Question about HP Pavilion ze2000 Notebook
I have an hp ze2000. I hooked it up to an external monitor. When I unhooked it and restarted it my laptop screen now stays blank. Who knows the answer to this?
  • HP Master
  • 4,806 Answers
Sometime by holding "FN" and pressing "Spacebar" brings the screen back, or hold Fn and hit the F7 key.
If its not the F7 key then it maybe F5 or F6.
Regards.
Posted on Nov 16, 2009
    President:
  • 2,049 Answers
To switch the image between the notebook display and the video device display, repeatedly press the fn+f4 hotkey. Pressing the fn+f4 hotkey switches the image among the notebook display, the connected video device display, and simultaneously on both displays
    Master:
  • HP Master
  • 956 Answers
I think you have to reset through setup F12 or is it F8 restart and push one or the other, then locate menu for screen click to enable.
Haven't come across this before. Best I can suggest?
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
Not able to start up my hp dv4-1124nr laptop. Giving me black screen all the time. Have tried options like removing battery, AC Adaptor and also memory modules. It is still showing black screen after...
Try hooking up an external monitor. If the external monitor is working and showing you what you are used to seeing, than you just need to switch the laptop back to it's regular display mode.
There is a key that looks like this
'o'
you need to press the function key and this key (usually f4) at the same time to switch displays.
Dec 12, 2010 | HP Pavilion ze2000 Notebook
Desktop wont stay on screen drops to white screen blank
First thing you should try is hooking the laptop up to external monitor. It's usually easier to hook everything up, THEN power on the laptop. Most laptops will detect the external monitor and automatically provide video, some models require pressing FN+F5 Just examine your laptop keyboard carefully for a pair of icons that looks like two monitors.
If you get external video then more than likely the lcd on your laptop will need to be swapped out. If you don't get any video it could be a GPU or memory issue.
let me know what happens and I can guide you along.
May 20, 2010 | Acer Aspire 5100 Notebook
HP ZE2000 blank screen on start up.
you need to change the lcd inverter card of your note book
Oct 21, 2009 | HP Pavilion ze2000 Notebook
I have a hp pavilion ze 2000 and when I turn it on the two lights by the scroll and caps lock key blink and the screen stays blank. Please help me!
Hello, I'd start by hooking up another external monitor, that way you can rule out if your video/graphics card is working. If the new monitor works that means your video card is fine and you'll need to look at replacing your current monitor Good luck, mpawlak908
Oct 18, 2009 | HP Pavilion ze2000 Notebook
Laptop screen blank at start up
If it still doesn't work when you hook it up to an external monitor, assuming you did that properly, then it is your motherboard/video card.
If you have a seperate video card, I would replace that first. If you don't have a seperate video card, then you need a new motherboard.
FIRST - I would try hooking it back up to an external monitor, and making sure you switch it over to use the external as the default. otherwise you wont get picture.
Sorry... good luck.
Sep 10, 2009 | HP Pavilion dv2120us Notebook
Hp ze2000 shuts down
Without more information I cannot be sure, but I would say that it could possibly be set to use an external monitor. There is a FN key command to switch between your LCD Screen and an external screen. Try that. If you have an external monitor that you can plug into the VGA connection, that should tell you for sure. Good luck.
Nov 12, 2008 | HP Pavilion ze2000 Notebook
Monitor is blank!!!!
Firstly, the LCD+external setting will switch one or the other or both on.
Secondly, if you go into your display properties (or even the advanced page where your video card additional features are) you can usually select which monitor is "primary".
I suspect that your external display is primary, and the LCD screen is not "enabled" or used as part of the desktop.
The settings are all there, it's just a matter of finding them (depending on what video card is in whatever laptop you have)
This might have happened in the first place if you accidentally hit "Fn" and one of the "F" keys up the top. Fn + F6 on my laptop will switch LCD/external monitors on and off. (for example) There is usually a little blue picture on one of the "F" keys to denote that function.
Sep 09, 2008 | Toshiba Satellite A105 Notebook
Laptop Screen faded white
There are a couple of possibilities.
1. A cable has come loose inside the computer4.gif.
2. A cable has become defective.
3. The LCD is defective.
If you wiggle the LCD back and forth and you can get the picture to work again intermittently then answers 1 & 2 above would be more likely.
Jan 03, 2008 | HP Pavilion ze2000 Notebook
Blank screen
I think your LCD is stuffed is it under warranty do you know BUT if the screen is cracked they wont replace it typical HP. To get your external monitor running hold down the function key and the blue monitor looking key similtaneously normally on compaq its the F4 key but look around your keyboard (looks like a monitor) and is blue letters.
Sep 18, 2007 | HP Compaq Presario V2000 Notebook
HP Pavilion ze2000 Notebook Logo
147 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
