Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Recording more than one VHS onto a DVD
I can't figure out how to record more than one VHS tape onto the DVD. Each tape is only about 30 minutes long and would like to combine them.
    Sergeant:
    Champion:
  • 317 Answers
Try pausing the dvd recorder inbetween tapes, this usually works, otherwise consult your owners manual
Posted on Jan 09, 2008
See pg 14 of the manual. When you are ready to record, instead of pushing the record button on the remote just once, push it multiple times and the various recording times will come up. I just recorded 3 60 minute videos this way onto one DVD. Be sure to set the recording mode (LP/SP/EP) to enough time to cover all the videos you want to put on the DVD. What I haven't figured out is how to write the names of the separate chapters on the DVD, so I just made a disc title that includes all the names. Not very elegant, but works until I figure out how to do it the right way.
Posted on Jan 19, 2008
Recorder stops recording from vhs tapes after about a minute
Some VHS tapes have copyright signals embedded in them. Then when the DVD recorder reads the copyright signal it will stop recording due to it thinking there is a copyright violation happening. Try testing with a VHS TAPE of a show you have recorded off the TV and see if it does the same thing .,
Mar 24, 2016 | Televison & Video
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
I have a Panasonic DMR-ES30V. I've only ever recorded from what I'm watching on the TV to a DVD. I now have a VHS tape that I'd like to record to DVD. I tried starting the dvd to record...
Most Combo Recorders (VHS and DVD) will prevent you from
recording a Copyrighted VHS tape program onto DVD.
Try recording a TV program onto your VHS tape, then
transfer it to your DVD and see if your new DVD recording
will work or not.
Jul 16, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
How do I eliminate 3 minutes of static, that I accidentally recorded from the VHS tape onto the disc. I want to record something after that but don't want 3 minutes of static in the middle of my recording.
besides sitting there to hit stop when the static part starts i would suggest loading the video onto your computer and use a video editing program to edit out the static from your recording - if you load 2nd thing your were going to record you can even put in effects and join them together as a "double feature" if you want
Apr 22, 2011 | Magnavox ZV450MW8 DVD Recorder VCR
Vhs tapes recorded to DVD+R's
try forwarding the tape to the end and then rewind to the start again, this can help to seat the tape correctly on the spindle . the audio track part of the tape is in a specific region on the tape so misalignment may be the issue with those cassettes.
also try to press the tracking up and down when playing the video
May 12, 2017 | Televison & Video
Will not record on a DVD R
what I would do is play the vhs tape for a bit then rewind and press the dub botton only and see what happens. if nada then insert a new blank dvd and make sure its formated.
Apr 05, 2008 | Sony RDR-VX530 DVD Recorder/VCR
VHS to DVD - D-VR4XSU
have u tried the seting on the vcr, you know how u can change the lenght of recording on the vhs
Mar 29, 2008 | Philips Magnavox DVD/VCR Dual Player
Panasonic DMR-E55 Won't Let me Record my own VHS
Hi
This is probably caused by an irregular magnetic encoding pattern being generated by the tape itself. If the DVD recorder does not fully recognise the code, it may incorrectly interpret it as copy protected. If there is any tape flutter or there are tape edits, these can contribute to the problem. In addition to this magnetic imprinting can occur on old tapes that have been stored for a number of years without being spooled. basically wrong bits of the tape get magnetised. You can sometimes hear an echo on old tape recordings caused by imprinting.
You could try the following:
1) If available, try using a different video machine to play back and record from.
2) Whatever video machine you use, put your tape in, fully fast forward and rewind a couple of times, then try your recording again. This is particularly important if you haven't used the tape for some time.
3) If it fails again, check to see if it always fails at the same point.
4) If it does, try winding forward a little and then try to resume recording.
5) If you can record it means that a short section of tape is giving a spurious code to your dvd recorder and confusing it.
6) Use a re-recordable dvdrw to make a master. You won't keep wasting discs if the recording stops. You will also be able to produce another dvd from your master and edit it if your recording ends up in a number of segments.
7) Always use the highest quality setting possible when producing a master.
8) If all else fails, if you have a friend with another dvd recorder, maybe try that.
Have fun....
Jan 21, 2008 | Panasonic DMR-E55 DVD Recorder
Recording VHS from TV/VCR combo onto DVD
This machine does not support DVD recording. Are you trying to make a tape from a DVD, by some chance?...accordianman
Jan 21, 2008 | Panasonic DMRES15 DVD Recorder
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
174 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
