Question about Refrigerators
Need to get access to the pump. How do open up the
Need to get access to the pump of a top load washing machine How do I open up the front?
  • matlock_mich May 11, 2010
    One o two ways under the consol is 2 clips pop them and pull forward or look or2 screws on bottom of front remove and remove by tilting bottom upward.Hope this helps.
    President:
  • 1,937 Answers
Assuming that this is a basic Whirlpool / Kenmore top load, direct drive washer, see the following.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=962131af4fd992034867327e32162166
Posted on Nov 16, 2009
How do I remove the bottom cover of my access pump tp check my Frigidaire front load washer GLTF2940e. It is not spinning. I need a visual! Thank You
The front panel does not open. HYou need ro access the pump from the rear of the washer or lean the washer to the side and access the pump from under the washer.
I hope the helps you. Please the me know if I can assist yuou further.
Thanks,
Vic
Apr 23, 2011 | Frigidaire GLTF2940ES Front Load Washer
Calypso front panel removal
Hi If you just need to get to the pump there is a access panel on the bottom.. flip it on its side and unscrew the panel you should be able to get to it... if you can't you can open the top with by pushing a putty knife in the front to push in the two clips and the top will hinge back.. then you can get to the screws to remove the front panel.. let me know how you do .. Thanks
Sep 08, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing machine flashing oe
OE = Drain Error • Not fully drained within 10 minutes.
Check and clean the pump filter. The access panel is located on the front, bottom left of the machine. Place a towel under the front of the pump filter access panel opening before opening to catch any water that may flow out.
Check drain hose on the back of the machine for any kinks or blockage.
Dec 18, 2010 | LG WM1814CW Front Load Washer
I have a kenmore washer that does not drain and spin at the end of the wash cycle....Kenmore Super Capacity 3.5...Quiet Tumble Action...Easy Access
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 02, 2010 | Frigidaire ATF6000ES Front Load Washer
My washer is smoking and wont stop spining after a cycle i assume this is the belt and i am going to replace it but right now i am having trouble opening the front or back whichever i need to get to the...
heatman101
Aug 29, 2010 | General Electric WHDRE526EWW Top Load...
How do I access the drain pump to see if it is clogged. Filter is clean and drain hose is not kinked or clogged
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 19, 2010 | LG WM0642H
Machine has stopped and says clean pump?? where is pump??
you need to remove the front kick panel and then the top cover then you can access the pump in the lower area below the wash tub
Feb 27, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Need to remove the front panel of front load washer
you will have to remove the rear panel in order to remove the front panel. The bolt and clamp are inside the front panel.
Jul 09, 2009 | Frigidaire ATF6000ES Front Load Washer
I need to replace the pump on my Admiral AAV70000AWW washing machine but need a repair guide manual or instructions
Electrically Isolate the machine
To access the pump the front panel needs to be removed, first the machine top needs to be opened,
at the joint between the machine front panel and top insert a flat blade 4" from each side to release the lid catches, tilt back the top to access the internal screws on the front panel and remove the front by lifting off it the bottom brackets.
Ensure the machine is empty of water, to do this lower the waste drain pipe to floor level and clooect any water in a suitable container.
Tilt the machine back 45 degrees and remove the drive belt and bolts for the pump, remove the hoses from the pump, refit in reverse order.
Jun 08, 2009 | Maytag Admiral AAV7000A
Washer gets ld code
The ld fault is a long drain error. Check your drain pump reservoir and drain hoses for clogs. Removing the agitator in my opinion would be unnecessary. Unplug your machine and remove the back panel. There should be a drain pump reservoir at the bottom under the wash basin. They are notorious for collecting lint and hair and can obstruct the drain flow. You can also squeeze along the drain lines and feel for obstructions. To access the drain pump itself, its easier to remove the front panel. You will need to release the two metal hold down clips located under the front lip approx. two inches from either side. You need a putty knife to push in on the clips and lift on the top front at the same time. Once you have the top released, lift up and remove two screws holding the front panel. The front panel should pull away leaving an open access to the inside cabinet. The drain pump is located on the lower right-hand side of the wash tub at the very bottom of the unit. You can easily remove the two drain lines at the pump and check for obstructions there as well. Again, unplug the unit before servicing the pump. I hope this helps.
Mar 29, 2007 | Kenmore 23822 Top Load Washer
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
