Black stripe on copies
I have a Xerox XC1040 copier. It has worked great. The other day I turned it on to make some copies and experienced a black stripe about 2 inches wide on the copies. I went through their suggestions for cleaning the transfer Corotron but this has not helped.
Any suggestions?
  • Tony0000 Jan 09, 2008
    In the direction the paper exits the machine. I ran a copy and stopped the paper part way through the copy process. The band is about 2 inches wide and about 1/3 of the distance from back to front.
  • 589 Answers
Please be more specific.
Are the lines appearing in the direction the paper exits the machine, or from the front of the paper to the rear?
Posted on Jan 09, 2008
  • Anonymous Jan 09, 2008
    Ok, now does this machine have a plain top cover, or an automatic document feeder?
    I know this seems like a lot of questions, but it's all in the steps of troubleshooting.
6ya staff
SOURCE:
How do I repair a thick black line going down the page?
Hi Ydn2,
You need to say what type of machine, what colour, what conditions. etc,etc.
Good luck.
Feb 26, 2015 | Xerox Phaser Office Equipment & Supplies
Black cq when using document feeder
clean the slit glass its the small maybe two inch wide glass to the left of the main glass clean it good use windex or alcohol that will get rid of you problem have a great day
Apr 18, 2014 | Kyocera KM-1505 Copier
I have a very old, but working, copier Xerox XC1040. It is blinking "H." What do I need to do?
To reset the H3 or H4 condition on your Xerox XC1040 copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
If this solution works for you then please leave a positive feedback and testimonial for me.
Thanks,
WheatlandServices
Oct 15, 2010 | Xerox Office Equipment & Supplies
Black stripes on copies using a Canon D1120
Do you use the Doc. feeder? Try to make a copy off the copy board glass. Is the line there? Now make a copy with the adf. Is the line there? If so, you need to clean the small glass under the doc feeder. It looks like a glass ****, about a 1/2 inch wide. Clean it with windex and that should solve your line problem...
May 11, 2010 | Canon CLC 1140 Copier
I need to replace the fuser gear on a XC1040
You have to remove that small cover on the bottom of the frame. It has 2 phillips screws to remove it. it is the cover about 3 inches high that runs around the lower front part of the machine.
Once you do that, you only have to remove one screw , unplug the heat rod and lift the fuser up and out. It really is pretty easy.
Mar 08, 2010 | Xerox Office Equipment & Supplies
I have a Xerox xc1040 that works fine most fo the
Yes these problm occurs frequently xc1040 . you ned to adjust the paper tray properly. then shake the bunch of papers so that the paper which are sticked are freed.
Jun 16, 2009 | Office Equipment & Supplies
XEROX CopyCentre C20-Blank stripe going down side
Open the cover and put a piece of paper on only half the glass, and make a copy. BLOCK the left side of the glass with the blank paper.
See where it is blank. Most of the times that is a dirty or haved up mirror in the scan head. One of the small mirrors in the black assembly under the lamp. When a digital copier scanner optics become dirty, the image in that area becomes very light .
Mar 18, 2009 | Xerox CopyCentre C20 Black and White...
Unprinted stripes on sheets
could be the drum causing the issue or the scanner assembly.
Jan 16, 2009 | Xerox WorkCentre Pro 412 All-In-One Laser...
Xerox C 20 photocopier 'scanner blocked' eror message
There is a scanner lock located on the bottom of the scanner. Look where you take your copies out of the machine. On the under side of the scanner you will see a green latch about an inch and a half long and half inch wide.
Turn the machine off. push the scanner latch inward , then pull it back toward yourself until you hear and feel it snap into place. Then turn the machine back on. that should do it.
Nov 18, 2008 | Xerox CopyCentre C20 Black and White...
Xerox xc 830
pls check ur machine ros assembly unit. i think the ros assay geting dust or its geting failed.
Jul 23, 2008 | Xerox Office Equipment & Supplies
294 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
