Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
How can i set temperature for ge profile refrifgerator
  • 6,826 Answers
I really do not know this refrigerator,but the freezer compartment should be set at a lower temp,cause it is a deflector for the fan,that blows the cold air to where it is needed,it is not a thermostat.This means set it to a warmer setting,the freezer will still be below freezing.Set the thermostat on the fridge side,to about midway.I do not know the read out on the thermostat.but it will be fine at midway,or a little higher,colder point.If you have a read out,on the out side telling temp,then just watch it close,and give it 8 hours to equilize,and achieve the temp.the fridge will get colder,and if it is two cold,adjust the temp ,thermostat ,not the adjustment on the freezer side,this will achieve the good cold temp,in the fridge side,and the freezer will be fine,and the utilities will be less also.If this was at all,helpful,then let us know,thank you.
Posted on Nov 16, 2009
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    GE Arctica Refrifgerator- Not cooling
    its either the ptc overload on the units compressor is bad and is easily replaced by unplugging the old and replacing with a new replacement,the only other thing it may be is the cold control for setting the temp of the freezer/refrigerator,but normally these don't go out
    May 15, 2010 | GE Profile Arctica 25.4 Cubic Feet...
    My GE Profile Performer refrigerator is freezing fruits and veget
    PUT THE REF. ON 5 AND SET THE
    FREEZER ON 2 1/2 AND SEE IF THIS WORKS
    Apr 23, 2010 | GE Profile PSW26P Stainless Steel Side by...
    GE Profile Side-by-Side Refrigerator gets to too cold
    turn the temp setting up to40 then check in a couple of hrs
    Nov 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
    Buttons on Control Panel not working for my GE Profile Gas Range
    Anyone has any information as to how to fix my describe problem with GE Profile Gas Range I have.
    Thanks
    Mar 14, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
    GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
    26 people viewed this question
    Top Refrigerators Experts
    Sal DeAngelo
    dweatherby
