I have a Toshiba TV model 32AF43. The TV sometimes doesn't pick the signals from the remote. I know the remote works. Can I replace the infrared receiver on the TV? Thanks in advance
  • pqt6 Nov 16, 2009
    Hi:
    OK, I'll try that.
    I have a couple of questions:
    - Do you have the original part number of the infrared receiver for my TV? That might help making sure the replacement part fits.
    - I noticed that the links you gave me for the part point to IR receivers for different TVs than the problem one. Is this module of a very generic type?
    - Could you supply a link to the service manual for the TV?
    - I'm not sure if I need to dissasemble the front, back or both panels to do the soldering. Any guidance? I hate to dissassemble needlessly.
    Thanks in advance
    PABLO
  • pqt6 Nov 16, 2009
    The TV is a Toshiba model 32AF43.
    I would like to try replace the infrared receiver on the TV:
    - Can you give me links to buy the part?
    - Can you give me the Toshiba part number? That might help making sure the replacement part is either original or generic but fits.
    - I'm not sure if I need to dissasemble the front, back or both panels to replace the part. Any guidance? I hate to dissassemble needlessly.
    Thanks in advance
    PABLO
  • 4,102 Answers
Hi, you can change the infrared reciever but the problem is getting the part the only real chance you have of getting the part would be to go into your local tv repair shop and ask them to order you one as they might be able to get you a universal one, as long as your 100% sure you can remove the old one and resolder the new without causing any damage to the corcuit board then you could go ahead with doing it.
But are you 100% sure the control is working properly the first thing i would do is take the control apart and give the back of the buttons a good clean and give all the contacts on the board a good clean also as this is the usual cause of the problem your having.
If this dont make no change then you could buy an all in one remote you can get these for next to nothing so try one of these first as you could change the part on the telly and still have the same problem.
So do the control first to make 100% sure that its the telly at fault and not the control.
Let me know how you get on or if you need further assistance ok
Posted on Nov 16, 2009
  • 5,807 Answers
Yes , you can replace the IR receiver.
you may need to open the unit , be sure that everything is unplugged
and visually look for the IR receiver.
the IR receiver have 3 important pins to operate.
you may need to use a 30 watt soldering iron and a good soldering
lead . and try to resolder the 3 most important pins
if the soldered joint is shiny , it must be good
and try again on your remote
if it still fails and you need really the IR Receiver it might be similar , is available at
http://www.radioshack.com/search/index.jsp?kwCatId=&kw=ir%20receiver&origkw=ir%20receiver&sr=1
http://electronicsexpo.partsearch.com/Part/Directed+Electronics+Inc/Sansui/0773071001/New.aspx?ModelMfgName=Directed+Electronics+Inc&ModelBrandName=Sansui&ModelNumber=TVS2746
here is the schematic
on V out 1, the voltage reading will be fluctuating from 5V
downwards whenever you press any button on the remote
using a multimeter
  • 4 more comments
  • Rommel Cana
    Rommel Cana Nov 16, 2009
    you can also try to see if this is like the one you are having
  • Rommel Cana
    and these is where it is connected
  • Rommel Cana
    here is a link to your TV service manual only with a fee
    http://www.nodevice.com/search/search.ht...
  • Rommel Cana
    the IR receiver might be in these location
  • Rommel Cana
    i haven't told you disassembled your unit, if you feel you cant solder and measure voltages
    likewise with just looking inside the unit, and confirming the components that you have inside
    then it might probably best to have someone have your unit be serviced by a professional.
    it would not cause you much by just having a rough estimate on your unit.
    although there are schematics and service manuals they are just a reference for the unit you are
    having.some parts are replaced by the manufacturers depending on their date of manufacture
    to improve the performance of the unit. what is important is you know what kind of part you need to
    replace. some have labels usually don't and usually it is for the tech knowledge to decide. .
  • Rommel Cana
    Rommel Cana Nov 25, 2009
My toshiba 65in will not respond to my remote
The infrared sensor to your TV might be bad. It should be replaced. It is an easy to get part, and is cheap to buy from any electronic spare part shops. To access and replace it, you have to pull out the front panel PCB. In fact, you have to open the TV to replace it. The component will look somewhat like this.
9_25_2012_12_43_33_pm.jpg9_25_2012_12_43_54_pm.jpg9_25_2012_12_44_12_pm.jpg9_25_2012_12_44_46_pm.jpg
Sep 24, 2012 | Toshiba 32AF43 32" TV
The remote doesn't work on my toshiba tv zp38
Check the infrared emission from the remote control first. If it is found OK, repalce the infrared sensor inside your tV.
To get more details about how to check the remote control, get into this blog.
'electronicshelponline[dot]blogspot[dot]com
Named 'Electro-Help'
Apr 09, 2012 | Toshiba 32AF42 32" TV
Tv doesn't pick up signal from remote
Hi Connie,
First of all, thank you for posting your question here at Fixya.
Please ensure that the battery is in good condition. Check the battery terminal for corrosion, Scratch it with fine sandpaper.
If the battery and its terminal is not the issue, please confirm if the remote control emits an infrared by pointing directly the sensor (infrared emitter) to your cellphone/digital camera. If it is working fine, you will be able to see the flash of the infrared through the screen of your camera. Watch the video below.
If you've confirmed that there's no infrared coming out from the remote control then this is an indication that the remote control itself is already faulty. Replace it with new one (part no. 0980-0305-3300 ).
If you can see the flash of the infrared, the IR board inside the TV is faulty. Please inquire at this link for replacement.
Hope I helped you.
Good luck and have a great day!
Jdvillanueva
Jan 11, 2012 | Vizio VL420M 42 in. HDTV
Need to program the 32af43 to my dish remote need code
Here you can download entire pdf for the model number mentioned and in page number 15 and 16 you can find codes http://www.tacp.toshiba.com/tacpassets-images/models/36af43/docs/36af43_om_e.pdf
Feb 05, 2011 | Toshiba 32AF43 32" TV
Tv not responding to remote works sometimes
hello, usually if the remot control is ok, then the infrared receptor need to be replaced, he is placed near the stand by light.
in a rare case the problem is at the 5v voltage that goes to the receptor. more rare is the possibility
that something is wrong at the microprocessor circuit.
i hope it was helpful!! Let me know if you need further guidance
Dec 10, 2010 | Toshiba 32AF43 32" TV
The remote control does not work to turn tv on. Channel does not change either so need to go to tv and all works well when at tv.
Hello, you need to make sure what is broken, the remote control or the TV. To check the integrity of the remote control, you need to broadcast from the remote control while he aimed at the video camera. If you see a flicker of light through the camera it shows the integrity of the remote control. In this case the infrared receptor need to be replaced, he is placed near the stand by light.in a rare case the problem is at the 5v voltage that goes to the receptor. more rare is the possibility that something is wrong at the microprocessor circuit. . If the remote control out of order, can be opened carefully by a thin screwdriver, usually the causes to the error are loose components or contacts that are supposed to weld back into the board.
Oct 08, 2010 | Toshiba 32AF43 32" TV
Infrared sensor won't work in a Toshiba TV
The remote wouldn't work on my brand new 46" Toshiba TV. Comcast person said the tv gave off an infrared signal that interferred with the Comcast remote.
Solution was to turn on cable box FIRST, then TV ( now I use All On button, which turns on cable first). If I turn on TV first, the remote wouldn't work consistently. Hope this works for you.
Aug 09, 2009 | Toshiba 26AV500U 26 in. LCD HDTV
Remote sensor not working
either the sensor on the tv is going or the eprom chip will need to be replaced along with a crystal that is on the chip
Dec 10, 2008 | Toshiba 32AF43 32" TV
Codes are not working
did you mean remote controll?
if you mean remote controll the common trouble of remote controlls is only three
1) the IR LED /infrared led
2) dirty contacts of keypad
3) leaky/open/shorted capacitor
Jan 05, 2008 | Toshiba 32AF43 32" TV
TV does not respond to Remote
possible defective rf receiver led defective in the tv.
Nov 21, 2006 | Toshiba 32AF43 32" TV
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
