Question about DeLonghi RT200 Retro 2-Slice Toaster
The lever doesn't stay down anymore, what should I do?
What kind of a screwdriver do I need to open a Delonghi CT02R two sliced toaster
thank you
Posted on May 02, 2013
  • 34 Answers
It sounds like the latch is broken. Unless you are very comfortable opening appliances and know very well what you are doing, it is best to have the toaster replaced. Check if it's still under warranty, or buy a new one.
Any workarounds to block the lever in its down position are very dangerous and a potential fire hazard. You may be able to wiggle the lever into place so it catches whatever is left of the latch, but make sure it will pop up easily when the toast is ready.
I hope this helps.
Posted on Nov 16, 2009
Repair of model 553 krups toaster over. Lever will not stay down to toast
if there is a open circuit the lever will not stay down. hold the lever down check if the elements glow , most times it costs more to fix then a new one.
May 05, 2018 | Krups Toaster Ovens
Pontiac g6 seat recline lever won't work anymore
remove seat(s) and check for obstruction in the mechanism path. You'll need a big Torx bit.
Mar 22, 2014 | 2007 Pontiac G6
I have an Elna 2730. the feed dog is not transporting the fabric anymore and the needle just keeps stitching in the same place. is it broken or just needs adjusting?
if you have a manual, look to see where the feed dogs are, if the lever for the feed dogs is in the up position then the machine will sew a straigh stitch
if the feed dog lever is in the down position then it will only stay in one spot,
if you try to push the lever up and it will not stay or stays and will not sew then the feed dogs need to be checked
Oct 09, 2013 | Elna Quilter's Dream 6003Q
Needle is moving up and down but it doesn't move forward
if you have a manual, check and see where the feed dog lever is and make sure it's in the up position. when the feed dog is in the down position it's in the darn mode staying in one place,, but when it's in the up position the machine will sew.
here is a link for a manual, if you don't have a manual
http://www.sewingpartsonline.com/instruction-manual-elna-2110.aspx
Jun 12, 2013 | Sewing Machines
My Philips toaster blown off
Bring it to the manufacturer,
or buy another one! ;)
Mar 05, 2013 | Kitchen Appliances - Others
Frigidare side by side refrigerator ice dispenser will only dispense crushed ice
1. Take out the ice bin to access the switch in the freezer.
2. Underneath the ice bin is a metal rod.
3. In the back of the freezer there is a square hole from where the rod came. Put your finger in this hole.
4. You should feel a plastic lever. If it's up, push it down. If it's down, push it up.
5. Put the ice bin back and try for ice again. You should receive crushed and cubed ice at this time.
6. If you push the lever up or down and it doesn't stay in place you should contact an authorized service technician for repair.
Jul 29, 2012 | Frigidaire FSC23F7D Side by Side...
Our switch doesn't stay in off position
you probabley bent the switch lever so the little indent on the lever won't stay positioned in the off detent. probabley need new switch lever. part doesn't cost much .not hard to put in if your mechanicly inclined , if not a repair center can do it for you.
Sep 12, 2011 | KitchenAid 32685 Mixer
1) The lever at the back that keeps the foot up when threading etc will not stay up on it's own. When you put it up, it just falls bak down a second later. 2) The needle won't go up and down,...
it sounds like the take up lever has either come loose or is broken, & since the needle won't go up & down it needs to be checked
Aug 02, 2011 | Singer 1507
I have the Delonghi DE500P and the lever that indicates the bucket is full will not stay down and therefore the bucket full light remains on and the fan will not start. when i use my finger to push this...
Replacing the switch/lever is more trouble and costly than it's worth. That's if you can find the part. I suggest, that you try reinstalling the bucket very carefully, making sure it making contact with the lever in the proper position. Lots of times, the bucket is simply not being inserted properly and it misses the switch. If that doesn't work and you want to repair it yourself. Contact Delonghi Parts Dept 800-865-6330.
Hope this helped you.
Apr 27, 2011 | DeLonghi DE500 Dehumidifier
Toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Oct 11, 2007 | Waring WCT708 4-Slice Toaster
DeLonghi RT200 Retro 2-Slice Toaster Logo
540 people viewed this question
Top DeLonghi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oloyede Monsuru
Paul Bade
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
