Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
My ice maker doesnt make ice i have checked all the obvious stuff
    Scholar:
  • 79 Answers
Did you check the temperature of the freezer? Most ice makers have a temp senser imbedded in the tray/unit . If the temp in the freezer isn't at least 5 degrees (normally on many ice makers) the ice maker won't operate. This is one possible cause. Other causes could be no water to the tray, the timer motor defective or stuck somewhere in its cycle, or the bin arm is up in the off position. I hope I was of some help! Good luck!!
Posted on Nov 16, 2009
Amana ice maker wont stop making ice
Does it have Ice bucket in door? If so, most likely emitter and receiver that shoots red laser across and through ice bucket is bad. Obviously check to see that Ice Maker is cut on either at switch or with wire arm lowered.
Oct 08, 2017 | Refrigerators
I have a Maytag Performa PTB2153FR ice maker that I believe was over filling-now it's not filling at all. I cleared some ice out of the water line but it's still not working. Not sure if I replace the...
if you are doing this stuff and have questions your problem is you are doing your own work and obviously have no idea what you are doing, and you should stop it and call a professional.
Jan 01, 2015 | Maytag Refrigerators
My whirlpool GS6NBEXR refrigerator ice cube maker leaves slimey, flaky residue at the bottom of my glass. What can I do?
Diana, if I understand you ok, the ice you put in the glass leaves slimy residue. So that slimy stuff has to be in the ice cube. Well remove the the ice maker unit and thoroughly clean this ice holder and throw away the ice cubes in the kitchen sink and see if leaves slimy stuff. As for slimy stuff, while the unit is out, check any leaks etc. BTW any smell?
Jan 06, 2014 | Whirlpool GS6NBEXR Side by Side...
I have a 10 year old, at least Kenmore ice maker overflowing into the ice chest. No obvious adjuster.
Can you locate the Kenmore Model Number? It will look like this=> 321.654987 What I think is the dual water control valve is leaking once it turns off. Here below is a ice a ice maker repair clip on You-Tube where he shows a slug of ice filling the ice maker fill tube. In most cases replacing the water control valve will stop the continued water flow to the ice maker once the ice maker fills. I will be here to answer any questions you have Thanks Sea Breeze
Apr 15, 2013 | Refrigerators
HOW DO YOU ROMOVE ICE MAKER MOTOR .TAKE IT OUT
You don't....... Take the whole Ice Maker and PITCH it if you think it is bad. If the motor took a dump on you, then replacing it will only put more strain of a NEW MOTOR on other components in the Ice Maker. Ice Makers are so cheap these days, if one dies on you, just replace the whole thing and relax in your easy chair.
Ice makers are pretty much trouble free, so the odds of you getting a second bummer unit, is pretty remote. Since you have the talent to take it out, obviously you have the talent to put it back.
Now then, if your a tinkering type of person, then go to ANY APPLIANCE - Mom-Pop store and ask them for a couple broken ice makers. They will probably give them to you for FREE, I know we had several that we kept tripping over. Take them home and take them apart and more than likely you will be able to come up with a motor that will fit, or you will find out how the darn things work. Or, you might just get frustrated enough, to buy the new one like I suggested in the first place. I like tearing stuff apart too.
Merry Christmas,
Jim
Dec 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Model MSD2754GR Side-by-side.. it will dispense water but will not fill the ice trays (I have checked all the obvious stuff, water supply lines and ice sensor arm). Don't here the control module "clicking"...
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 11, 2009 | Refrigerators
Ice Maker has some black stuff in water
check the ice-maker itself, it has a teflon coating (like a frying pan) that sometimes flakes off leaving little black flakes in the ice. if this is the case you have to change the ice-maker.
Jun 28, 2008 | Nor-Lake Norlake Refrigeration 4' x 6'...
Ice maker
1 may have frozen water line
2 reset ice maker press in ice lever 5 times
3check check ice maker plug
May 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker on Whirlpool fridge
i know it sounds obvious but check water supply is turned on. another easy check is the inlet valve is ok
May 09, 2007 | Whirlpool GD2SHGX Refrigerator
Ice Maker Problem
The "ice maker module" is pretty vague. THere's lots of things that work together to make ice. Could be a bad motor, a bad solenoid (electric valve that lets the water in), a broken gear, a loose wire, or just frozen up. If you havent pinpointed the problem, you are probably wasting money buying a new "ice maker module". I'd advise looking for obvious problems (frozen/jammed, no water input, broken looking stuff) and if you dont see anything, call a repairman.
Feb 26, 2007 | KitchenAid KSRS25IL Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
141 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
