Question about Sony PlayStation® 3 (80GB) Console
Seem to have the connections right but will not play back in digital w hd tv and kenwood rec w dolby dig and dts
  • pickmynose May 11, 2010
    What kind of cable are you using? AV / S-AV or HDMI
  • 281 Answers
The ps3 does not automatically detect AV cables like it does with HDMI. You have to set your console back to the original factory settings for video. The way to do this is turn your console off all the way, even in the back. Then before you turn it back on put your finger on the power button in the front. While still holding the power button in the front, turn your console back on in the back. Continue holding the button until you hear several beeps. This should set it back and you should have picture again. It may take several tries if you have never done it before. If you have any other questions feel free to contact www.wiredextreme.com
Posted on Nov 16, 2009
Testimonial: "actually to fix my problem i jst put the optic cable in the cd/dvd port on receiver and it worked. "
How do I get audio from tv to receiver?
There should be audio output's on your TV and cable box. There are usually multiple options on most newer model a/v equipment. If u check the manual look for the page showing you about the various connections on the back, you're lookin for anything to do with audio output, there are many different types optical, digital, and analog. Again depending on your specific equipment there's almost always at least one way you can connect them
Feb 15, 2015 | Pioneer HTP-071 5.1 3D Home Theater System...
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
How should I connect my denon avr 1906 to my 32" ES6300 Series 6 SMART 3D Full HD LED TV Model numberUE32ES6300U in order to get dolby digital from the tv's tuner please?
Use an optical cable.
Be aware though. Your TV has a DVB-T tuner. It picks up the Freeview standard definition (SD) channels, but not the Freeview HD ones. Dolby Digital sound only comes from the Freeview HD channels.
Your TV will pass Dolby Digital from any source connected to a HDMI port to the Optical Out. It will also pass DTS. But the internal Freeview DVB-T tuner doesn't generate Dolby Digital, just stereo and stereo with Dolby Surround encoding where you use ProLogic II for decoding.
Sep 08, 2014 | Denon AVR-1906 Receiver
Onkyo HT-S3400 not showing DTS-HD Master Audio
Hello, with the source playing press the display button on the remote. What format do you see? Thank you, CB
Apr 05, 2017 | Onkyo 5.1-Channel Home Theater Package...
Got a Kenwood vr405 surround receiver, a Sanyo plasma TV, hd cable box and an insignia blu ray player. Both the cable box and the blu ray player are connected via hdmi to the TV and the TV is connected to...
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Jan 14, 2010 | Kenwood VR-405 Receiver
Does kenwood VR-405 play DTS-HD Master
I have the 405 and a Samsung 3600 which has onboard DTS Master/ Dolby True HD. Out of the 6 movies I 've watched, only 2 have given me Dolby Digital. Bottom line: If the movie doesn't have DD, you cant get DD on the 405. I thought just about all blu rays had DD but its not so. Its time for us to upgrade!
Oct 24, 2009 | Kenwood VR-405 Receiver
DTS Master HD audio problem
Hey! Make shure your amp and blu-ray player output and input signals are set to "bitsteam" and you are useing HDMI and optical connections. I hooked up my Onkyo tx sr 506 integrated amp to a Samsung BD 1400 player and everthing worked perfectly right out of the box. Perhaps your amp can"t decode DTS HD Master or your blue ray doesn't support it although i think a firmware upgrade may accomplish this. Put on The Chronicles of Narnia Prince Caspian which will DEFAULT to DTS HD MASTER 7.1 and see if it works. It's an excellent source to test your system. Picture and audio recieved 5 stars from Home Theatre magaziene and like i said, either your amp, or player doesn't support it or your interconnects are keeping it from coming thru. HDMI and OPTICAL connects and check your set up for "bitstream" Remember what Todd Rundgren allways said,"Everything will work if you just let it!"
Feb 05, 2009 | Yamaha RX-V663 Receiver
Not showing DTS MASTEr OR DG True HD
In the menu is an option for switching master and true hd on. Standard its of and played als normal dts/dolby.
also: check the input (blu ray?): maybe it is set to only output no high def signals, so the amlifier doest recieve hd sound..
Igor
Dec 14, 2008 | Audio Players & Recorders
I cannot seem to get DTS-HD master to show on the receiver screen
You need to check 3 things:
1) DTS will only work through a digital connection (coaxial, optical, or HDMI) between your receiver and dvd player. DTS and Dolby 5.1 cannot carry a signal over red and white rca connections.
2) After number 1 is solved ensure the reciever is set to the digital channel, your DTS-HD in this case, or in an auto mode.
3) Finally the most important is that the signal is a DTS signal. Start a DTS capable dvd, go to the sound menu and set it for DTS.
Press play and all should be well...
Cheers,
NTIMID8
Dec 13, 2008 | Onkyo Audio Players & Recorders
Dolby Digital Has Stopped Working
i sthe thx dobly digtal button on off or on auto ?
Nov 14, 2007 | Kenwood VR-505 Receiver
Sony PlayStation® 3 (80GB) Console Logo
49 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
