Question about Nikon N55 35mm SLR Camera
FILM REVERSAL We have had the nikon N55 for about 5 years and never had a problem now all of a sudden the film reverses back into the canister while trying to load.
  • 2 more comments
  • RZCJPC Feb 09, 2008
    We are having the exact same issue. We've had the camera for approximately 2 years and it's now eaten about 4 or 5 rolls of brand new film when trying to load. Help!
  • ceutce Feb 21, 2008
    I have just encountered the same issue. I thought it was the batteries but after replacing the batteries I have the same problem. Any thoughts on the issue would be great!
  • Bath UK May 21, 2008
    Exactly the same issue for us! - had camera over 5 years with no problems - film reversal occurred when attemtping to reload - lost 3/4 fresh rolls of film - changed batteries - now lost 4/5 more rolls of fresh film. Any ideas why this reversal might start happening?
  • jsmithgdalen Nov 24, 2008
    i have a n55 put new film in and it runs as if it is loading then the flashing e pops up and my film is used up. I don't believe it reverses because my film is gone as if I used the whole roll. Any thoughts?
Try the first solution , it worked for me :)
Posted on Sep 30, 2008
I had an error (Err) message with an E in the window. Both were flashing, eventually the Err would stop and just an E would show in the window. I had to leave the camera on, open the door and remove the film, flash a few pix without the film in, reload the film, with camera on, and then close the door. It worked! No more error message.
I just tried a similar work around and fixed it. Try taking film out, leave door open, turn camera on. Error should go away except for an E in the film count area. As suggested earlier, click thru a few shots - with the film out and the door open. With the camera still on, load the film. Seemed to fix it for me. Good luck!
Posted on Aug 21, 2008
  • violet aura Oct 11, 2010
    I bought the Nikon N55 at an estate sale and was excited about the purchase until it started rewinding the film when loading it! lmao
    I searched the topic and luckily stumbled across your posts.I tried the above technique of having the film door open,snap the shutter a few times,loaded the film,closed the door...and voila! It finally loaded correctly!Had it not been for your posts I may have considered the camera faulty and gave up.Thank-you for the time that you took to share your expertise and advice on this.It is greatly appreciated! :)
Have successfully loaded and developed three films since posting dated 21.05.2008. On each occassion I have found that if switch on the power and operate the shutter tow or three times without any film in the camera, and then insert a fresh film into the camera it correctly loads. Don't know whether this is simply good fortune or the way forward - but it has worked for me so far! (Bath UK)
Posted on Jun 03, 2008
Has anyone had any luck with this problem?  It just started happening to me too!
Posted on Mar 24, 2008
Does anybody know a freakin solution????
Posted on Mar 23, 2008
I've got Nikon F65. I cannot load film. The motor which load up the film doesn't move at all. Please help!
I don't know this model but you can try this.Drop the film canister in and pull the film strip out and place on the film advance sprocket.Rotate the sprocket by hand/thumb until film is seated (1 turn). If the auto feed is working you will be OK. 2 other things ,1 of course load film in dark area, 2 check the batteries on the camera first, if they are week your film advance wont work ,Good Luck.
Jul 29, 2011 | Nikon Photography
I thought I loaded the film in a Nikon F100. The Camera showed the film was moving 1-24 I got to 24 the film re-winded I took it to get developed and The film was clear I just need to know how the load...
Since you managed to close the back of the camera and shoot, you've placed the actual canister into the camera correctly.
What happened is there are a series of pegs on the left side of the camera, or sometimes just a red indication line, that the film must be placed onto. If you don't lay the film onto this, the camera won't pull the film out of the canister when you shoot, but it will rewind it back into the canister correctly when it thinks you are out of shots. This will result in a blank roll of film.
Feb 16, 2011 | Nikon F100 with 28-80 and 70-300 lens 35mm...
How to unload nikon fg 35 mm film
When the last exposure is made, the film advance lever will not move the film to allow another picture to be taken. Turn the camera upside-down; with the lens facing you. Locate a small button in a slight recess in the right-hand side of the bottom of the camera. Press the button in to release the sprocket drive mechanism from the film. Turn the camera right-side up again, and unfold or open the film crank knob from the top most part of left-hand side knob (the one with the ASA settings on it). Return or rewind the film back into the canister by gently turning the crank clockwise until you feel the resistance ease up completely. This indicates the film has been completely rewound and is now protected from light when the back of the camera is opened, next. To open the camera back, pull the crank knob gently up and away from the top of the camera. The back door will open and when the knob is fully extended, *** will be possible to remove the film canister from the camera body. You should do this in subdued light if possible - and return the film canister into the original protective container if available - otherwise, place in a light tight box, bag, etc.
I hope this helps - and good luck!
Nov 02, 2010 | Cameras
How to change film in Nikon N 2020
Press the R1 and R2 release buttons. Pull up on winder handle until the back of the camera opens. Continue the pressure on winder handle until you have removed the film canister. Insert new film canister. Pull leader across winder assembly. Close camera back. Press exposure button. Press winder handle in towards camera b
Oct 13, 2009 | Nikon Photography
35mm film broke rewinding in camera
Take the camera with the film still inside to a reputable business that develops and prints pictures. The usually have a means of retreiving the film with out futher damage. If you want to do this yourself, you will need a place that is totally dark. You will also need something that is totally light tight. A solid plastic film canister may be sufficient. Take your camera into the "dark room" , open the back and gently try and release the film avoiding as much as possible only touching the edges of the film. You can turn the lights on once you have the film inside the light tight canister.
Aug 26, 2009 | Nikon FE 35mm SLR Camera
Putting film into nikon f60
It is fairly simple. Insert the film canister with the hole side (not the projection) down. Insert the spool of the camera into this hole and slide the canister inside the chamber. Now pull the film out slightly so that the leader (the narrow portion at the end of the film) aligns with the orange mark at the lower right end of the film chamber. Make sure there is no slack in the film. Close the door and turn on the camera.
Mar 13, 2009 | Nikon F60 35mm SLR Camera
Blank Film Developing
kwilson36
you should have at least 6in. of exposed film from the film canister to the take-up spool unless you loaded the film in total darkness.
open the back cover to make sure the shutter is working, reload and give it another try.
Jan 25, 2009 | Nikon N90S 35mm SLR Camera
How do i change ISO/ASA on the nikon N65?
The ISO is automatically set by the DX code on your film canister - if there is no code, the camera sets ISO 100. If you load canisters yourself with, say ISO 400 film, you can adjust the exposure using the exposure compensation button at the top right side of the LCD ( " +/- " ). Using ISO 400 film set the +/- to minus 2 ( -2 ) so that it will UNDEREXPOSE 2 stops since the film is 2 stops ( 4X ) more sensitive than ISO 100 film.
Nov 18, 2008 | Nikon Cameras
Nikon N-65 Camera
Hey mrskee,
The first suggestion I would make is to make sure your pulling the film leader out far enough, and the film canister is sitting in place properly. If this doesn't work I would examine the sprocket holes in the film leader and make sure they are not ripped if they are you should pull the film out until they are no longer ripped and then try loading the film again. I hope this helps.
Sincerely,
Allan
Go Ahead. Use Us.
May 20, 2008 | Nikon N65 35mm SLR Camera
CAN WORKOUT HOW TO OPEN NIKON FE CAMERA
Sept 19th, 2008
On the bottom of the Nikon FE, there is a silver button to push in, and this releases a lock for the film.
Then on the left side, on the top, there is a white arrow and a silver lever tucked in. Wind your film, this it's all the way back in the canister. Then the black lever by the speed film (ASO) numbers, pull that back toward you. This will release the black 3/4" knob upward, and by gently pulling this upward, your door will release and the film canister will be allowed to come out. Just besure to wind your film back in the cansiter, before you open the door, or your photos will be over exposed. Best to do this in a darker area or shaddowed area, just for protection.
Good Luck. I've had mine since the mid 1970's and love it for double exposures and the special filters I have for it. The Hot Shoe for the flash attachment, just burned out on me a couple of days ago.
Mar 02, 2008 | Nikon FE 35mm SLR Camera
Nikon N55 35mm SLR Camera Logo
283 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Greg Cann
Greg Cann
Are you a Nikon Photography Expert? Answer questions, earn points and help others
