Question about Toshiba REGZA 47WL68 47 in. LCD TV
Toshiba 47 inch hd picture fades out then comes back. It looks like it is melting. Has done it about 10 random times
  • 8457 Answers
SOURCE: Toshiba 26AV502U, sound breaks up, picture
Ur Tuner board have problems,it dying.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Posted on Apr 22, 2010
  • 8457 Answers
SOURCE: no backlights
The T-Con board is dead.This board sit right in the middle in the bottom of the LCD screen panel.This board is dead,require replacement.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con board for the replacement.
Posted on May 24, 2010
budmrtn
  • 11361 Answers
SOURCE: Syntax Olevia Television Problem: Television
Three possible causes:
Power supply module with poor DC filter caps, Bad T-CON board, Backlight inverter board. Those are the assemblies to check.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Posted on Jun 15, 2010
Testimonial: "NICE. thanks for giving the options to check. "
SOURCE: How do I get a full picture on my vizio 47 inch.
you need to check the resolution on cable box
and check the format botton in remote control
Posted on Nov 17, 2010
budmrtn
  • 11361 Answers
SOURCE: i have a d:4742m 47
No pictures can be due to no 24vdc for the backlight, bad T-CON board (have backlghts but no pictures).
Please try below first:
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 28, 2010
How do you change picture size without the remote control
I have a 47 inch Toshiba lcd tv. I lost my remote control and am unable to change the picture size on the screen. Is there a way to change the hd settings from 480i to higher definition through my digital cable box?
Feb 28, 2010 | Toshiba 37WLT58 37 in. LCD TV
The picture fades out and then comes back on in about an hour.
witch sentence is corocet .I' ll come back to toronto on 10 march.I'll back to toronto on 10 march
Jul 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Gray faded look on top to picture
It can be the plastic anti polarizing screen that covers the display.
Often it causes grey or red shadows on top of the picture.
Sep 15, 2008 | Toshiba 56H80 56" Rear Projection...
TV picture fades, then shuts off
There are some components in the scan amplifiers, and or the power supply area that have become unstable. This can happen with age and use. It is impossible to make an accurate assessment without actually troubleshooting the set.
You need an experienced TV service tech that is strong on troubleshooting, has the service manuals, and has the proper set-up to work on your set. I would recommend the factory service rather than an independent service tech unless you know for sure that the independent service tech can handle this type of repair.
Considering the age of the model of set that you have, I would be looking at replacing it rather than fixing it. Because of the age of the set the reliability will be decreased.
Jerry G.
Jun 10, 2008 | Samsung TXF2899 28" TV
Picture on Vizio HD 47" LCD TV freezes
It sounds like a main board failure but it could be the power board as well, to find out your going to need to test the power supply voltages when it quits
Nov 26, 2017 | Televison & Video
Panasonic PT-47WX49E
The only thing I can think of that would make the picture fade to black is a loose solder joint on the filament supply. Each of the 3 picture tubes has a filament and if the 6.3 volt supply to those filaments is suddenly lost, the picture fades to black as the filaments cool down. An experienced tech can find and correct this for you quite easily.
Sep 10, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Toshiba REGZA 47WL68 47 in. LCD TV Logo
107 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
