Question about Samsung HL-S4266W 42" HDTV
Samsung HL-S4266W when turned on says "check fan #2" then after couple of minutes shuts down. How do I check fan?
  • 6,927 Answers
You will have to remove the panel from the back,and check the fan,it is most likely gone out,or has dust and debris clogging it up.Do not use a vacuum,it will destroy the vacuum,and electricute you.Use compressed air and blow it clean.If the fan is shot,and does not run,or runs slow,then order a new one at a appliance store,Or a t v shop.If you use a external fan until you get the replacement ,it will get you by,If this was any help,please let us know,thank you.
Posted on Nov 16, 2009
Samsung HL-S4266W says to Check fan #1. I replaced it and it is running fine, but it still says it. Help!
Either something has to be done to clear that error or the set is detecting something.
I have a comment/suggestion here. that error may be misleading you, when you replaced the fan was there a noticeable amount of dust in the set---not like inside a carpet vac but noticeable.
I have seen this before in more than one set and brand---first thing we do is roll set outside (I know its getting to be winter) and with the cover off use compressed air and dust the whole set out--don't do it inside as even if set looks fairly dust free it may look like a dust storm when you do this.
I have seen many where units were dead or shutting down etc where once the air channels (unit takes in air from front and exhausts it toward the rear) I have a working set with no issues.
this is from experience and I hope it may help.
SD TECH
Dec 05, 2012 | Samsung HL-S4266W 42" HDTV
After tv is on for awhile and gets warm picture freezes but sound continues. after shutting down for quite awhile and turn it back on it works
analog board is most likely cause. Especially if you cant shut it off or change channels when it freezes.
May 28, 2011 | Samsung HL-S4266W 42" HDTV
My tv displays a message: check fan no. 2 then it shuts off
need to replace the fan located in the back of the lamp, is getting defective, may shure the new fan is in the right position label facing out.
Dec 18, 2010 | Samsung HL-S4266W 42" HDTV
How to replace replace fan no.2 on Samsung HL-S4266w? how to re
tack out engine take out lamp take of lamp housing assembly replace fan
Apr 20, 2010 | Samsung HL-S4266W 42" HDTV
Replace fan no.2
Just take off back and look. No trick to it. Unless Lamp fan--have to remove engine block.
MY SAMSUNG TV MODEL DLP HL -S4266W. I TURN ON THE TV AND I GET PICTURE SOUND EVERYTHING SEEMS FINE THEN AftER A COUPLE MINUTES IT TURNS OFF
Lamp maybe going out if you have not replaced it then it Lamp but Pull back off and make sure Fans are running if Fan to Lamp is defective then TV will shut Off. Look up Encompass Parts Distr or Call 1-800-638-3328
Nov 22, 2009 | Televison & Video
Hl-s4266w samsung no picture or sound timer flashes and then shut
replace Both of your STK ICs they are big black ics will have part number on them CK 2 resisitors 2.7ohms sometimes they will be bad also they are in same circuit as STKs STK394-020 040s call Mats for parts 1-800-628-1118
Sep 21, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
My HL-S4266W Samsung projection tv shut off by itself and all lights were blinking. The TV would turn back on but turn itself off after a few minutes. I replaced the bulb but this did not fix the problem....
Actually7 there's a possibility that your ballast is the one causing the problem, the thing is that with samsung tvs what goes bad most of the time, besides the lamp, are the ballast and the colorwheel, in this case my hopes are on the ballast, but if you want to be more sure discountdashmerchantdotcom
Jul 14, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
My t.v. shuts off after a few minutes
try this link...it tells you what the LEDs indicate. Apparently the cover on the back is not sealed properly, my guess is that it is a fan not working properly or some other reason the set is overheating.
http://downloadcenter.samsung.com/content/EM/200604/20060404091311750/EN/3_sub.htm
Oct 31, 2008 | Samsung HL-S4266W 42" HDTV
Samsung HL-S4266W 42" HDTV Logo
144 people viewed this question
Jerry Greenberg
Jerry Greenberg
