Question about Viking Kitchen Ranges
We have an 18 year old viking range model # vgr 48 6gd. the broiler is not functioning and we were told the dual valve?for the broiler needs to be replaced i don't have the part # and can't even find the model. is there a valve out there somewhere that would work?
SOURCE: My 48-inch Viking gas range
Anyone figure out what the fix for this is??? I just bought a new frigidaire and it's doing the exact same thing!
Posted on Sep 08, 2008
MNTECH
  • 1543 Answers
SOURCE: My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Posted on Jan 15, 2009
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Posted on Feb 26, 2009
localwonder
  • 6784 Answers
SOURCE: oven quit working
Hi. this is common in many old gas range ovens. There is a set of coils that are attached to the gas valve assembly. These coils , when activated and operational, open and close the main and secondary valves in this unit. They are controlled by the main ERC(clock/oven control board). I recommend checking these coils and there respective wiring harnesses. if the clips and wires are worn and corroded, simply replace the entire wire harness.
Now, if the wiring harness and wires that are connected to the coils look good and there are no signs of corrosion on the wires and connector clips, this will confirm that the coils have failed and you will need to replace them.
You can also preform an additional test with a multimeter. simply connect your multimeter or voltage meter to both terminal posts located on the coils. once your meter is connected, start the oven cycle. you should register some sort of current during this test at this time. if the current is sufficient and the coils do not initiated the valve action, this will confirm coil failure. if the meter dosen't register a current during oven operation, this will confirm ERC(control) failure. you will have to replace the Oven control board in this case.
The Most common issue in this situation will most defiantly be the coil assembly and not the control.
Please rate and god bless:)
Posted on Apr 21, 2009
  • 10865 Answers
SOURCE: Broiler won't light
Usually, when an oven won't broil, it's because the broil igniter is weak or burned out. The igniter is a small, round or rectangular device, about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace the igniter or the safety valve. Usually the igniter is to blame.
Posted on Aug 07, 2009
How do I access the gas safety valve for the infrared broiler on Viking VGRC485
under front access toe panel. Remove doors on both sides and remove screws, obviously unplug unit and your valve will be right there between both ovens.
Oct 10, 2013 | Viking VGRC485-6 Gas Kitchen Range
I have a 5 year old Viking stove/oven and am experiencing a problem posted on this website three years ago but an acceptable solution was not provided. Each time I turn on the oven, no matter which setting...
replace the switch
get in an electrician to do the job as diy electricity repairs are *******
if you want the correct answer to your problem that is acceptable to you then you have to provide the answer yourself
the fact is that when anyone has a problem the only acceptable answer is to get in the qualified personal to properly diagnose and fix the fault
Jun 15, 2017 | Viking VDSC365-6B Dual Fuel (Electric and...
Broiler doesnt' turn on, does a viking range need a separate designated electric electrical breaker?
The documentation for this range calls for a 240 volt, 40 amp, dedicated circuit for the electrical supply on 30 & 36" ranges. 48 & 60" ranges require a 240 volt, 50 amp supply.
http://www.vikingrange.com/MEDIA_CustomProductCatalog/m2740207_F20533.pdf
Mar 08, 2010 | Viking VDSC365-6B Dual Fuel (Electric and...
Viking range professional will not broil.Oven works but it will not broil . It is a gas oven
This is your broiler gas valve that has gone out. An easy repair for you, too.
Should you need the parts shipped, please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service. We can get it out next day air to you.
Thanks, Ella
Nov 15, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Viking oven burner not turning on properly
Sounds like your ceramic ignitors have worn out - apparently they are to be replaced every 3-5 years - at least I had a similar situation and this is how it was solved. I have two ignitors in the larger oven & 1in the smaller one. Easy to replace (60$/each) - two wire and one screw each. Issue is when they fail to heat up properly the gas valve doesn't open fully, or won't open at all.
Also I'd clean the burners when in there ... mine corroded a bit and required brass wire brushing. There is a small **** on the burner that had filled in (width of a piece of paper) which prevented the flame from moving to the opposite side of the burner - so essentially only one side of the burner lit.
Oct 14, 2009 | Viking VGIC485-6G Gas Kitchen Range
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
Oven not working
Check continuity on gas valve. the middle connector is common, upper is broil and bottom is bake. Resistance between common and bake should be about the same as between common and broil. I believe you'll need to set the ohmmeter to KOhms (or x1000.
If no continuity between any of the connectors - replace gas valve (not much fun, and part is expensive).
Jan 21, 2008 | KitchenAid KGRC707 Gas Kitchen Range
Viking Range
I'm having a similar problem. I don't know the exact fix yet, I'm just starting to research. Check this link: http://www.applianceguru.com/forum1/1916.html
It sounds like the ignitors are suspect. This may be a weak component for Vikings. This link recommends a Maytag replacement part.
Dec 08, 2007 | Viking VGSC366-6B Gas Kitchen Range
Kitchen Ranges Logo
585 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
paulcarew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
