1). Press "OK" than Press "Stop" or "Additional Function key" to end service mode or restart the machine.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Dec 14, 2012 | Canon imageCLASS MF4150 All-In-One Laser...
How can i cancil error 0004 ?
To clear the error code you must enter service mode level 1 first. Once in service mode you choose in the following order Copier>Function>Clear select ERR and push ok. At this point it would apprear nothing has happened but in fact the error flag has been cleared. Shut the machine off. Now turn on. If your error was minor and your cleared the cause of your error E000004 then the machine will operate as it did before the flag went up. If you get the error code again look for a Canon trained tech in your area to correct the issue. If you do not know how to get in to the service mode level 1 your best to search for entering service mode canon. As I don't want to promote persons without expertise entering the machine service and adjusting things without any backgound. Good Luck
Jun 25, 2011 | Canon imageRUNNER 5000 Copier
What does "nd" mean on my neptune washer
Hello tana_carney4,
Your in the FAV6800AW forum so I’ll assume your machine type is a FAV6800AW or FAV9800AW. I’m an owner of the FAV6800AW with some hands on experience with the machine.
The ND error code equals No Drain. The microprocessor on the Control Board keeps track of the time needed to receive a Low/Mid Level fill indication from the pressure switch at the start of a tub drain cycle. If that time elapses and the pressure switch is signaling that the tub has watering remaining then you trigger the ND error code. Is the tub empty or is there standing water in the tub with the ND error code?
If the wash tub is empty and you fail out of the wash cycle with the ND error code then I feel you have pressure switch failure, the pressure switch is signaling the Control Board incorrectly. We need to go into Service Mode “Board Input Test “ and check if the pressure switch is signaling a -1 with an empty tub (no water). If rhe pressure is signaling a -1 with an empty tub then the pressure switch is false signaling “Stuck Pressure Switch” you will error out in the wash cycle with the ND error code and the Pressure Switch will have to be replaced.
If the wash tub has standing water in the tub with a ND error code to the console we need to check for a failed drain motor, a drain pump impeller jam/clog. We would go into Service Mode turn the drain pump and listen. Do we hear the drain pump turn on? If so will it pump out 5 gallons of water in about 25 seconds or less as my working FAV6800AW will do? Further troubleshooting will require a DVM to verify that 120VAC is applied to the drain pump, If we have 120VAC at the drain pump motor connections and we don’t hear it turn on we would need to remove the drain pump and check for failed motor or jammed impeller. If the drain pump turns on but we have slow drain out of the drain pump we could would need to remove the drain line from the Sump Cap to the inlet of the drain pump and check for restrictions and possible impeller damage to the drain pump.
The question is do you just want know what the ND error code is?
Do you want to DIY the repair? If not then it would be time to call in a repair service.
Here is the FAV6800A/ FAV9800A Service Manual link.
If your machine type is not a FAV6800AW or FAV9800AW then please disregard my post.
Rich aka dh1200s
Nov 18, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Error code F-36-2
Konica 7022 showing code f-36-3
Jan 28, 2009 | Office Equipment & Supplies
Konica 7020 Printer
HI,
you need to reset the fuser latch as it has a fuser error code most likely needs new thermisters,
anyways give this a go, hold down 2 and 5 keys together and power on machine, this will put you into to a service mode call 25 mode, go to dip switch 3 and bit 1 and then next to bit 1 hit the key that says turn off,
turn machine off and back on should clear error code, if it doesnt you need new thermisters, even when you put in new thermisters you still need to clear this error in service mode
Regards
Konica Tech
Feb 15, 2008 | Office Equipment & Supplies
Error SC940
SC940 - Main Switch Abnormal (U.S.A. version only)
Definition: [level: A]
The Main switch does not turn off after sending the reset signal two times
in a row.
Possible causes:
· Main switch
· Main PCB
You must enter em SP mode and then turn off the main switch and on again.
Entering in SP mode:
Enter SP mode as follows:
1) Press the clear modes key.
2) Enter "107".
3) Press the clear/stop key for more than 3 seconds
Then turn of the machine, don't play around in the SP mode u can damage the Ricoh
Nov 05, 2007 | Ricoh Aficio 450 Copier
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
134 people viewed this question
old marine
old marine
