Question about Vanguard International VN18B Infra-Red Heater
I need a new igniter button that is located on the top of the heater. Where can I order one? The button quit working and I paid $80 for a technician to to come out and tell me the battery was dead. Ever since, the ingniter switch does not want to work and now it is like the control that fits over the battery is stripped. It want lock into place. It just keeps turning and turning. This prevents connection to the battery and therefore the heater wont light. Please tell me where I can order another one. I cant afford another servce call plus parts. Thanks! PS this heater was bought in Feb and hardly ever used.
My camper water heater quit working. It has a Suburban water heater and when it quit working the reset switch did not light up. On/off does nothing. Do you think it is the switch or something else?
You didn't state if it was an electronic ignition type or not. You didn't state if it was AC + LP either. Assuming it is LP only and has electronic ignition, and the light is not coming on I would first look for a 12V fuse for the water heater. If you are lucky that might be all that it is.
The fuse would normally be located in the Charger/Converter Breaker/Fuse panel.
Beyond that you would have to start testing with a meter or test light to see if you have voltages to the unit.
It is common for the ignition boards to go out too. But those are a bit pricey. If you aren't handy electronically, have a meter, and a wiring diagram, it might be worth having a qualified technician troubleshoot this for you.
Apr 24, 2017 | RVs
VERY GOOD "spark" HOOKED UP YOU CAN SMELL THE GAS WHEN YOU HOLD THE BUTTON IN IT WILL IGNITE THE GAS WHEN THE FAN OFF BUT DOES NOT
Possible weak gas flow to igniter may require adjustment, have a qualified gas technician check it.
press the helpful button
Jan 08, 2016 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Damper stuck
Unknown if this is new installation or older installation that stopped working, so we're guessing
Damper is sold separately. Refer to part numbers in product manual.
http://waterheatertimer.org/pdf/Whirlpool-flue-damper-manual.pdf
http://waterheatertimer.org/Review-Whirlpool-Flue-damper-gas-Water-Heater.html
Call whirlpool Warranty and Service department 1-877-817-6750/ 12 years parts coverage for single-family residential installation when installed by code and information shown in product manual, and maintained as showing in product manual.
Clean air intake located on bottom of unit as shown page 24-25 product manual... the problem might be not enough incoming air supply.
Review manual for correct venting.
Check outlet for 80% rated voltage and for correct polarity, and for ground continuity with manifold tube located under gas control valve.
Troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Call local service technician. Call installer.
May 06, 2013 | Water Heaters
My Bradford White Defender M-I-30T6FBN doesn't show igniter button on instruct8ons
1) Just open the following link to identify gas control, and following instructions for lighting each gas control that appear under the gas control that looks like yours.
2) Otherwise add a comment and carefully describe gas control valve, and then open link and compare your description to pictures of each gas control valve, and then look below each picture for link that says how to light water heater.
3) Call plumber.or local service technician, or local BW supplier who can recommend technician.
4) Call Bradford White to get recommendation of local technician.
Feb 11, 2013 | Bradford White Bradford MI30T6FBN-337 30...
Our control panel for the heater/ac quit working for everything except for the fan speeds. I put another control panel in and still have the same problem. The LED lights on the buttons are not on ei
For things wich are complicated enough and comes with guarantee only if installed by an agreed technician, I personally prefer to go to service, even if cost me a bit extra. Can be so many reasons for not working properly yor A/C that I am afraid even the old one was not the problem, since the new one is having the same symphtomps. Can be a simply fuse for A/C.
Sep 10, 2017 | 2001 Chrysler Town & Country
I have a kenmore series 80 dryer that the heat has quit working. can you help
have you?.....Checked voltage, checked the thermal fuse, hi limit thermastat on the heater housing
Checked the element to make sure it isn't broken.
If it is newer have you checked the heater relay and or the circuit board beside the timer. and lastly make sure your dryer can vent out. Relays and board are in he control panel.
Best of luck. if you can't do these checks yourself you may need a qualified service technician to help you out.
Mar 03, 2011 | Kenmore Dryers
How much does a new sensor cost?
Ignition sensor-about 70-80 dollars
temp sensor-about 50-60 dollars
These are two of the sensors in a heater. Price is about what the price is in my part of the world. You should find out what sensor and check local prices before you bank on Arizona prices. As they could change quite a bit depending where you live in the world.
Oct 06, 2010 | Hayward H Series Pool & Spa Heater 400k...
Needing part to fix my water heater?
Colburns Suppy they have a web site and will have that part in stock or they can order it. www.coburns.com
Feb 01, 2009 | Bosch & Tankless LP Hot Water Heater
Need New Rotary Switch
Look on the net under www.grainger.com. They can take the numbers you have and cross reference it.
May 29, 2008 | Marvin 7060 Utility Heater
Vanguard International VN18B Infra-Red Heater Logo
Top Vanguard Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Vanguard Heating and Cooling Expert? Answer questions, earn points and help others
