Question about GE (PSS26MSRSS) Side by Side Refrigerator
Hi .I have problem my refrigerator . The bottom wires of left door is open . Need wiring diagram . Please help me or any idea .GE mod #PSC25MSSA.SS
  • ruslan pimutkin Nov 16, 2009
    thank you so match!!!!)))))
  • GE Master
  • 3,051 Answers
Hello there Here is where the wiring diagram should be located on your refrigerator it may be in a small envelope or a plastic piece Refrigerators: Behind the front grill, in the center or on the left side. Other common locations are on the left or right side by the condenser, or inside the refrigerator section inside the control panel. ok? hope that this is very helpfull best regards michael
Posted on Nov 16, 2009
Why my alarm wont come on when door is left open
there is a short circuit in wiring. please check its wiring
Oct 15, 2015 | Samsung RF265AA Bottom Freezer French Door...
Hello, I have an AMANA side by side fridge with electronic display between the doors since 10 years.It seems to have a bad contact in the electrical cable going from the right door (fridge) to the main...
Here is a wiring diagram of a typical Amana Side by Side Refrigerator. In the top left corner you will see the box saying Harness FZ Door and Door Hinge Click HERE to view. I'm not sure just what model number you have but this diagram will help in giving you an idea of what plug and sections of wiring you and I can assist you in locating your bad connections. Look under the top hinge plastic cover and see if connecting or try pushing the plug assembly together more firmly. If this helps please let me know and please look around your fresh food section door and send me your model number so I can point you to the correct refrigerator wiring diagrams and tech support. Thank You, Sea Breeze
Larger View
Aug 29, 2012 | Amana Refrigerators
GE profile PSC25MSSA Heavy condensation on all of left wall in refrigerator side. Door seal is in great shape.
many problems like the one you have discribed is the refridgerent is getting low or the dyer is blocked or your compressor is getting weak you will need a engineer to test this
Nov 27, 2011 | Refrigerators
Ice/Water dispenser not working on my GE Profile Arctica model # PSS26SGPA SS. Does make ice though, just front panel stopped working. Called a tech to troubleshoot, who said it was the main...
Had same problem. Removed kick panel at bottom and found the wires from the freezer door near the lower hinge are very flimsy. The white wire was broken at the connector and the connector was corroded. Since I have no plans to remove the freezer door, I spliced the wires together with **** connectors and it's working fine.
GE could do better.
Jan 12, 2011 | GE Profile PSW26P Stainless Steel Side by...
The control panel for the icemaker, water, etc isn't working. Is there an exploded view of this for troubleshooting?
Yes, Click Here=> GE ARTICA PROFILE TECHNICAL INFORMATION Top left of the Tech Sheet feeds display panel and temperturecontrols if digital. Top left of wiring diagram is J4 and at bottom left hinge there is a pin plug connection that most likely has a beak in the connection. Check voltage DC should be 13 volts between red and blue or red and black. Click on wiring diagram and it opens into a Service Manual. Have questions please ask. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Jun 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The water and ice dispenser not working now it wont keep cold
The problem is most likely related to the wiring at the pin plug at bottom of door hinge. Click Here=> GE ARTICA PROFILE TECHNICAL INFORMATION SWeems i have solved 3 like this this week. Most times corrosion gets into the plug and stops the dispenser from working. When you get to the above link/page the first photo top left and the wiring diagram below and top left corner, J4 Plug leads to dispenser and temperature controller. Click on wiring diagram to download a Service Manual. Grt with me as soon as you can so I may help you resolve this. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Apr 26, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker is making ice, but neither the ice or
I have seen a lot of these this week. There are several reasons that could cause this problem. The light switch for the freezer door acts as a lockout for those controls when door is open, The pin plug at left bottom hinge has corrosion or a loose wire connection. We can begin by checking those parts and measuring the low voltage going to the dispenser board at the hinge and motherboard. Click Here=> GE ARTICA PROFILE TECHNICAL INFORMATION Save page to favorites and on the wiring diagram click on it and it will open into a new tab where you can save the Service Manual. Find a OHM meter and voltage meter and let me know when ready. J4 plug on top left is what sends power to the dispenser and the temperature controls. It is also on top left of the wiring diagram. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Apr 20, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE side by side refer. model # GSS25PSM. I'm getting water leaking along the bottom of the ice/water dispenser flange, then down the door face staining the SS. Any ideas? Thanks!!!
Duct door. Look up where the ice comes through the door if it's sweating the duct door is not sealing and you will probably have frost in the chute on the inside.
Feb 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram Convection oven ZET837SB1SS
I would suspect a couple of wires are crossed.
GE puts mini-manuals in their units, which have wiring diagrams, schematics, etc. Very handy.
It will be folded up in a small envelope, usually behind the control panel or hidden elsewhere. That should help you.
Oct 26, 2007 | GE Monogram ZE2160SF Convection /...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
