Question about Refrigerators
REFRIGARATOR SECTION NOT COOLING PROPERLY, BACK WALL OF BOTTOM FREEZER SECTION FROSTING UP.
  • ptatreau Nov 16, 2009
    Will keep you posted on my progress with the problem. thank you, Paul Tatreau
  • 6,927 Answers
Try setting the freezer to warmer,this will push the cold air to the bottom,this is just a adjustment on the fan deflector,not a thermostat as people believe,this adjustment will still keep the freezer in the freeze temp,not to worry,and adjust the thermostat in the fridge compartment to about 7 or 8.Let this temp have time to change 8 hours or so,if this does not help,then remove the inner compartment of the freezer unit,the panels,and the little fan.You will find the coils at the bottom rear of the freezer compartment,freezing,and a ice bottom,froze over.Defrost this with hot water.There is a drain,under the ice,that has clogged up with food debris,and the water could not drain out,The water is from when the defrost,that melts the ice off the coils>The defrost timer only comes on for a short time,to get the frost off the coils,that is why they call it frost free.Anyway,the drain,takes the water down under the unit,to a drip pan,sense there is not much water to be put in the drip pan,it evaporates quickly.You will have a mess,under there once the ice and the food debris is cleared away,it may take some air pressure to clear the drain,after the ice is gone,but not much.Use a air tank,to do this,un- less the hot water does the trick.Then just make sure the drain is clear,maybe run water threw it.Put it back together,and you are finished.I hope this helps,if so,please let us know if it was ,at all helpful,thank you.
Posted on Nov 16, 2009
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Nov 16, 2009
    thank you,and I hope it works out.
The back wall of my hotpoint freezer/refrigarator is frosting up what is wrong whit it.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 13, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
FREEZER FREEZERS BUT THE REFIGERATOR WONT GET COLD
Check the air return on the bottom left wall of the refrigerator side. Check for cold air flow at the top of the refrigerator when the compressor is running. If you feel no air flow, open the freezer door and see if you detect significantly more air flow after opening the freezer door. This could indicate a return air flow restriction and make sure that there no blocking of air vent at the top of refrigerator section that supplies the cold air from the freezer.Check the door seal gasket on the refrigerator for leaks.
If the vents and air flow paths in the refrigerator are proper, then check the back wall of the freezer for excessive frost. A defrost system problem could be preventing the refrigerator from cooling properly. If you do see excessive frost on the evaporator in the freezer, you may be able to restore proper cooling in the refrigerator by storing your food in an ice chest and then shutting off the refrigerator/freezer and letting the unit completely defrost for about 24 hours. Leave the doors open for air circulation. After the frost on the evaporator has defrosted, plug the unit back in and see if the refrigerator and freezer will cool properly.
If there is still same problem then you need to replace evaporator fan.
Hope this helps.
Shane
Mar 01, 2011 | Whirlpool Refrigerators
The upper portion of the freezer turns off, causing the ice to melt. And the cooler side bottom drawer turns into a freezer. I can't figure out what's going on.
You have a frost blocked evaporator. Translation: The cooling coils, located behind the back wall inside the freezer section, have plugged up with frost (usually caused by a burnt out defrost heater, located at the bottom of these coils) which prevents the cold air from circulating inside the freezer, and into the top of the fresh foods section. At the same time, this blocked air flow allows very cold air at the bottom of the freezer section to migrate back into the bottom of the fresh foods section, and thus freeze item in the bottom bins of the refrigerator. Unload the freezer, take the shelves out and remove the back panel. Melt the frost with a hair blower, and change out the heater at the bottom.
Jul 08, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Not cooling properly
First thing- set the controls at the mid range of their settings. Next, check the coils under the fridge to see if they are clogged with dust, etc. Next, using a couple stem thermometers, determine the temps in the freezer and fresh food sections. In the fresh food section, place a tall glass of water on a shelf in the middle, put the thermometer in and let it set for awhile in the fridge. Inside the fresh food section, look for the damper opening at the top of the wall in between the two sections. Wet the back of your fingers- can you feel air blowing through the damper opening? Inside the freezer section, look at the back wall- any frost buildup there.
Hope this help.....
Jun 28, 2010 | Magic Chef CTF2125 Top Freezer...
MY GE refrigerator is freezing in the freezer section and the refrigerator. However, this is only at the bottom to slightly below the half way Mark. Thisis a two door refrigerator freezer. One half is...
Do not know how to find a repair in your area, but here is what is wrong:
The cooling coils, located behind the back wall of the freezer section, have frosted up, preventing the normal flow of air. Now, some of the cold air in the freezer is sinking and flowing into the bottom of the fresh foods section through the air vent by the bottom bin. To fix this, disconnect power to the refrigerator and unload the freezer side. Remove the panel at the back of the freezer section and melt all the frost and ice. Replace the heater at the bottom of the cooling coils, which would normally take care of the frost build up. Reassemble and restore power.
Nov 12, 2009 | GENJRS06 Electric Single Oven
Freezer same temp as refrigerator.
Any frost buildup on inside back freezer wall?
Nov 07, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
Amana energy saver not keeping fridge section cool enough. HELP!
if there is frost build up on rear wall of freezer section the unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow to the fresh food section. one of three things are bad. defrost heater, defrost thermostat or defrost timer. if no frost on rear wall you might be low of freon.
Jun 24, 2009 | Amana ABB1927DE Bottom Freezer...
Fridge cools at top and not propwerly at the bottom
Check the back wall of the freezer section for frost buildup. Refrigerator is cooled by air that comes from the freezer section. If the coil is frozen over the air is reduced going to the refrigerator.
Jul 11, 2008 | Smeg Refrigerators
Kenmore Trio 596.75509400
Generally speaking if the refrigerator does not cool and you have frost on the back wall of the freezer it suggests a defrost problem.
However since the refrigerator started working by itself it would point to an air circulation problem from the fan in the freezer compartment failing to operate. The frost on the back wall without the fan operating would cause frost buildup because the heat is still trying to get to the coil through the back wall. If your refrigerator freezer has a door fan light switch something holding the door partly open would cause the fan not to operate. Look for a button or toggle and manually push it in. You should hear the fan turn on and the light will go off.
Mar 12, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
