Question about Kitchen Appliances - Others
The dryer turns on but I don't get any heat model SE 1000
The dryer turns on but I don't get any heat from model SE 1000
    Sergeant:
    Champion:
  • 289 Answers
I nead more Information,mod#
Posted on Nov 16, 2009
Heating element turns off and on while tumbling.
What is your model number? All dryers will turn the heat on and off by means of the "hi limit thermostat" to insure your clothes don't catch fire as well as your machine. If there is a different problem with the heating, please be as descriptive as possible.
Apr 25, 2012 | Maytag Dryers
The dryer heats but the drum does not turn. The belt is fine, could this be the blower? model # sdg3606aww
If the unit is heating...I don't think it is the blower. It may actually be the motor-part: 2200376
Sep 07, 2011 | Maytag SDG3606A Gas Dryer
Had a flood in the basement. THe electric motor works by there is no heat. Turned on the main and cutoff valve to the dryer started the dry it tumbles just fine but still no heat. Don't think...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 06, 2011 | GE Dryers
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
Dryer heat turns off after about 5 min- dyer will remain running but no heat
HI, After the heat shuts down, do you hear a click like it is trying to heat again but then get no flame. The most some problem is the coils on the gas valve go bad and will not reopen after they have heated up.
Remove the cap on the front lower left panel. After dryer has ran and heat shuts down, watch and se if the ignitor glows again (you will hear a click) and the ignitor shuts off before a flame. If this happens, change the coils on th gas valve.
Here is instruction: Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jun 01, 2009 | Dryers
Maytag Stacked W/D SE 1000
Had the exact same problem. Just had a repairman look at it. I need to replace the motor. Probably won't.
Jun 09, 2008 | Kenmore 75944 Gas Dryer
Kitchen Appliances - Others Logo
22 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
