Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Hi, I installed the RTH2308 thermostat and it is turning the heater and a/c in reverse. Example: it is 75 degrees in the house and if I turn it to cold and down to 70 the heat comes on and if I turn it up to 80 and heat the a/c goes on. Help please. Thanks, Aaron
    Scholar:
  • 79 Answers
Most likely you have the W wire and the Y wire reversed when you connected the wires at the thermostat. Try switching them around and se if that solves your problem. The W terminal is for heating and the Y terminal is for cooling.(both at the thermostat and your furnace). Make sure you turn the power off at your furnace before you change any wiring connections, if you don't you could short to grond and ruin the step down transformer or blow the low voltage fuse in your furnace. Hope I was able to help you!! Take care!
Posted on Nov 16, 2009
  • Honeywell Master
  • 43,501 Answers
I cannot say for sure because I really should have more info. to get it right for sure but I think that you have the "W" and the "Y" wires switched. Typically the W (heat) wire will be the white one and the Y (cool) will be the yellow one. Try taking off the wires in the t-stat from these two terminals and switch them. If this is a heat pump and take the wire you have on the B or the O terminal and move it to the other one the B and the O terminals determine heat/cool mode in a heatpump t-stat.
I turn my heater on, it is set on auto, but it never turn off, it's a new thermostat.
If the setting was at 80 degrees and it didn't turn off, that's because the room didn't reach 80 degrees yet. Keep track of the room temperature as well as if it turns off when set for a lower temperature.
Dec 28, 2012 | Honeywell Programmable Thermostat Heater
I have never used central ac before - how do I set it? If it is on 75 will that cool the house? If I want it cooler, do I put it lower? like 65?
As to your question 'will 75 cool the house?' The answer is 'yes' - if the outside temperature is low enough. Typically speaking you can expect your central AC to cool a properly insulated house to a down to a temperature of about 20-25 degrees lower than the outside temperature. For example - if the outside temp is 95 degrees. You could expect to get your house down to 70-75 degrees. If the outside temp is 110 degrees then you could only expect to get the house to 85 or 90 degrees.
So .. as you can see - your 'inside' temp will be directly affected by the 'outside' temperature.
As to the operation of central air; it is very simple.
I would suggest that you not pay 'too much attention' to what you have the thermostat set on. A comfortable temperature - is a personal thing - so - I would set it somewhere - say 72 and see how I (and others in the house) was handling that setting.
If you want it 'cooler' just 'notch' it down a degree or two - if you need it a little warmer - turn it up a degree or two. Do this "fine adjusting" till you have the temperature setting you are comfortable with.
Usually the more you can leave your thermostat alone the better off you will be from a comfort position and an electrical useage standpoint. Obviously, the higher you have your thermostat set the 'less' it will cost you on your electric bill.
How high you set the temperature is a balance you have to come to based on how comfortable you want to be - matched with how much you want to hold down the electric bill.
hope this helps
Aug 14, 2010 | Honeywell Heating & Cooling
Does this thermostat have a delayed start setting?
You will have to have the installer manual and go into the con fig settings to change Honeywell.com
Jun 16, 2009 | Honeywell Electronic Programmable...
Heater turns on, but intermittenly
Turn the power to the furnace off and then back on and see if it resets. If not you may have a bad ignitor or dirty sensor.
Hope this helps.
Matt
Jan 05, 2009 | Fahrenheat FBE15002 Baseboard Heater
Honeywell heating system
go to the main power box and find the either breaker or fuse that runs the system and turn it off
Dec 25, 2008 | Honeywell Programmable Thermostat Heater
Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Dec 24, 2007 | EdgeStar Portable Air Conditioner Heater
Thermostate temperature setting wrong
Are you saying that the temperature over-shoots it's setting by 5 degrees? If so and if the thermostat has an inticipator device in it you can adjust it. After removing the cover on the thermostat, look for a little brass triangle on the lower right hand side. There will be a scale with numbers on it and they are very hard to see. This device heats up prior to shutting off the thermostat so it will not over-shoot by more than a few degrees. Move the brass triangle either up or down and let the heater cycle a few times. If the temperature swing gets worse, go the other way next time.
If the thermostat is not heat inticipated, there will be a small "Dip" switch where you can adjust to a specific degree of under-shoot.
Visit the Honeywell website and you can pull up the installation/owners manual for your model. www.honeywell.com
Nov 27, 2007 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
176 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
