Question about Samsung NC10-14GW Notebook
My screen has rotated how do i switch it back?
You didn't mention by what degree has it rotated, Is it a 90 degree rotation or a complete 180 degree rotation. Anyways here's the solution to your problem.
Hold down Ctrl+ Alt and then press the Up or the Down arrow key to rotate it by 180 degrees.
OR
Hold down Ctrl+ Alt and then press the left or the right arrow key to rotate it by 90 degrees.
Posted on Nov 16, 2009
  • Taye Jonson Oct 29, 2011
    Thank you so much this just helped me so much cause my 3 years old jumped on my bed and kicked my netbook and the screen went black and when it came back up it was rotated and I couldn't figure out how to get it back.
  • vb7837 Jul 07, 2012
    thank you sooo much i am 13 and if this didn't work i would have to have told my mum and she would have killed me! my cat rotated my screen so with out this help i would have died (hypothetically speaking) but still thank you!!!!!
  • 458 Answers
Right Click Somewhere on the desktop screen and select your View, You'll be able to switch it back to normal position there
Testimonial: "sorted ty"
    Master:
  • Samsung Master
  • 956 Answers
Control panel.
Display settings
My FaceTime screen is at 90 degrees
  1. Verify that screen rotation lock is off. If you see this symbol in the status bar, rotation lock is on: lock_rotate.png Follow the steps below to turn off screen rotation lock.
    • Swipe up along the bottom of the screen to display Control Center (you can do this from any screen, including the Lock screen).
    • Tap the Screen Rotation Lock button.
    • If the button was highlighted, the button will appear dimmed after tapping it.
  2. Not all iOS apps are designed to rotate. Some may use only portrait or landscape mode, or switch depending on the content. To test screen rotation, open the Calculator app that comes with your device. If the screen does not rotate as expected while using the calculator app, continue troubleshooting.
  3. If the issue persists, restart your iOS device.
  4. If the screen remains locked, back up and restore your device.
Oct 05, 2014 | Apple Ipad I-pad
Allwinner A20 dual core android tab screen want rotate
Allwinner A20 is a name of a processor, so I'm not sure what tablet are you using.
There is an option to block rotation, for example if you want to read an e-book while laying on your back. Go to settings and try to find an option to unlock rotation.
Also, some tablets have a hardware (physical) switch on the side that locks rotation.
Jan 17, 2014 | Samsung Galaxy Tab Tablet PC
Screen will not rotate
Some tablets will have a physical rotate lock switch. There is also a setting that locks the rotation. Settings > Display. Auto Screen Rotate.
Dec 08, 2013 | Samsung Galaxy Tab Tablet PC
Screen rotation lock is now audio muting. i want to return to screen rotation lock
Unfortunately, this is a new feature from a past update. There is no current way to change the lock button back. However, you can access the screen rotation lock by double clicking home, swiping right, and toggle the screen rotation lock. As a future note, in the next update, you will be able to change it back.
Feb 25, 2011 | Apple iPad (16 GB) WiFi Tablet PC
My screen is side ways how do i put it back to normal
Do you have a rotating monitor? There are a few that can be rotated 90 degrees in the plane of the screen for a "portrait view" instead of the standard landscape view, and they will automatically swap horizontal and vertical signals as needed. If you have one of these, the position detector switch is stuck in the wrong position. You may be able to get it unstuck by rotating to the other position and back again.
There are some programs (e. g., Acrobat Reader) that let you rotate the view of the file you have open, but that only affects the contents of the window, not everything on the screen. I'm not aware of a program that rotates the full screen view for the entire system.
Nov 19, 2010 | Computers & Internet
I have somehomw switched the screen view from ladnscape to portrait byt touching a key on the keyboard when trying to do control alt delete. How can I switch the desktop back to a landscape view
You dont get worry.The problem will be solve.
  • Go to Control Panel.
  • Open the VGA Card Properties (for example if you motherboard is intel then open the Intel Extreme Graphic.
  • After this Click on Rotation Tab.
  • And then You change from here.
Short Keys of Intel Motherboard for rotation.
  • Rotate Normal (<Ctrl> <Alt> Up)
  • Rotate 90 Degree (<Ctrl> <Alt> Left)
  • Rotate 180 Degree (<Ctrl> <Alt> Down)
  • Rotate 270 Degree (<Ctrl> <Alt> Right)
Mar 17, 2010 | Computers & Internet
The display on my laptop screen
in video card advanced properties there is a rotate option
I don't know which videocard you have but you can go to display settings from control panel click on advanced button and enter to video card settins. There should be the rotate option
Jul 30, 2009 | Compaq 262585-B21 16-port KVM Switch
Accidentally rotated the monitor screen by 90 degrees.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1132269&rpn=PSM42U&modelFilter=M45-S269&selCategory=3&selFamily=1073768663&selModel=1132269|PSM42U
according to the downloadable user guide at toshiba support page , it appears , FUNCTION / SPACEBAR keys switches the landscape / Portrait modes . have you tryed that . good luck .
Dec 25, 2008 | Toshiba Satellite M45-S269 Notebook
Display screen upside down
It's broken wires to a switch inside the rotating mechanism. If you take the screws off of the screen and the rotating mechanism and remove the grey plastic covers you'll see a black switch inside a white plastic mounting that is anchored around the bundle of black wires going to the screen.
You'll be able to see the metal tab that rotates down to activate the switch when you swivel the screen (do this carefully with the covers off so you don't wreck the screen by asserting too much stress on it).
If you know someone that can solder tiny stuff, take it to them. It doesn't matter which wire goes to which terminal on the switch. You should see two broken wires in the black bundle - those are the ones that need to get reconnected to the switch. I used transformer wire to fix mine, as the insulation on transformer wire is painted on (and will need to be removed from the ends with a small file) instead of having plastic/rubber insulation that can melt when soldering.
Once the wires are reconnected, insulate them using liquid electrical tape, then put the wires gently back into the bundle, and make sure that the stress points don't land right on your solder connections. After that you should be good to go.
It's not a job for someone who hasn't soldered before... better left to someone with steady hands and the necessary equipment.
Hope that helps!
May 15, 2008 | Canon PowerShot S2 IS Digital Camera
Samsung NC10-14GW Notebook Logo
2,063 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
