Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
Plinthe chauffante baseboard heaters
I have 2 currently installed model # F2546NWC and F2548NWC and am trying to determine the volts these are required to be used on. Do these models have a specific voltage requried (120 or 240). The label has been removed and I do not have the equipment to do the voltage check. I wasn';t sure if the specific model indicated input voltage
1500/1150 WATT
Posted on Jan 29, 2008
  • 625 Answers
Take a close look at the tubular element with a magnifying glass. the volts value should be stamped into the element. most baseboard heaters are 240 volt at low, high and medium density. wattage could be from 750 to 1500 watts
Posted on Jan 10, 2008
Intertherm baseboard heater model 1580. Need thermostat
Home Depot carries I believe 2 different T-stats , wall mount, and unit mount. Try there. Or you will need to get it touch with the manufacturer. Also have info, 120 or 240 volt.
Mar 06, 2011 | QMark Portable Hydronic Electric Baseboard...
Need a wiring diagram to hook up a wall thermastat from breaker box to the thermastat to the baseboard heater
Please view the videos below how to install...Good Luck ...Jim
This video will show you how to install the wire and breaker for a 230 volt sourse
These two video will show you how to install the heater and thermostat.
Feb 17, 2011 | Honeywell (CT62B1015) Baseboard Heater
My Fahrenheat baseboard strip heater is a 1996 model, 120 volts. It only works for one thermostat cycle. The thermostat points open slowly and arc as they open. The points will not reseat to supply any...
Why not get a 24 volt definite purpose contactor and connect it to power?
Use a transformer to open and close the contactor and then you can use a low voltage 2 wire el cheapo wall thermostat to turn on the heater?
Dec 01, 2010 | Fahrenheat Electric Convector Baseboard...
What thermostat do I use for a model f2546nwc heater where the thermostat is mounted on the heater
u have to use a double pole thermostat...u can find it a has 4 wires- 2 red and 2 blacks..i just installed mine on 11/7/10...
Nov 04, 2010 | Fahrenheat Electric Convector Baseboard...
I have a FahrenheatPro. and it doesn't seems to not throw out hea
the baseboard heaters out put goes down a lot more than you would think when used on 120 volts ... thats because not only is the voltage half of what it should be, the current is also half .. so the total power (the product of voltage and current) is one fourth of what it would be if operated on 240 volts .. you are operating at only 186 watts instead of the 750 watts you should have .. so you would have to have 4 times as many heaters for the same heat output .. you likely have the 240 volts available (most houses do) .. there are two phases .. each 120 volts .. when both phases are used together then you get the 240 volts total .. another option is you can use heaters designed for 120 volts .. the current would increase to a little more than 6 amps per heater .. some heaters have a jumper you can move for 120 volt service or 240 volt service... you can use those with either voltage ..
Sep 12, 2009 | Fahrenheat Electric Convector Baseboard...
I need a wiring diagram for a Fahrenheat electric baseboard heater. model # F2546NWC 1500 watt.
i dont have a diagram but i just did mine,,,its real easy to do...write back if you didnt solve your answer yet...
Dec 26, 2008 | Fahrenheat Electric Convector Baseboard...
the heat may be affecting the unit's paint. normally the oil used in manufacturing burns off the first time the unit is used. maybe the proximity of the element to the case is too close.
Dec 19, 2007 | Fahrenheat Electric Convector Baseboard...
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
805 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
