Question about HP Pavilion Dv5220us Notebook
Hello. when i plug in my hp dv5220us laptop it sounds like the fans running all cenyer lights on but power button will not turn on. same with battery
  • HP Master
  • 4,806 Answers
Remove the AC power jack and then the battery. Hold down the on/off button for 30 seconds, that will drain any residual power from the laptop.
Then just plug in AC power only and try to boot the laptop up. If it boots let it load Windows and then shut it down. Remove the AC power jack and then re-insert the battery. Then try to boot the laptop up.
If it boots up you all good.
If this does not work please post back.
Good luck.
Posted on Nov 16, 2009
One of my ac's light is blinking and wont turn on. Is not the control batteries, what could it be?
Laptop Won't Turn on, Blinking lights - HP Support Forum ...
h30434.www3.hp.com > Laptop & Notebook > Boot
Solved: Hello My laptop is an HP pavillion dv6z-1100, its running a 64 bit version of windows 7 ... Message 1 of 38 (164,169 Views) ... Upon attempting to turn it back on (while being plugged into the ac adapter) the computer would power up, ...
Air conditioner light blinks - Discussion on Topix
www.topix.com > Chevrolet Malibu
Jul 11, 2006 - my 2001 Malibu has this problem, blinking A/C light. ... On the control panel for the air conditioner, the ac button(the one with the little green light) blinks on ... The ac will turn itself back to outside air after it has been running on ... 2002 A\C Blinking
May 14, 2007
2003 Toyota Camry A/C button flashing
Apr 10, 2007
More results from www.topix.com
Dec 25, 2015 | Computers & Internet
Hp dv7 wont turn on
It sounds like your power adapter is not putting out proper voltage...
Try removing the laptop battery and see if the laptop will power on when plugged in with no battery connected. If it will not power on this way, then test with another power adapter. If still no good, then it should go in for service. Please let me know if this helps or not.
Joe
Apr 24, 2012 | HP Pavilion dv7-1137us Notebook
My emachine D725 series wont start up after the battery was drained and usb was removed. The power button lit up for a second, cd rom light up too then turns off after few seconds and turns on again..the...
Flishp,
Try running the laptop plugged into power, but without the battery. If this works, try putting the battery back into the laptop; if it continues to work, let the battery charge over night and see if you can run the laptop from the battery. If when you plug the battery in the laptop turns off, you need a replacement battery.
Please let me know if you have any more questions.
Thank you.
Mar 22, 2011 | eMachines Computers & Internet
I turn on the power switch, led lights, fan run, but after few seconds it turn off and no display on the screen, as in blank/ no lights
Hello ,
Check the battery,and the ampere.You did not explain about the company name and it is unable to
present next step about battery. you should better to go nearest technician, for test.
If your battery is fine Check the dc adapter,to cheek either charge the battery or not.
REGARD'S
Dec 29, 2010 | HP Computers & Internet
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
My laptop was starting to run really high and hot and would shut down after just a few minutes. Last night when I tried to restart it, the lights all came on, but not the screen. It doesn't even sound...
Try to drain the static energy of the motherboard first by follwing this steps.
Take out the battery
Unplugged the power adapter
Press and hold the power button for 30 secs
Put the battery back in
Plugged in the power adapter
Turn ON the computer
If still NO display. You need to call HP tech support department for this could be a mainbaord issue. Since you mention that system is running hot. Computer fan might stop working that damages the mainboard.
Jun 13, 2010 | HP Pavilion DV6500T Notebook
My laptop is not turning on
have you tried to remove the battery, try to remove it ad plug it directly without the battery
Mar 09, 2010 | HP Pavilion DV6700T Notebook
Notebook will not boot and the power and hard drive light are just blinking.
try removing the battery and AC adapter... then press on the power button several times... then reinstall the battery and the AC and see if it will work now.
Dec 29, 2009 | HP Pavilion Dv5220us Notebook
Hp dv6000 won't start up at all, lights turn on, then off
You may need a new power supply, It may be putting a bit of power out but not enough to run thr comp
Jun 15, 2009 | HP Compaq nc6000 Notebook
HP Pavilion Dv5220us Notebook Logo
95 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
